********* TXD 8005 5-channel Amp Install
Discussion in '3rd Gen. Tacomas (2016+)' started by Fenway4ever, Jul 3, 2020.
  1. Jul 3, 2020 at 6:53 PM
    Fenway4ever
    Fenway4ever [OP] New Member
    Pete
    2019 Toyota Tacoma TRD Sport Access Cab
    Has anyone installed a TXD 8005 5-channel amp? I ran the wiring harness tonight from the stock head unit and there are 2 wires I’m not sure I need and one seems to be missing. On the plug n play harness there are two stray wires (one yellow and one orangish red. The site says the yellow one is for constant memory and the orangish red wire is for accessory / switch. I’m not sure where to run these to the amp if at all since I think an amp only needs power and remote turn on. I’m thinking maybe they are for optional add-ons...? Also there is no remote turn on wire to the amp. Do I need to run one from the fuse box to the amp with an add a fuse? Any help is greatly appreciated!
