TW's active 4runner builders BS thread
Discussion in '4Runners' started by ramonortiz55, Jul 21, 2015.
  1. Feb 6, 2016 at 6:13 PM
    #5481
    kyle11863
    kyle11863 King of the BS
    Kyle
    Big Bear, CA
    1990 Toyota 4Runner SR5 V6 4x4
    Doug Thorley long tube headers and lots of mud
    That would require so much work time and money. I'd need to find the swing out and find a tailgate for it (probably have to paint it too) rip off my old one, wire up and attach the new one, and then mount the swing out. I don't know if I'd trust myself mounting that swing out with how much wait they are.
    Also if I'm not mistaken the body is actually slightly different for the swing out ones then the non swing out ones, which if that's the case would cause an extra problem
  2. Feb 6, 2016 at 6:19 PM
    #5482
    RedRunner87
    RedRunner87 Mall Crawler LVL Expert
    Vince
    The Springs, CO
    16 4Runner SR5
    255/80 Falken Wildpeak AT3W
    I have always had a weak spot for the second gen with swing out
  3. Feb 6, 2016 at 6:21 PM
    #5483
    mr optimist
    mr optimist Mr Lazy
    Sam
    Alamosa, CO
    1998 4runner SR5 5 speed
    Supercharged, 5 speed, AOR Sliders, Tundra Front Springs, OME 906 Rear springs, Bilstein Tundra 5100s, Factory Diff lock, Wrangler Authority 275/75/16
    2nd gen is the only 4wd toyota I would do that to why? Cheap, and 3.slow.
    the stock swing out is cool as hell though
    ramonortiz55[OP] likes this.
  4. Feb 6, 2016 at 6:23 PM
    #5484
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    The only thing wrong with them is that torsion bars blow! There isn't a good way to lift them and no flex
  5. Feb 6, 2016 at 7:02 PM
    #5485
    MattJakobs
    MattJakobs Everything but a Tacoma
    Matthew
    NorCal
    1985 4Runner w/ FlipPac
    I have a feeling it's going to be hard to say no to it when I see the ladder feature
  6. Feb 6, 2016 at 7:19 PM
    #5486
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
  7. Feb 6, 2016 at 8:22 PM
    #5487
    Russtoy
    Russtoy Well-Known Member
    Russel
    Ohio
    2000 4Runner SR5
    What are you asking for your Beadlocks? What size? If they have tires...what size? Willing to seperate?
  8. Feb 6, 2016 at 8:57 PM
    #5488
    SCRunner12
    SCRunner12 Tundra Troll
    Robert
    Santa Cruz, CA
    2006 Tundra DC, TRD, 4wd
  9. Feb 6, 2016 at 9:04 PM
    #5489
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
  10. Feb 6, 2016 at 9:16 PM
    #5490
    SCRunner12
    Robert
    Santa Cruz, CA
    I've got no monies or place to store it. Once we get a bigger place and more than just street parking i will be getting a project.
  11. Feb 6, 2016 at 9:19 PM
    #5491
    SCRunner12
    Robert
    Santa Cruz, CA
    I'm going to replace my timing belt cover on my 4Runner tomorrow as it has been cut to fit a supercharger. Do I need to do a full fluid replacement to remove the upper radiator hose or could I get away with just removing the hose, adding the same amount of coolant back in and burping the system?
  12. Feb 6, 2016 at 9:19 PM
    #5492
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    That is my problem, I don't have a garage. So a project like that wouldn't happen.
  13. Feb 6, 2016 at 9:30 PM
    #5493
    SixthSnail
    SixthSnail I have no idea what I'm doing
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    I'm trying to sell them together for around 2000 OBO. Perfect shape toyo MTs in 285/75/17. Wheels are 17" and Come with the spacers on them.
  14. Feb 6, 2016 at 10:22 PM
    #5494
    Russtoy
    Russel
    Ohio
    2000 4Runner SR5
    That was quick...has a sale pending on it.
    Shoot...that was a money maker. Could have bought it for $500 and sold it on a quick flip for $1500!! Someone so
    Did you get your electrical problem fix??
    With your coolant...open your radiators cockpit and drain your antifreeze into a clean vessel. Approximately a quart or two (make sure you block off your over-flow coolant bottle before starting). Then close the cockpit back up...now you'll be able to remove your upper radiator hose without making a huge mess. Once done with your TB, reattach your over-flow coolant bottle...then just pour the antifreeze back into your system. Good luck!
    Thanks Matt...appreciate the info. I'm looking for some 17x9 or 17x10's Beadlocks. Not really looking for tires unless they're 33x12.5. Thanks again.
  15. Feb 6, 2016 at 10:30 PM
    #5495
    SixthSnail
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    No prob. I'll let you know if I split them
  16. Feb 6, 2016 at 10:31 PM
    #5496
    SixthSnail
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    Previous owner put HIDs from TRS in!
  17. Feb 6, 2016 at 10:34 PM
    #5497
    Russtoy
    Russel
    Ohio
    2000 4Runner SR5
    No worries...thanks. Hey Matt, when you drive your 4Runner with the Beadlocks on...do you notice anything different? Or do they give just a normal nice comfortable ride. I think I want Beadlocks...unless the ride is changed for the worst.
    Thank you for your opinion and observations,
    Sweet HIDs...I love mine!!
  18. Feb 6, 2016 at 10:37 PM
    #5498
    SixthSnail
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    My opinion is slightly skewed. The truck rides a bit different from the Tacoma. My Tacoma has 33" Toyo ATIIs. Those are a load C tire. The tires on the T4R are load E so they are stiffer.
    Beadlocks are hard to balance so I expected the ride to be worse. It's not bad. I drove about 300 miles on them today and they felt fine. Would be better without beadlocks but just slightly.
  19. Feb 6, 2016 at 10:40 PM
    #5499
    Russtoy
    Russel
    Ohio
    2000 4Runner SR5
    You got an awesome deal on your 4Runner. The PO spent a ton of money on it. Frik'in awesome $4-5,000 suspension upgrades. HID's in the headlights...another $5-600 depending which he purchased...Beadlocks with Toyo MT's that's another $3000+!! Wow...you made out!! Good for you Bro!!
  20. Feb 6, 2016 at 10:48 PM
    #5500
    Russtoy
    Russel
    Ohio
    2000 4Runner SR5
    The balancing is actually what I was worried about. That much hardware spinning...I figured it would be difficult to balance. For me, if it can be pretty close...I'm fine. Just as long as it's not shacking to truck apart...haha!!
    I'm running Toyo's AT II's also...what an awesome tire!! I love them. So quite on the road...smooth riding you forget you are running a AT tire. Top it off...does pretty darn good off road...except in deep sticky mud. But snow and ice is great!...IMHO...
    SixthSnail[QUOTED] likes this.
