U-bolt grade?
Discussion in 'Suspension' started by colinb17, Mar 15, 2010.
  1. Mar 15, 2010 at 4:01 PM
    colinb17
    colinb17 [OP] If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig...
    ordering the stuff for my rear lift tonight and ran into a question i couldn't seem to find the answer to. i know it's highlyrecomended to replace the ubolts when doing an AAL. but what grade bolt is used from the factory. toytec has grade 8s which i would would love to use becasue of the strength, but my autoparts store has grade 5 for $10 a set. if the factory uses grade 5, i'd be ok going with the autoparts stor ones, but will still contemplate the grade 8s. if toyota uses grade 8s stock i'll deffinately get the toytec grade 8s
    if you have a less expensive source for grade 8s, a link is of course welcome.:D
    thanks everyone,
    Colin
  2. Mar 15, 2010 at 4:20 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    anybody?
  3. Mar 15, 2010 at 5:58 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    9:00 bump
  4. Mar 15, 2010 at 6:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Im not sure what Grade the OEM U bolts are, but I would get the Grade 8 if not OEM.
  5. Mar 15, 2010 at 6:06 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    if they are long enough, do you think it would be a good idea to get another set from the dealership? that is if they aren't going to charge me out the ass for them.
  6. Mar 15, 2010 at 6:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The U bolts used for the TSB springs should be long enough.
  7. Mar 15, 2010 at 6:21 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    even though i have the tsb?
    i'll can out and check tomorrow...it's pooring rain and cold out right now :eek:
  8. Mar 15, 2010 at 6:23 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The OEM U bolts from the TSB springs fit my AAL just fine.
  9. Mar 15, 2010 at 6:29 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    That's good news, thanks Chris :)
