TW's active 4runner builders BS thread
Discussion in '4Runners' started by ramonortiz55, Jul 21, 2015.
  1. Mar 9, 2016 at 11:13 AM
    #9821
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    coilovers themselves are great. Customer service from icon, not so much.
    I see you still are a bitter bitch today.
  2. Mar 9, 2016 at 11:13 AM
    #9822
    4x4runner2002
    4x4runner2002 Well-Known Member
    Zach
    2002 4x4 limited
    suspension and armor
    Use them with bilstein shocks that have adjustable perches. Then you can get more or less lift. I believe the tundra ones have 5 settings and the Tacoma ones have three.
    I've never run them. I went straight to my icons up front.
  3. Mar 9, 2016 at 11:19 AM
    #9823
    ramonortiz55
    ramonortiz55 [OP] Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    its a fourth gen thing.
    Another fourth gen guy on here said the same thind as @LTDSC
    The 3rd gen superflexes are great.
  4. Mar 9, 2016 at 11:20 AM
    #9824
    rjsimz
    rjsimz Well-Known Member
    Rob
    Huntersville, NC
    13 4x4 DCLB
    That was a serious question but aiiiight. Thinking about scooping the ones that are local to me.
  5. Mar 9, 2016 at 11:21 AM
    #9825
    ramonortiz55
    Ramon
    Texas
    stock
    show meeh
  6. Mar 9, 2016 at 11:22 AM
    #9826
    mr optimist
    mr optimist Mr Lazy
    Sam
    Alamosa, CO
    1998 4runner SR5 5 speed
    Supercharged, 5 speed, AOR Sliders, Tundra Front Springs, OME 906 Rear springs, Bilstein Tundra 5100s, Factory Diff lock, Wrangler Authority 275/75/16
    I have the tundra ones. It doesn't really make sense to me how changing the perch makes it higher. The shaft on the shock isn't getting longer. Just seems like you would be preloading the spring and it would ride like crap.
  7. Mar 9, 2016 at 11:22 AM
    #9827
    rjsimz
    Rob
    Huntersville, NC
    13 4x4 DCLB
    When I get home from work
  8. Mar 9, 2016 at 11:23 AM
    #9828
    4x4runner2002
    Zach
    2002 4x4 limited
    That's exactly what you are doing. More preload is more lift but gets harsher.
    Same thing with fancy coil overs like icon,fox,King.
    That's why I put a 14" King spring in place of my 13" icon Spring. So I got the same lift with way less preload.
  9. Mar 9, 2016 at 11:24 AM
    #9829
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    they ride great, these had 60k miles on them when the rust on my shaft tore the inner seal at full compression. Otherwise i'd still be cruising on them without needing a rebuild. Rebuild kit was $35 each and rebuild itself was $75 each. Im happy with them. The shaft getting rust was an off circumstance and shouldnt be "usual".
    rjsimz[QUOTED] likes this.
  10. Mar 9, 2016 at 11:26 AM
    #9830
    ramonortiz55
    Ramon
    Texas
    stock
    hmmmmmm
  11. Mar 9, 2016 at 11:30 AM
    #9831
    rjsimz
    Rob
    Huntersville, NC
    13 4x4 DCLB
    I do more highway driving than anything so I'd like digressive for the speeds and shitty roads that I have to drive on. I'm leaning on snagging them.
  12. Mar 9, 2016 at 11:35 AM
    #9832
    ramonortiz55
    Ramon
    Texas
    stock
    do you know if @MattJakobs installed his finally?
  13. Mar 9, 2016 at 11:37 AM
    #9833
    RaleighTaco
    RaleighTaco Well-Known Member
    Jonathon
    Raleigh NC
    '97 Toyota 4runner
    Correct. I read in some thread that said most were pre wired you would just need to get the wiring from the locker to the dash. :notsure:
    I've got a month to figure it out. Swapping the axle and the front diff out is not a worry. Making sure I have all the electrical crap I need is.
  14. Mar 9, 2016 at 11:41 AM
    #9834
    RedRunner87
    RedRunner87 Mall Crawler LVL Expert
    Vince
    The Springs, CO
    16 4Runner SR5
    255/80 Falken Wildpeak AT3W
    That's what I have heard
  15. Mar 9, 2016 at 11:43 AM
    #9835
    mr optimist
    mr optimist Mr Lazy
    Sam
    Alamosa, CO
    I have it set on the lowest. No effective preload. I am only running 1.5in lift in the front. Lame. I know
  16. Mar 9, 2016 at 11:44 AM
    #9836
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    LAAAAAAAAAAAAAMMMMMMMMMMEEEEEEEEEEEEEEEEEEEEE
  17. Mar 9, 2016 at 11:48 AM
    #9837
    mr optimist
    mr optimist Mr Lazy
    Sam
    Alamosa, CO
    I am realistic about my needs. I am not going to run a ridiculous amount of lift to drive to work and back. It gets me where I need. But more importantly gets me out. I also don't have to deal with diff drop. Panhard. Brake line. I am fine being lame.
    Careful. I may go camping Saturday... :eek:
    just kidding.
    TBuzz likes this.
  18. Mar 9, 2016 at 11:48 AM
    #9838
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    proper angles& travel > Height
  19. Mar 9, 2016 at 11:49 AM
    #9839
    mr optimist
    mr optimist Mr Lazy
    Sam
    Alamosa, CO
    I will build a buggy or something down the road if I want to look cool. Haha
  20. Mar 9, 2016 at 11:51 AM
    #9840
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    It is all about how you use your vehicle and the driver is more important than any lift. These rigs are so capable with no lift w/ the e-locker anyway.
