TW's active 4runner builders BS thread
Discussion in '4Runners' started by ramonortiz55, Jul 21, 2015.
  1. Apr 27, 2016 at 10:26 PM
    kyle11863
    kyle11863 King of the BS
    Kyle
    Big Bear, CA
    1990 Toyota 4Runner SR5 V6 4x4
    Doug Thorley long tube headers and lots of mud
    Blah blah blah. You all forget, if they were as bad as you guys pretend they are, the 4runner line would've died long ago
    Fenwick1993 likes this.
  2. Apr 27, 2016 at 10:39 PM
    4Running Daily
    4Running Daily Long Live ZS
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    They were selling like hot cakes when they came out, the big issues arose years later. My statement is an opinion based on April 27th, 2016
    The early 3rd gens suck too in my opinion.
    Fenwick1993 and dtaco06 like this.
  3. Apr 27, 2016 at 10:45 PM
    kyle11863
    Kyle
    Big Bear, CA
    True. Still if they were so bad they wouldn't still have a following. Also out of everyone in here with a 2nd gen, only 3 are broken, and all 3 were not properly maintained. Can't speak for @Fenwick1993, but I know mines got 260k+ on the clock. Not the worst stats
  4. Apr 27, 2016 at 10:52 PM
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    Don't worry, I still have you beat on head gaskets. I blew the first set at 150k. The second set at 160k and 2 warped heads. And finally it started drinking coolant at 176k and I said fuck this motor. I started bouncing it off the rev limiter before every shift before it finally shot a rod out the side of the block.
  5. Apr 27, 2016 at 10:53 PM
    SixthSnail
    SixthSnail I have no idea what I'm doing
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    Billy is a cool guy. Built my front bumper on my tacoma a while back.
    ninjastar808 likes this.
  6. Apr 27, 2016 at 10:53 PM
    kyle11863
    Kyle
    Big Bear, CA
    Damnnnn that's a lot. Was this in AZ?
  7. Apr 27, 2016 at 10:57 PM
    RedRunner87
    RedRunner87 Mall Crawler LVL Expert
    Vince
    The Springs, CO
    16 4Runner SR5
    255/80 Falken Wildpeak AT3W
    What's wrong with the early third gens?
  8. Apr 27, 2016 at 11:03 PM
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    No this was in San Diego a long time ago. I have 30k miles on the 1999 3.4l motor I had swapped in.
    Supposedly the 1996-1998 are more likely to blow head gaskets
  9. Apr 27, 2016 at 11:08 PM
    kyle11863
    Kyle
    Big Bear, CA
    Hmm I wonder if its similar to the 2nd gens issue. Explains shy I see the newer 3rd gens more often. I'm kinda proud of mine though. I don't think it would've blown if I didn't try to go to AZ with it in that heat. Oh well. Too late now
  10. Apr 27, 2016 at 11:13 PM
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    Interesting. Mine is going strong so far.
  11. Apr 27, 2016 at 11:15 PM
    kyle11863
    Kyle
    Big Bear, CA
    I think I might have a theory as to why
  12. Apr 27, 2016 at 11:17 PM
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    Why is that?
  13. Apr 27, 2016 at 11:21 PM
    kyle11863
    Kyle
    Big Bear, CA
    The cold. Where I live in California it's colder than most of the state, which is part of why mine lasted for so long. San Diego doesn't get as hot as Arizona, but it still gets very hot, a lot hotter than the mountain parts of Colorado. No heat, no busted head gasket
  14. Apr 27, 2016 at 11:22 PM
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    That maybe true. But climbing these mountains will cause a lot of heat build up. We have long drawn out hills around here.
  15. Apr 27, 2016 at 11:26 PM
    kyle11863
    Kyle
    Big Bear, CA
    Mine drove up and down my mountain many times without issue. It was only after driving 170 miles through the desert that it got cooked
  16. Apr 28, 2016 at 1:14 AM
    tacot0wn
    tacot0wn Mia San Mia
    CO
    07 DCSB on 35s. Slowly becoming #EAF
    Don't know how i ended up lurking in the 4runner section...anyways, yes, i've got a DIY water filtration setup. Until I can figure out what kind of pump I want to use, it's a hand pump system. 25L raw/unfiltered reservoir, pre-filter attached to the end of the line, line goes through the cap, into a handpump backpacking filter, pumps it out into the back of another 25L container. I'll usually just fill the raw one from source when i set up camp and do the filtering as necessary. End game is to have a hose run from one of the other fittings on my raw tank and have the raw container be a vacuum with a pump on the clean side of it & I can pull right from source. If you have more questions and/or want pics just shoot me a PM.
  17. Apr 28, 2016 at 6:57 AM
    dannyk35
    dannyk35 Well-Known Member
    Danny
    Jackson, WI
    2013 Tacoma TRD OR, 2002 Tacoma TRD OR
    Well damn, thats quite a lack of fucks given. Lol
  18. Apr 28, 2016 at 7:59 AM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    Both of mine were over 300k before they went down. Then I got em.
  19. Apr 28, 2016 at 8:02 AM
    Fenwick1993
    Not Fenwick
    Chesapeake, VA
    I should also add that neither of them have blown head gaskets. I could easily get them running, they just wouldn't be quite up to my standards. They were ridden hard and not taken care of maintenance-wise.
  20. Apr 28, 2016 at 8:05 AM
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    That sounds like a @kyle11863 excuse...jk
