u-joint stuck behind knuckle
Discussion in 'Solid Axle Suspension' started by fireturk41, Nov 30, 2011.
  1. Nov 30, 2011 at 7:19 PM
    fireturk41
    fireturk41 [OP] I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    last time i went wheeling my u-joint on the half shaft of a jeep dana44 backed outa the caps, the caps have come out to the point where you can no longer slide the shaft outta the knuckle. ive tried pounding them in to no avail and im running outta ideas.
    i thought about grinding them out but the area is too small for a grinder, i might give the sawzall a shot tomorrow but i was just wondering if there were any ideas up here
    also tomorrow i finish wiring up my airlocker switch to a non arb compressor
  2. Dec 1, 2011 at 12:35 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
  3. Dec 1, 2011 at 6:40 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    Heat maybe, have you tried pirate4x4? Pictures would help. Only thing maybe is to pound the caps off instead of on?
  4. Dec 3, 2011 at 8:35 PM
    Stoffregen Motors
    Stoffregen Motors Active Member
    Cool, CA
    Torch or plasma cutter. It would be a last resort.
    Have you tried using a giant c-clamp?
  5. Dec 7, 2011 at 7:54 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
  6. Dec 8, 2011 at 8:38 AM
    Stoffregen Motors
    Cool, CA
    Good luck with the sawzall. Even the cheapest axle/u-joint material on the planet will eat a sawzall blade in less than a minute. If you had a plasma cutter you could cut the joint, or worst case scenario, the axle. If you use a torch, be careful, you could lose the heat treating in surrounding materials.
  7. Dec 27, 2011 at 7:21 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    finally got it out bent one pry bar and snapped another one and also bent my friends big ass c-clamp (mine didnt fit). the too me and a friend one pushing and the other pulling to finally get it
    i bent the ears bigger than the opening in the knuckle i guess
    now im saving up for chrome molly
  8. Dec 27, 2011 at 8:59 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Ball joint presses have a huge c-clamp that would work... Sorry I'm late.
