U-Joint slinging grease?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TnShooter, Feb 15, 2012.
  1. Feb 15, 2012 at 5:45 PM
    TnShooter
    TnShooter [OP] The TacomaWorld Stray
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I have a line of grease where the u-joints have slung the grease out.
    You can see some grease on the ujoints themselves.
    It's on the first u-joint closest to the transmission. And the one that is at the carrier bearing. The rear one doesn't seem near as bad.
    Could this be from over greasing the u-joint?
    I haven't ever greased them, but I think Toyota does when they change the oil?
    It's a 2007, V6, 4x4, Access-Cab, TRD -Off-Road
    Anyone else seen this happen?
  2. Feb 15, 2012 at 5:53 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    Could be if you did over grease them
  3. Feb 15, 2012 at 5:57 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    They do this after they are greased. The excess that is on the u joint slings off. Normal if you ask me.
  4. Feb 15, 2012 at 6:16 PM
    MattDriver
    MattDriver Member
    Guntersville, Alabama
    Tacoma TRD offroad dcsb 4x4
  5. Feb 15, 2012 at 6:29 PM
    badger
    badger Well-Known Member
    07 SR5
    It's normal to have some. When I grease mine I wipe away any excess I can see. Some mechanics are pretty sloppy with that and make a lot more mess than they should. If you never saw any it would mean the bearings had probably not been fully greased.
  6. Feb 15, 2012 at 7:08 PM
    TastyHuman
    TastyHuman Oh. Bummer.
    I had the center one do this and it was caused by the ball in the zerk fitting not sealing well so grease would leak back out after it was pumped in. Replaced the zerk and all is well.
  7. Feb 15, 2012 at 7:29 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    They aren't sealed so you can pump as much as you want into them.
    I pump mine until I see the burn crap stop and new mobil 1 shoot out of it
    when you done just take a rag and wipe the excess away. very simple and it will prolong their life.
    see all the mobil 1
  8. Feb 15, 2012 at 7:36 PM
    TnShooter
    Deogee
    STOCK
    This makes me feel better. Mine is not near as "bad" as yours.
    Not that "bad" is ummm, bad? in this case.
    It tells me at some point, it was greased.
    Thanks all.
