TW's active 4runner builders BS thread
Discussion in '4Runners' started by ramonortiz55, Jul 21, 2015.
  1. Jan 10, 2016 at 1:25 PM
    #4301
    MattJakobs
    MattJakobs Everything but a Tacoma
    Matthew
    NorCal
    1985 4Runner w/ FlipPac
  2. Jan 10, 2016 at 1:27 PM
    #4302
    rjsimz
    rjsimz Well-Known Member
    Rob
    Huntersville, NC
    13 4x4 DCLB
    Ah, you can't really cut that one up for the satoshi. Thanks though!
  3. Jan 10, 2016 at 1:30 PM
    #4303
    MattJakobs
    Matthew
    NorCal
    oh no, I thought you were looking for a filler while you cut one up. I forgot where I bought mine but have it written down somewhere, I believe it was about $40-$50
  4. Jan 10, 2016 at 1:31 PM
    #4304
    rjsimz
    Rob
    Huntersville, NC
    13 4x4 DCLB
    Not bad.
  5. Jan 10, 2016 at 1:33 PM
    #4305
    MattJakobs
    Matthew
    NorCal
    fit perfectly, came with new clips as well. theres a chrome option and a primed option depending on whether or not you want to paint it
  6. Jan 10, 2016 at 1:42 PM
    #4306
    ramonortiz55
    ramonortiz55 [OP] Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    i wanted the seahawks out.. unbelievable
  7. Jan 10, 2016 at 1:42 PM
    #4307
    ramonortiz55
    Ramon
    Texas
    stock
    has anyone ever had their brake booster fail?
  8. Jan 10, 2016 at 1:43 PM
    #4308
    rjsimz
    Rob
    Huntersville, NC
    13 4x4 DCLB
    I'd like to color match it. Duplicolor does a perfect job matching Toyotas OEM colors
  9. Jan 10, 2016 at 1:46 PM
    #4309
    kyle11863
    kyle11863 King of the BS
    Kyle
    Big Bear, CA
    1990 Toyota 4Runner SR5 V6 4x4
    Doug Thorley long tube headers and lots of mud
    I had the master cylinder fail but not my brake booster. Good thing too. Boosters are expensive
  10. Jan 10, 2016 at 1:48 PM
    #4310
    ramonortiz55
    Ramon
    Texas
    stock
    what was the symptoms on the master cylinder?
    these past few days ive felt ive had to press my brake in further than normal to get the 4runner to start slowing down.
    or pump it a few times..
  11. Jan 10, 2016 at 1:49 PM
    #4311
    RaleighTaco
    RaleighTaco Well-Known Member
    Jonathon
    Raleigh NC
    '97 Toyota 4runner
    Any of you guys with a snorkel had the rubber elbow that connects the snorkel to the air box collapse at wot?
  12. Jan 10, 2016 at 1:52 PM
    #4312
    kyle11863
    Kyle
    Big Bear, CA
    That sounds like master cylinder to me. I had that issue or as I like to call it, airy brakes. One thing that I would do to see if it fixes the problem is bleed your brakes. It helps a lot
  13. Jan 10, 2016 at 1:53 PM
    #4313
    MattJakobs
    Matthew
    NorCal
    I know, when thinking about doing my bumper color, I kept thinking black and doing my flares color matched with the Duplicolor
  14. Jan 10, 2016 at 1:58 PM
    #4314
    ramonortiz55
    Ramon
    Texas
    stock
    my Camry is doing the same thing.
    i bled the brakes and it still does it.
    Would be a coincidence if BOTH master cylinders failed on BOTH vehicles at the same time
  15. Jan 10, 2016 at 2:01 PM
    #4315
    kyle11863
    Kyle
    Big Bear, CA
    It kinda just depends how airy they are. When I did it on mine I did several pumps on each wheel. Probably went through a half a bottle each time I did the process. They did feel better each time
  16. Jan 10, 2016 at 2:03 PM
    #4316
    ramonortiz55
    Ramon
    Texas
    stock
    any other way to diagnose the master brake cylinder?
  17. Jan 10, 2016 at 2:09 PM
    #4317
    kyle11863
    Kyle
    Big Bear, CA
    There is one way that my auto shop teacher showed me. I know it works on my 2nd gen but I'm not sure it is reliable for other cars. He told me to slightly push on the brake pedal and start the car. If I felt the pedal try to push out it was good, if it didn't the cylinder was dying. Mine didn't push out and sure enough 7 or so months (and 6 brake bleeding sessions) later my cylinder gave out completely
    ramonortiz55[OP] likes this.
  18. Jan 10, 2016 at 2:11 PM
    #4318
    ramonortiz55
    Ramon
    Texas
    stock
    thanks
  19. Jan 10, 2016 at 2:13 PM
    #4319
    ramonortiz55
    Ramon
    Texas
    stock
    Nope. It doesnt push back... at alll
  20. Jan 10, 2016 at 2:16 PM
    #4320
    kyle11863
    Kyle
    Big Bear, CA
    Yeah then it probably is only a matter of time then
    One thing I must warn the with the brake bleeding. When it completely goes you will still have a little pedal left, but if you try to bleed it after it goes out 100% you will have no brake pedal at all. Definitely keep to bleeding at your house. I made the mistake of doing it at a friends and had to drive home with no brakes
