Typically....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tmat, May 20, 2009.
  1. May 20, 2009 at 8:34 PM
    tmat
    tmat [OP] Well-Known Member
    Treavor
    Cypress, CA
    07 Regular Cab, PreRunner
    BHLM, de-badged, custom Manoukian flowmaster exhaust system, Bilstein 5100 front adjustable shocks set at 1.75", "smoked" foglights, Satoshi grille mod, 265/75r16 BFG T/A KO tires, AFE Pro Dry S air filter, solid rear window, Weathertech floor liners and painted grill surround
    Is it typical for somebody to get wheels and tires first or get the suspension done first? I'm torn, Both are going to cost roughly the same, so I don't know which to do first.
  2. May 20, 2009 at 8:44 PM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    What size tires do you want to run?
  3. May 20, 2009 at 8:49 PM
    tmat
    Treavor
    Cypress, CA
    Actually the suspension stuff is going to be a lot more. I just checked right now, about $1,000 more.
    I'm thinking of doing 265/75/16 BFG All Terrains. I have the stock 245/75/16 Dunlop tires
  4. May 20, 2009 at 9:00 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Personally I'd do both at the same time. If you're going bigger tires, you may need the lift first to accommodate them. However, it looks dorky to have a lift without the bigger tires, but you don't really have a choice.
  5. May 20, 2009 at 9:01 PM
    Kenny650
    Kenny650 Well-Known Member
    It's very typical to get the suspension done first. However, if you do that first without wheels and tires it will looks a bit funky. Don't try to mount the tires and wheels BEFORE the suspension lift though, it won't work.
  6. May 20, 2009 at 9:02 PM
    Ridingontrd
    Richard
    Laughlin,N.V
    If you haven't sean it yet,Drop down menu under mods&tutorials.Tire size calc.may help.You'd be going up 2 sizes.To fit you would need new rims w/a back spaceing less then 5.0".
  7. May 20, 2009 at 9:04 PM
    tmat
    Treavor
    Cypress, CA
    Got it, thanks guys. All my friends are telling me the same thing about the lift without the tires and how it'd look funny. I don't plan on lifting it too much though. I'm planning on getting the 2.5" King Coil overs with the TC UCA's and maybe the 2.0 smooth body King shock in the back. So, not much of a lift. Do you still think doing the tires first would be no bueno? Would the tires fit is what I should be asking...
  8. May 20, 2009 at 9:07 PM
    Ridingontrd
    Richard
    Laughlin,N.V
    Some trimming may be necessary around the wheel well.
  9. May 20, 2009 at 9:09 PM
    Ridingontrd
    Richard
    Laughlin,N.V
    After you drive it w/the Kings.....You wouldn't give a shit how it looks w/the stock tires.
  10. May 20, 2009 at 9:09 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    I can't really say for the reg cabs. They'd fit fine on a TRD blisten setup, but on the lower stocker suspension I'm sure there'd be some rub. Honestly I still vote hold out, save up and do both at the same time. That way you'll get the full transformation all in the same day or two and be able to really appreciate the change that much more. Otherwise, you'll be unhappy either way, and you don't want to risk damaging your new expensive tires or the truck when you don't have to with the lift.
    Just my $0.02
  11. May 20, 2009 at 9:11 PM
    tmat
    Treavor
    Cypress, CA
    I have the regular cab Prerunner though. It's on the 4x4 suspension...
  12. May 20, 2009 at 9:12 PM
    Ridingontrd
    Richard
    Laughlin,N.V
    Good choice on the Kings by the way.:woot:
  13. May 20, 2009 at 9:18 PM
    tmat
    Treavor
    Cypress, CA
    Yeuup. I heard they were the best.
  14. May 20, 2009 at 9:32 PM
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    Question... he wouldn't need any lift to just go from stock 245s to 265s right? Those tires would fit fine.. they aren't that much bigger?
  15. May 20, 2009 at 9:40 PM
    tmat
    Treavor
    Cypress, CA
    that's what I thought. I think people think I just have the base model 5 lugger. I have the Prerunner though 6 lugger.
  16. May 20, 2009 at 9:40 PM
    Ridingontrd
    Richard
    Laughlin,N.V
    You'll be fine.
  17. May 20, 2009 at 9:42 PM
    snowtaco
    snowtaco Well-Known Member
    Cali and Pa
    2006 single cab
    Replaced head unit, tint, blacked out tail lights, 10in sub, billet grill, 3 in front lift, led halo projector lights, camper shell.
    suspension first then tires if you go real tall you will look alittle off until you get the tires but if that is the case the tires you really want might not fit with out the lift
  18. May 20, 2009 at 9:47 PM
    tmat
    Treavor
    Cypress, CA
    decisions decisions
  19. May 20, 2009 at 9:52 PM
    Ridingontrd
    Richard
    Laughlin,N.V
    [​IMG] Here's a pic w/the stock tires. The front was set at 1.75 lift.
  20. May 20, 2009 at 9:54 PM
    snowtaco
    Cali and Pa
    2006 single cab
    lift if lift it haha
