TW's active 4runner builders BS thread
Discussion in '4Runners' started by ramonortiz55, Jul 21, 2015.
  1. Nov 15, 2015 at 7:32 PM
    #721
    ramonortiz55
    ramonortiz55 [OP] Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    so having my rear locker installed tomorrow.
    extended brake lines also!
    I will let you guys know how it goes..
    I am also needing new tires..very soon :D
  2. Nov 15, 2015 at 7:35 PM
    #722
    rjsimz
    rjsimz Well-Known Member
    Rob
    Huntersville, NC
    13 4x4 DCLB
    First time in sand with them...handled like a champ. Love em.
  3. Nov 15, 2015 at 7:38 PM
    #723
    ramonortiz55
    Ramon
    Texas
    stock
    dude, when I bought my 2015 taco, took it to the beach the next day. pulled out two fords :D
  4. Nov 15, 2015 at 7:39 PM
    #724
    rjsimz
    Rob
    Huntersville, NC
    13 4x4 DCLB
    Haha, sounds like typical Ford guys. Wish I had a taco. Need a truck bed.
  5. Nov 15, 2015 at 7:41 PM
    #725
    ramonortiz55
    Ramon
    Texas
    stock
    its a beach with a LOT of loose sand.. A LOT, there are plenty of warning signs that all vehicles enter at own risk.. 4x4 highly recommended..
    they ford guy was a 2 wheel drive
  6. Nov 15, 2015 at 7:43 PM
    #726
    rjsimz
    Rob
    Huntersville, NC
    13 4x4 DCLB
    Exactly, they think, "Oh hey, I've got a truck!" and think they could bulldoze through anything without 4wd. Idiots.
  7. Nov 15, 2015 at 7:49 PM
    #727
    Nicklovin
    Nicklovin Mall Crawlin Through Life
    Nick
    Huntington Beach, CA
    00 The Tunda - 0̶4̶ P̶r̶e̶r̶u̶n̶n̶e̶r̶ - 0̶1̶ O̶v̶e̶r̶l̶a̶n̶d̶e̶r̶ - 07 FJ Mall Crawler Xtrme
    Tacoless
    Here's a question for you 4 runner guys along with a little story. So I come from a family of badass mechanics, unfortunately they are all dead thus I am not too smart mechanically. However I really want to learn and have decided to pickup a project car. Currently considering an old 4 runner from the 80s, what's your guys' opinions on this?
  8. Nov 15, 2015 at 7:51 PM
    #728
    ramonortiz55
    Ramon
    Texas
    stock
    I am not too savvy on the first gens. I know the second gens are slow and are considered the bastard child of 4runners..
    Now 3rd gens.. ask @RedRunner87 @ramonortiz55 @Russtoy anything you want
  9. Nov 15, 2015 at 8:08 PM
    #729
    SCRunner12
    SCRunner12 Tundra Troll
    Robert
    Santa Cruz, CA
    2006 Tundra DC, TRD, 4wd
    Had one in high school. Awesome trucks and a lot of fun in the summer with the top coming off. Oh have basically three options with them. 84-85 is a solid axle up front, but 84 was carb and 85 typically fuel knjected (better). Good trucks and very capable, but slow and fetch a pretty penny because of the solid axle.
    86-89 4cyl are ifs and fun truck with the 5 speed. Most are fuel injected and typically found with 175-300k+ on the body. It's hit or miss if they in good shape but can be found unmolested or beat.
    88-89 had the option for the legendary (in a negative way) 3.slow. A pretty weak engine for being a v6 and horrible mileage typically. Also has the tendency to blow head gaskets if not watched, maintained and caught early. With an auto it almost rolls backwards on hills...haha. Still ifs and a good platform with the 5 speed for a 3.4 swap. I plan on picking one up in a year or so to make a project.
    There is a ton of aftermarket for them and the 4cyl can be built up by going with LCE, but don't expect too much. Also 86-87 had a turbo 4cyl but only offered in auto trans.
  10. Nov 15, 2015 at 8:11 PM
    #730
    ramonortiz55
    Ramon
    Texas
    stock
    the first gens have the common rust on the rear fenders right?
    so if you find out without the ruse on the rear fenders.. its a WIN!
    check on the fender rust!
  11. Nov 15, 2015 at 8:51 PM
    #731
    Russtoy
    Russtoy Well-Known Member
    Russel
    Ohio
    2000 4Runner SR5
    On my rack lights...I actually had Jim @OTRATTW make thoes especially for me!! He's a great guy to work with!! Absolutely can't say enough nice things about him! If your going to buy any switches...buy from him!!
    I think the item you are asking about is one of my LED light wands. Have a couple of them...bright as heck. They last for about 4-6 hr charge. Got them off the Cornwell Tool truck.
    I'm Sure I told you and showed you pictures of my big alumuine raditor. Well, I have 2 e-fans cooling it. So I had a switch made up so I can turn the e-fans off if I'm going to be crossing any waterways. That way my e-fans do not get damaged by hitting the water! Well...hey, there's one of thoes LED light wands again...lol!!
    With the relay/fuse box...I used an items called poly-nuts. You drill a hole, then use a tool that looks like a rivet gun...but instead of shooting a rivet...it inserts a threaded nut into the drilled hole. So now I can bolt whatever I want there. Nice clean install...looks factory! IIRC...The poly-nuts run from 6mm-12mm. They come in a kit...kit cost like $75 or so. It's not a Cornwell tool, but I got it off my Cornwell Tool truck!
  12. Nov 15, 2015 at 8:56 PM
    #732
    ramonortiz55
    Ramon
    Texas
    stock
    polynuts? ill have to look into it..
  13. Nov 15, 2015 at 9:04 PM
    #733
    SCRunner12
    Robert
    Santa Cruz, CA
    What's rust? I live in California, I have no recollection of this substance on my 4Runner...haha
    That is true though, they are prone to rust on the rear and front fenders right by wheel well. They do have fiberglass bedsides that you can buy to replace the steel ones to avoid that problem again in the future.
  14. Nov 15, 2015 at 9:04 PM
    #734
    ramonortiz55
    Ramon
    Texas
    stock
    so what do you call this gun? polynut gun?
  15. Nov 15, 2015 at 9:05 PM
    #735
    Russtoy
    Russel
    Ohio
    2000 4Runner SR5
    They are awesome. Once installed it's like having a threaded nut there. So now you can bolt up whatever you want. The best part...you have the ability to remove an item...without having big holes in your sheetmetal! Greatest thing since slice bread my friend.
  16. Nov 15, 2015 at 9:08 PM
    #736
    ramonortiz55
    Ramon
    Texas
    stock
    how much torque can you put on them?
    hmm them you need to buy the bolts to match the threads right?
  17. Nov 15, 2015 at 9:11 PM
    #737
    Russtoy
    Russel
    Ohio
    2000 4Runner SR5
  18. Nov 15, 2015 at 9:13 PM
    #738
    ramonortiz55
    Ramon
    Texas
    stock
    i dont like sheet metal screws either. I use rivets. But I like the idea of being able to thread a bolt in, removing, unbolting and what not. With a Rivet, you drill and tap once. drill it out if you mess up or need to remove it
  19. Nov 15, 2015 at 9:13 PM
    #739
    Russtoy
    Russel
    Ohio
    2000 4Runner SR5
    Correct...they come in different sizes to match different bolts....depends on what you are mounting. Buy yourself a kit. Once you use it...you'll be hooked.
  20. Nov 15, 2015 at 9:14 PM
    #740
    ramonortiz55
    Ramon
    Texas
    stock
    thanks for the link. I need this. this is awesome
