TW's active 4runner builders BS thread
Discussion in '4Runners' started by ramonortiz55, Jul 21, 2015.
  1. Mar 3, 2016 at 8:56 PM
    #8661
    ramonortiz55
    ramonortiz55 [OP] Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    ill do this
  2. Mar 3, 2016 at 8:56 PM
    #8662
    ramonortiz55
    Ramon
    Texas
    stock
    ive never messed w the pinch weld.. time to do some hammering
  3. Mar 3, 2016 at 9:04 PM
    #8663
    MattJakobs
    MattJakobs Everything but a Tacoma
    Matthew
    NorCal
    1985 4Runner w/ FlipPac
    They cause cancer, don't do it...
    Planned on running spacers?
    Is this because of the added width more so than height?
  4. Mar 3, 2016 at 9:05 PM
    #8664
    MattJakobs
    Matthew
    NorCal
    @4Running Daily
    Do you have Tundra breaks? If so, how'd you clear them with your LC wheels. Don't recall you having spacers
  5. Mar 3, 2016 at 9:10 PM
    #8665
    4Running Daily
    4Running Daily Long Live ZS
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    I do not have Tundra brakes because supposedly they only clear the LC wheels if you have a inch spacer.
    MattJakobs[QUOTED] likes this.
  6. Mar 3, 2016 at 9:16 PM
    #8666
    SCRunner12
    SCRunner12 Tundra Troll
    Robert
    Santa Cruz, CA
    2006 Tundra DC, TRD, 4wd
    It's not bad at all. You'll want to trim some of the fender liner and hammer the pinch weld.
    A little of both, but yeah the width is what usually catches on the fender liner and such. The 255's are skinnier than stock tires so when it flexes it won't rub the top edge and rear of the fender.
    There are two different LC wheels. 93-94 are the acorn lugs and won't fit over 231's but the 95-97 LC wheels use the washer type lugs and do fit over the 231's.
  7. Mar 3, 2016 at 9:24 PM
    #8667
    MattJakobs
    Matthew
    NorCal
    Interesting, I've never heard this before. I have the washer type lugs so I guess that means I'm good and I can get rid of my spacers. I have much too much "stance" for my liking. I really want to narrow my wheel base some because I think my tires are sticking far too much out.
  8. Mar 3, 2016 at 9:34 PM
    #8668
    SCRunner12
    Robert
    Santa Cruz, CA
    I never ran the 95-97 wheels with my 231's but I'm pretty sure they work. I do have one sitting in my backyard that I could throw on my Tundra if I get ambitious.
    Just looked through BFAD TBU thread and it says LC wheels will it fit without a 1/4 spacer. You might be stuck with the spacers for now.
  9. Mar 3, 2016 at 9:46 PM
    #8669
    MattJakobs
    Matthew
    NorCal
    In that case I'll likely just get the TBU 199mm and hope they fit. Anything is an improvement really.
  10. Mar 3, 2016 at 9:50 PM
    #8670
    ramonortiz55
    Ramon
    Texas
    stock
    i need sleep
  11. Mar 3, 2016 at 9:55 PM
    #8671
    kyle11863
    kyle11863 King of the BS
    Kyle
    Big Bear, CA
    1990 Toyota 4Runner SR5 V6 4x4
    Doug Thorley long tube headers and lots of mud
    Nah sleep's for the weak!
  12. Mar 4, 2016 at 4:54 AM
    #8672
    rjsimz
    rjsimz Well-Known Member
    Rob
    Huntersville, NC
    13 4x4 DCLB
    Road tripping to Charlotte, NC today. I'll be playing with my brothers Audi and E39
    Pics:
    Getting it ready for SoWo in GA
    uurx and MattJakobs like this.
  13. Mar 4, 2016 at 5:22 AM
    #8673
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    Does the 2014 4runner have the lean if toytec springs are used. I have the spacer was wondering if it will be a problem for future install.
  14. Mar 4, 2016 at 5:23 AM
    #8674
    ramonortiz55
    Ramon
    Texas
    stock
    driver's side lean?
  15. Mar 4, 2016 at 5:24 AM
    #8675
    ramonortiz55
    Ramon
    Texas
    stock
  16. Mar 4, 2016 at 5:28 AM
    #8676
    Timbo's Customs
    Timothy
    Lakeland FL
    Yes do they end up with the lean without the spacer.
  17. Mar 4, 2016 at 5:28 AM
    #8677
    ramonortiz55
    Ramon
    Texas
    stock
    i know some generations have the lean in the REAR, but that is usually fixed with one of the springs being taller than the other.
  18. Mar 4, 2016 at 5:29 AM
    #8678
    ramonortiz55
    Ramon
    Texas
    stock
    reference? im curious about this now
  19. Mar 4, 2016 at 5:30 AM
    #8679
    ramonortiz55
    Ramon
    Texas
    stock
    so whenever you put your springs in the rear, make sure to check your labeling
  20. Mar 4, 2016 at 5:30 AM
    #8680
    Timbo's Customs
    Timothy
    Lakeland FL
    Ok. I'm about to order the 5100s front and rear and ome 889 rear springs. I have 2.5" toytec springs already from the tacoma.
