U joint question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Aerose91, May 5, 2018.
  1. May 5, 2018 at 6:14 PM
    Aerose91
    Aerose91 [OP] Well-Known Member
    Connecticut
    07 TRD Sport 4x4
    I'm having a nasty vibration so I'm going to just replace all 3 u joints on my driveshaft. I understand the process pretty well but have never done it on this truck. A few questions:
    When i disconnect the shaft from the rear diff and transfer case, are there any seals or anything that need to be replaced, and should i be prepared for gear oil to leak out?
    Do i just unbolt the carrier bearing from the frame and take it off with the shaft?
    Do new u joints need to be greased?
    -Muchos gracias
  2. May 5, 2018 at 6:15 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    4 x 9/16 or 14mm bolts on each end, 2 maybe 17mm bolts at the carrier bearing. No seals and No oil will come out. Yes get new u-joints and replace all 3, could also replace the carrier if you are so inclined.
    https://www.amazon.com/Spicer-5-1330-1X-U-Joint-Kit/dp/B00DOI8BDS
    https://www.amazon.com/dp/B00GAPFESW/
    MolonLabeTaco likes this.
  3. May 6, 2018 at 4:13 AM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    Is there a way to test if the carrier bearing is ok before taking it off the truck?
  4. May 6, 2018 at 4:46 AM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    To add to @Sandman614's post.
    Yes, you want to grease your new u-joints. They will have some assembly grease in the cups, but once they're installed, add your favorite grease with your trusty grease gun. You should be greasing all 5 u-joints every oil change or at least every other.
    I just replaced the u-joints on my Prerunner. The stock Prerunner u-joints don't have grease zerks. The new ones that I installed do, so hopefully I get another 100k+ miles out of them. If you don't have a u-joint press, I suggest picking one up. Some people say they've used a c-clamp and a couple of sockets, but I couldn't get enough leverage to move the u-joints with that setup when I tried.
    https://www.amazon.com/dp/B01N7CO50E/ref=cm_sw_r_cp_apa_i_RNU7AbQEHP3FB This is the one that I purchased, and it worked great.
    Doing the carrier bearing while the driveshaft out isn't a bad idea. You'll need a bearing puller to get the yoke and carrier bearing off.
  5. May 6, 2018 at 7:48 AM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    I was planning on renting a joint press. I'm wondering if i should just replace all 5 u joints at this point
  6. May 6, 2018 at 8:58 AM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    Rock Auto sells a Moog/Precision U joint for $8.70. That price seems stellar, would this one work? Or is the Spicer the way i should go
  7. May 6, 2018 at 9:02 AM
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    The OEM u-joints are Spicer if I'm not mistaken. I used AC Delco when I replaced mine. Moog typically makes quality products. Just make sure you're buying u-joints with grease zerks. They're available with and without.
  8. May 6, 2018 at 3:29 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    How often are you in 4wd? The fronts see many less miles, generally not needed at the same time as the rears.
  9. May 6, 2018 at 3:37 PM
    pmstoy10
    pmstoy10 Well-Known Member
    hudson valley, ny
    2010 Tacoma DCLB TRD Sport
    Weathertech Floor Liners, UWS Toolbox, Seatbelt Chime Mod, Coverking Covers, Window Guards, Wheeler's 1.5" Single Leaf AAL, Rear Spring TSB, Front Bilstein 5100's @ 2.5", Rear Extended Travel Bilstein 5100's, removed front mud flaps, Lifetime LED Headlights, Firestone RideRite Air Bags with Daystar Cradles, Light Racing UCA's, ECGS Front Diff Bushing
  10. May 6, 2018 at 4:48 PM
    jfoster92
    jfoster92 Well-Known Member
    Justin
    Farmerville, la
    08 Tacoma prerunner v6/manual
    Just replaced my carrier bearing and center joint today. All 14 mm bolts. Grease after installation and your good
  11. May 6, 2018 at 6:19 PM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    5% of the time, max. But i forgot to grease all my joints for about 20,000 miles so I'm concerned they still might be torched
  12. May 6, 2018 at 6:20 PM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
  13. May 6, 2018 at 6:22 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Unless you're in 4wd the front shaft doesnt spin.
  14. May 6, 2018 at 7:12 PM
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    Moog ain't what they used to be.
    Do it right or you'll be doing it again way sooner than you should have to.
    Sandman614 likes this.
  15. May 6, 2018 at 7:13 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Spicer
  16. May 6, 2018 at 7:17 PM
    Sandman614
    Tim
    '06 SR5 Off Road
  17. May 6, 2018 at 7:48 PM
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    I have a press which is great for trail or side of the road joint swaps. At home I tend to use a socket along with a big hammer (and sometimes a vice). I went to have a custom driveshaft made years back and all they use for transport truck joint swaps is socket and big hammer. Been doing it that way ever since. Have done dozens of joints this way.
    I get stuck doing the 6” joints w/ 3” cups at work because everyone else tries to be too gentle. Sledgehammer and an hour later they are ready to reinstall. It’s the shock from the hammer that is key.
  18. May 7, 2018 at 3:12 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Are you sure about that? I thought I read otherwise on here before. Not arguing, just wanting to know.
    Being that I change the diff fluids myself every 40,000 miles or so I would consider changing the front diff every other change if that’s the case, mainly because it’s a bigger PITA than the other two.
  19. May 7, 2018 at 4:30 AM
    Muddinfun
    Muddinfun Well-Known Member
    The driveshaft doesn't spin in 2wd, but the axle stubs and spider gears are spinning like a ground bloom flower in the 4th of July.
  20. May 7, 2018 at 4:46 AM
    Blockhead
    Pittsburgh, Pa.
    Ahh, interesting analogy...thanks! :oldglory:
    Muddinfun likes this.
