TW's active 4runner builders BS thread
Discussion in '4Runners' started by ramonortiz55, Jul 21, 2015.
  1. Sep 21, 2018 at 7:49 AM
    Roody
    Roody Well-Known Member
    Ross
    SW CT
    GX460
    Do you have a link / part # for them? There's so many variations I'm lost in the abyss of over-info
  2. Sep 21, 2018 at 8:35 AM
    Roody
    Ross
    SW CT
    GX460
    Awesome, thanks. In doing some research I also saw that people are running 5100s (or 6112s) and FJ springs. Seems super cheap to do (<$400). Any knowledge on this?
  3. Sep 21, 2018 at 8:35 AM
    4Running Daily
    4Running Daily Long Live ZS
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    I hated mine. I had the wrong amount of weight where the coils would clank over bumps
    dtaco06 likes this.
  4. Sep 21, 2018 at 8:46 AM
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    Mine didn’t have an isolated band. I like my LC’s a lot better even if they gave me another inch of lift.
  5. Sep 21, 2018 at 8:49 AM
    Roody
    Ross
    SW CT
    GX460
    The Toytec Land Cruiser springs?
  6. Sep 21, 2018 at 9:02 AM
    Roody
    Ross
    SW CT
    GX460
    So that's where the 6112 / 5125 comes in, in making sure it doesn't knock into the shock? Or is it not extra length and I'm way off?
  7. Sep 24, 2018 at 10:36 AM
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    You guys think spray paint on the AC condenser could block airflow? Seems like a dumb question
  8. Sep 24, 2018 at 10:56 AM
    Unner
    Unner Well-Known Member
    Huntsville, AL
    01 4Runner 4x4, 08 4Runner 4x4
    2001 4Runner, Lifted, Armored, 33s 2008 4Runner Stock
    Unless you're using bedliner I wouldn't worry about it. The bugs and crap that gets stuck in it would block more airflow.
  9. Sep 24, 2018 at 10:58 AM
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    I’m still trying to figure out why my shit runs so hot on the freeway
  10. Sep 24, 2018 at 11:05 AM
    Unner
    Huntsville, AL
    How old is the radiator and the other cooling system parts?
  11. Sep 24, 2018 at 11:09 AM
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    Radiator is a brand new denso, new t-stat, water pump/tb is probably 60k or so old. Brand new 40 amp, 2 speed electrical fan and shroud. Cut the cat out because it was blocking flow.
  12. Sep 24, 2018 at 11:14 AM
    Plastics Guy
    Plastics Guy DuroBumps
    DuroBumps
    Arizona
    02 4Runner
    Plasti-dip & exhaust tip
    It can cause problems because the paint does not dissipate heat at the same rate as the raw aluminum. The paint can encapsulate the heat to some degree, its a coating.
    Do I think that it would be noticeable as far as increasing operating temperature, No!
    Was this post useful to the OP in any way?... NO!!
  13. Sep 24, 2018 at 11:18 AM
    Plastics Guy
    DuroBumps
    Arizona
    02 4Runner
    Are you familiar with the known issue of the T-stat being installed 180 out? There is a little bypass vent that if its in the wrong orientation the truck runs 15- 20 degrees warmer. Once the T-stat is rotated to the proper orientation the temperatures are back to normal. Kind of sounds like that could be your issue. At least it would be nice if its your issue because its an easy fix!
    Do you remember the orientation of the bypass jiggly valve when you installed it by chance?
  14. Sep 24, 2018 at 11:33 AM
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    Ya I did 6:00
    Unner likes this.
  15. Sep 24, 2018 at 12:00 PM
    Unner
    Huntsville, AL
    Maybe the electric fan is causing the issues? If everything else is fairly new, stock, and functioning that really only leaves the electric fan.
    How was the cat blocking air flow? Or do you mean exhaust flow?
  16. Sep 24, 2018 at 12:11 PM
    Plastics Guy
    DuroBumps
    Arizona
    02 4Runner
    Yup, that is correct....
  17. Sep 24, 2018 at 12:41 PM
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    Previously I had a stock fan with no fan shroud. And because of the body lift, the fan and radiator do not line up. So that’s why I went electric. I removed the cat after my mechanic suggested it. I was at 220 freeway on occasion and removing the cat brought it down to 207. I still work at Magnaflow, so I’m gonna throw in another one when I get time.
  18. Sep 24, 2018 at 12:43 PM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    im hoping to go to an electric fan soon for mine. Tired of my semi truck fan now
  19. Sep 24, 2018 at 12:43 PM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    4Running Daily and dtaco06 like this.
  20. Sep 24, 2018 at 2:46 PM
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    Unner and dtaco06 like this.
