TW's active 4runner builders BS thread
Discussion in '4Runners' started by ramonortiz55, Jul 21, 2015.
  1. Jan 8, 2016 at 11:47 PM
    #4221
    RedRunner87
    RedRunner87 Mall Crawler LVL Expert
    Vince
    The Springs, CO
    16 4Runner SR5
    255/80 Falken Wildpeak AT3W
    Makes my 4Runner hit road marker signs....
  2. Jan 9, 2016 at 12:14 AM
    #4222
    Russtoy
    Russtoy Well-Known Member
    Russel
    Ohio
    2000 4Runner SR5
    Ouch...I saw that!! I hate when road signs jump out in front of you like that...hahaha. Sorry...but it does look like the mountain logo now. The green over the TRD looks like the mountain tops...lol! :itllbuffout:
    Seriously....hopefully you'll be able to buff it out and all will be good :fingerscrossed: :pray:
  3. Jan 9, 2016 at 12:22 AM
    #4223
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    Unfortunately because of the weather it is going to stay like that till it starts to get significantly warmer. But I will try to buff it out in the Spring. Lesson learned for sure though.
    Glad you see back to posting again and feeling better!
  4. Jan 9, 2016 at 12:26 AM
    #4224
    Russtoy
    Russel
    Ohio
    2000 4Runner SR5
    No worries...anyone ask, tell them you laid it on its side while 4wheels up in the mountains!! Remember...chick's dig scares!! Wear it like a badge of honor!
    RedRunner87[QUOTED] likes this.
  5. Jan 9, 2016 at 5:04 AM
    #4225
    rjsimz
    rjsimz Well-Known Member
    Rob
    Huntersville, NC
    13 4x4 DCLB
    @MattJakobs where do you get your vehicle inspections done around here?
  6. Jan 9, 2016 at 7:30 AM
    #4226
    ramonortiz55
    ramonortiz55 [OP] Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
  7. Jan 9, 2016 at 8:14 AM
    #4227
    MattJakobs
    MattJakobs Everything but a Tacoma
    Matthew
    NorCal
    1985 4Runner w/ FlipPac
    There's a citco off Kings Grant Road I go to. Family has for the last 17 or so years and it's just down the road so super convenient
  8. Jan 9, 2016 at 8:18 AM
    #4228
    rjsimz
    Rob
    Huntersville, NC
    13 4x4 DCLB
    I figured you went to that one.
  9. Jan 9, 2016 at 8:26 AM
    #4229
    ramonortiz55
    Ramon
    Texas
    stock
    i swapped out my cv axles yesterday. since a bit of oil dripped out, I need to top off the diff. i cant top it off until next weekend. as long as i dont engage 4x4, should i be okay?
  10. Jan 9, 2016 at 8:46 AM
    #4230
    4Running Daily
    4Running Daily Long Live ZS
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    You'll be fine even if you don't top it off. Also not engaging 4x4 doesn't matter because your diff is always spinning, even in 2WD.
  11. Jan 9, 2016 at 8:47 AM
    #4231
    ramonortiz55
    Ramon
    Texas
    stock
    really? i didnt know that
  12. Jan 9, 2016 at 8:49 AM
    #4232
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    That is a great idea!
  13. Jan 9, 2016 at 8:50 AM
    #4233
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    I didn't know that either! The forums always tell us to engage 4wd to lube everything up
  14. Jan 9, 2016 at 8:51 AM
    #4234
    mr optimist
    mr optimist Mr Lazy
    Sam
    Alamosa, CO
    1998 4runner SR5 5 speed
    Supercharged, 5 speed, AOR Sliders, Tundra Front Springs, OME 906 Rear springs, Bilstein Tundra 5100s, Factory Diff lock, Wrangler Authority 275/75/16
    You don't need to top off. Sometimes it "burps" a little out the breather. I have topped mine off twice now. I almost wonder if the correct level is just under the fill hole and it equalizes through the breather. Who knows :rolleyes:
    Really? even with ADD? Wouldn't just the left side spin?
  15. Jan 9, 2016 at 8:54 AM
    #4235
    ramonortiz55
    Ramon
    Texas
    stock
    ii figured just the cv axles spun
  16. Jan 9, 2016 at 8:59 AM
    #4236
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    So here is how our 4WD systems work.
    Transfer case has 2 driveshafts, 1 to each diff. If the car is in motion, 2WD or 4WD, both driveshafts are spinning.
    Now the Front Diff is directly connected to the driveshaft, therefore it is always spinning as well.
    The CV Axles are attached to the wheels directly, therefore, if the car is in motion, 2WD or 4WD, both CV's are spinning.
    The part that separates 2WD from 4WD is ADD. Which is a vacuum powered actuator on one side of the diff that disconnects the CV axle from the gears inside the diff.
    In 4WD the actuator allows the CV to connect with the diff causing both CV's to be connected to an open differential, spinning the wheel that requires less force.
    In 2WD the actuator disconnects the passenger side CV axle. So yes the Driver side CV is still connected, but it's an open diff, the diff is gonna spin the wheel that requires less force, which is the side that is disconnected due to the ADD actuator.
    Hopefully that makes some sense
    T4RFTMFW likes this.
  17. Jan 9, 2016 at 9:01 AM
    #4237
    mr optimist
    mr optimist Mr Lazy
    Sam
    Alamosa, CO
    Right. I would imagine just having one side spin the diff is much less resistance than both. I have always wondered why there is such a low maximum speed on the 4wd system. Because, like you said almost everything is spinning all the time anyways...
  18. Jan 9, 2016 at 9:10 AM
    #4238
    ramonortiz55
    Ramon
    Texas
    stock
    so in 2WD only three wheels spin mechanically?
  19. Jan 9, 2016 at 9:13 AM
    #4239
    SCRunner12
    SCRunner12 Tundra Troll
    Robert
    Santa Cruz, CA
    2006 Tundra DC, TRD, 4wd
    You guys can buy my manua hubs and the front diff will never spin unless you want it to...haha
  20. Jan 9, 2016 at 9:13 AM
    #4240
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    Technically yes, in 2WD, 3 wheels are connected to the transfer case.
    But assuming you have an open rear diff, only 1 rear wheel is getting power in 2WD.
