U Joints replaced?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 1nonlygarcia, May 22, 2016.
  1. May 22, 2016 at 7:31 PM
    1nonlygarcia
    1nonlygarcia [OP] Well-Known Member
    ceasar
    Lemoore CA
    06 Toyota Tacoma
    Pending prerunner long travel
    Quick question whats a good brand/website to buy U joints for a 2wd double cab 2006 toyota tacoma ? Any info will help. Local dealership is trying to charge me 798 to replace all ujoints.
  2. May 22, 2016 at 8:31 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I'd bet they are replacing the drive shaft, not just the u-joints.
    Any local parts house should be able to fix you up with u-joints. Or Rock Auto online.
    Blkvoodoo likes this.
  3. May 22, 2016 at 8:33 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Amazon
  4. May 22, 2016 at 8:33 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Factory would be best if not autozone and they give lifetime warranty. For that price you can just buy a cheap press and push them out and new one in. The tool you rent to pull them out sucks and Ive never had luck with them.
  5. May 22, 2016 at 8:34 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Factory is Spicer
  6. May 22, 2016 at 8:36 PM
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    You know I should have remembered that since I greased them a week ago.
  7. May 22, 2016 at 8:36 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Now that I've found good Spicer numbers there is no way I'll go back to anything else!
  8. May 22, 2016 at 8:37 PM
    thewarriordinghy
    thewarriordinghy General Lee's Titan
    Ben
    Georgia
    2017 Nissan Titan 4x4
    Temporarily Stock
    pulling out ujoints is easy, just need a certain sixed socket, a hammer, and needle nose pliars. as far as a ujoint, moog is pretty good.
  9. May 23, 2016 at 12:00 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
  10. May 23, 2016 at 12:48 AM
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    airrage likes this.
  11. May 23, 2016 at 1:54 AM
    airrage
    airrage Well-Known Member
    Myrtle Beach, SC
    2006 Tacoma Prerunner SR5 DCSB
    17X9 Gear Alloy Rims, BFG KO2's , Android Radio, 32" LED Light Bar in Bumper, LED Bed Lights,
    I did research on this when i needed to do mine, Get the Spicer with Zerk fitting to keep it greased atleast every oil change or more and stay away from Moog.
  12. May 23, 2016 at 11:26 AM
    adamax
    adamax Well-Known Member
    adam
    springville ut
    2015 trd off road
    If you have a six states in your area they sell spicer and usually install them for free if you buy there u-joints.
  13. May 23, 2016 at 4:51 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    $800 for all of them at a dealer is probably a bargain. I was 1800 miles from home last week when one went bad. I had to drive 80 miles to the closest dealer and it cost me $280 to get 1 replaced. The joint alone was $80, the rest was labor. I didn't have many other options.
  14. May 23, 2016 at 8:33 PM
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    Big girl panties, mini sledge and two sockets then hammer time
  15. May 23, 2016 at 10:31 PM
    1nonlygarcia
    ceasar
    Lemoore CA
    06 Toyota Tacoma
    I never asked if there were going to replace the drive shift either. All they quoted me for was the ujoints. I'm going to have to call tomorrow to double check. If it was only for u joints I'll just take everyone advice and changed them myself this weekend
  16. May 23, 2016 at 10:41 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I am saying the drive shaft as that is what Many on here have said that the dealers are only replacing the drive shaft as a unit instead of just replacing the universal joints.
    In my opinion 800 dollars is too much for universal joints. There are only three in the rear drive shaft. I would do it myself, just make sure to match mark everything so it goes back together the same as it came apart. I use a center punch to match mark as it will not rub off while handling.
  17. Jun 8, 2016 at 8:23 PM
    1nonlygarcia
    ceasar
    Lemoore CA
    06 Toyota Tacoma
    So update... It turns out it was only the rear ujoint that was worn/cracked. I bought a replacement at oreilly's. I didn't have the proper tools so took it to a local tire shop they replaced it and only charged me 70 bucks. No more clunk noises thank goodness. Thank for everyone input. :thumbsup:
  18. Jun 8, 2016 at 8:47 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Now make sure you keep them greased at every oil change.
    Go and sin no more.
    R0dzilla75 likes this.
  19. Jun 8, 2016 at 10:41 PM
    texascolt45
    texascolt45 Well-Known Member
    mike
    groves texas
    prerunner 4 cylinder
    wheels,bilsteins,side bars
    we have a local driveshaft shop that's been in business since the 70's.changed all 3 with spicer 530's and the carrier bearing I brought for 143.i hate u'joints.money well spent
  20. Jun 14, 2016 at 9:02 AM
    1nonlygarcia
    ceasar
    Lemoore CA
    06 Toyota Tacoma
    does anybody know a good website to buy hub/wheel bearings?
