Types of undercoating for a Tacoma?
Discussion in 'Technical Chat' started by des kaiser, Jul 5, 2008.
  1. Jul 5, 2008 at 8:20 AM
    des kaiser
    des kaiser [OP] Member
    What's the best type of undercoating for an 01 Tacoma 4x4? I've been using the Rust Stop once a year oil treatment that costs about $100 for the past 3 years. I'm looking for something more permanent for use in high salt /snow areas. The frame on my 01 is showing early signs of severe corrosion despite proper care and if Toyota doesn't make it right, I want to at least TRY.
    What procedures do you suggest? Would they sand blast it first to remove the old rust? Won't it just rust through any coating? Opinions appreciated.
  2. Jul 5, 2008 at 9:26 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    On our hot rods here some of the shops use Por 15 (it is expensive) then you paint over it or get it Rhino lined or Line X. Maybe someone will give you some better info.
  3. Jul 14, 2008 at 9:32 AM
    shook0002
    shook0002 "The Fuzz"
    Joe
    Philly
    '08 Doublecab 4X4 SR5
    Toyota is buying back 1st generation trucks due to frame rust, and giving you 150% of blue book value. Apparently its pretty much a unsolvable problem due to the steel vendor for toyota. Theres been plenty of talk about it on here just search.
