U Joint and Carrier Bearing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BizzyBone, Nov 1, 2022.
  1. Jan 24, 2023 at 8:16 AM
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    not familiar with spicer? wow, I'm surprised, they are one of the largest suppliers of joints, they are also a part of the DANA empire. Napa, Autozone, o'riley/car quest all should carry them.
    also buy an oem carrier bearing I got a cheap Amazon one for science and the bearing it self is fine but does rub/ squeak and I've adjusted heck, even went as much as to get the rear off the ground and put the truck in drive to see if it would self adjust, never changed and I've paint marker all over trying to make adjustments its getting replaced again shortly.
  2. Jan 24, 2023 at 1:28 PM
    VATACOMA39
    VATACOMA39 Member
    RICHMOND VA
    15 TACOMA DC
    I have thin line of grease splatter above the U joint mid-way underneath my 2015 Tacoma . Is this an indicator of a failing part ? I haven't experienced any squeaking but I have experienced some shudder under braking.
  3. Jan 24, 2023 at 2:21 PM
    reallifedog
    reallifedog wat.
    Jordan
    Denver
    08 Tacoma TRD OR
    not usually, that's generally a sign it was fully greased(maintenance) and threw the excess during driving. Whenever I run grease to parts with zerks, I pump grease until it shows fresh grease pushing out of the seals.
  4. Jun 13, 2023 at 5:42 AM
    babylon5
    babylon5 Well-Known Member
    David
    2015 Tacoma Double Cab TRD Sport
  5. Jun 13, 2023 at 6:17 AM
    Leomania
    Leomania Well-Known Member
    Leo
    2011 Tacoma TRD Sport DCLB v6 4x4
    All stock, baby!
    Yes, that’s correct. Until the transfer case actuator engages it, the front shaft is not spinning. The front u-joints should be unlikely to need replacement if you’re only using them occasionally and grease them every so often. Obviously, some people wheel hard and find they do need to be replaced.
  6. Jun 13, 2023 at 6:49 AM
    babylon5
    David
    Thanks for the confirmation. I do grease them at the same time as the rear ones and have always notices they take a lot less grease. And on a yearly basis i probably put on less than 100 miles in 4WD so they are indeed used infrequently.
  7. Jun 14, 2023 at 10:04 AM
    BigCountry762x39
    TL
    PNW, Oregon!
    yes. usually takes a small amount to get the fresh color up front on my 09, the backs I know are solid because I can always see a new line of goo slung up under my truck at each joint. on the back. but every oil change or anytime i take it out and beat on it a bit
  8. Oct 22, 2023 at 4:15 PM
    cloudbnd
    cloudbnd Well-Known Member
    Randy
    2008 silver DCSB 4X4 OFFROAD
    I had a vibration on my 08 Tacoma 4x4 V6. I replaced the carrier bearing and all 3 u-joints using Spicer products but I still have a vibration once I hit 50 MPH. Any suggestions would be much appreciated.
  9. Oct 22, 2023 at 7:57 PM
    Dacapster
    Dacapster Well-Known Member
    Hugh
    14 trd
    Many coming
    Just did my carrier bearing and u joints, take off vibe is back I did have to replace the aft yoke to the rear diff, so a D/S re balance is in order
    cloudbnd likes this.
