U Joint Zircs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sprig, Oct 21, 2020.
  1. Oct 21, 2020 at 8:10 AM
    Sprig
    Sprig [OP] Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    I have a 2009 4x4 - How many U Joint zircs are there? I greased them yesterday and only saw 3 zircs. I’ve heard there are 5 but I didn’t see them . Could someone clarify the number of zircs?
  2. Oct 21, 2020 at 8:15 AM
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    There are 5 zerks.
    2 on the front drive shaft and 3 on the rear.
  3. Oct 21, 2020 at 8:19 AM
    mikkydee
    mikkydee My Taco 2007 DCLB 4x4 Man Truck
    Doyle
    Florida
    2007 Silver DCLB Tacoma, 4X4, 4.0 Liter, 6" lift, 20" rims, 34" tires
    6" lift, 20 " inch rims, 34" tires, billet grill, aftermarket fender flares, custom rear bumper, DVd player with backup camera, all LED lights
    I recently did mine also. I believe 5 is the magic number. For 2 of them I had to use a needle dispenser because I could not get the greese gun on them without it. This is what I have. https://www.amazon.com/gp/product/B00H7LPKKU/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    It fits my lock and lube grease coupler. https://www.amazon.com/gp/product/B0779FK9CZ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    I don't think the two I had to use the needle dispenser for had ever been greased. The grease was so thick and hard it was very difficult to get new grease to feed into the the fitting.
    Crow Horse likes this.
  4. Oct 21, 2020 at 8:24 AM
    RedTaco68
    RedTaco68 Well-Known Member
    Pete
    WOOtown County, MA
    2013 Barcelona Red SR5 4x4 DCSB V6 6spd MT
    Millennial Anti-Theft Device (stick shift)
    The 2nd one back from the front is a pain in the @$$. Best approach is from the passenger side, and use a flexible hose with your grease gun.
    Sprig[OP] and mikkydee like this.
  5. Oct 21, 2020 at 8:45 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
  6. Oct 21, 2020 at 9:23 AM
    Sprig
    Ken
    Thanks all. Ya all are awesome
    RedTaco68 likes this.
  7. Oct 21, 2020 at 2:06 PM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    seems there is a guard to remove to easily get the front/rear 'zerk'
  8. Oct 21, 2020 at 2:20 PM
    mac84
    mac84 Well-Known Member
    Alabama
    2015 Tacoma TRD Sport 4WD MGM
    Please explain how the needle is used on the zerk. I have one but can’t figure out how to use it on the zerk.
  9. Oct 21, 2020 at 2:49 PM
    RedTaco68
    Pete
    WOOtown County, MA
    Mine was rusted beyond easy removal.
  10. Oct 21, 2020 at 2:49 PM
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
    Yeah. Just two bolts. Easy to remove, hit the grease fitting, and then reinstall.
    dk_crew likes this.
  11. Oct 21, 2020 at 2:54 PM
    ABNFDC
    Granite State
    The neat thing about occasionally greasing is the spray from the grease getting slung off the u joint helps deter rust.
  12. Oct 21, 2020 at 2:55 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    Ive considered buying that lock n lube thing, does it work good? reviews seem all over the place
  13. Oct 22, 2020 at 8:10 PM
    Sprig
    Ken
    On mine there are 3 zircs on the main drive shaft. They are on the outside of the u joints and super easy to lube. However there are 2 on the front drive shaft that are a sob pita to get too. Looked at them today and decided tomorrow would be a better day to attempt them. Sitting back with a glass of Buffalo Trace Kentucky Bourbon planning my assault on the 2 zincs.
    RedTaco68 and SWPA Tacoma like this.
  14. Oct 22, 2020 at 9:13 PM
    tamer
    tamer hamerworx.com
    NorCal
    2015 TRD OR AC, MGM, 4x4, 6spd MT
    I’ve never felt the need to use those fancy attachments. The one closest to the transfer case is easiest from the side if you pull the skid plate, 2 bolts.
    I’m able to grease all 5 easy while the oil is draining, clean up and finish the oil change.
    WebberLander and ABNFDC like this.
  15. Oct 23, 2020 at 5:49 AM
    RedTaco68
    Pete
    WOOtown County, MA
    Do you find the 2nd zerk on the rear of the front driveshaft to be difficult? It was a PITA; I bent a heat shield down and hit it from the passenger side. Curious how you do that one so easily.
  16. Oct 23, 2020 at 5:49 AM
    RedTaco68
    Pete
    WOOtown County, MA
    Please report back how you did on the front 2.
  17. Oct 23, 2020 at 7:11 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Besides the skid plate blocking access to the front DS, you may need to roll the truck a few inches forward/rearward so the zerks will come to an accessible position.
    A helper in the driver's seat is a nice addition for this task.
  18. Oct 23, 2020 at 7:54 AM
    tamer
    tamer hamerworx.com
    NorCal
    ^if you aren’t in 4wd you can actually spin the front shaft by hand.
    I just pull the little skid plate off, 2 bolts with the impact then I actually found getting it from the drivers side easier.
    ABNFDC likes this.
  19. Oct 23, 2020 at 8:08 AM
    ABNFDC
    Granite State
    The truck is light enough to just pop in neutral and push a couple inches to spin the rear shaft. And as already mentioned, that only applies to the rear. Just leave it in 2WD and spin the front driveshaft.
    In the OEM configuration, these trucks are cake to do basic maintenance on with the most basic tools. No fancy grease attachments or anything-just a regular old grease gun and a socket set.
  20. Oct 23, 2020 at 8:12 AM
    RedTaco68
    Pete
    WOOtown County, MA
    My shield had seized bolts. Argh.
