U joints?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jsnm23, Feb 20, 2016.
  1. Feb 22, 2016 at 6:35 AM
    L J
    L J Well-Known Member
    Illinois
    07 4X4 SR5 TRD Sport DCLB
    Are you getting the Toyota OEM carrier bearing? I know that you can get Dorman etc for much cheaper but I couldn't confirm the quality so I got the Toyota part. If I could have figured out what the Spicer part number was I would have went that route. I paid about $60 more for some piece of mind. Bought it online from Camelback Toyota for around $150 after the TW discount and got free shipping. I have it sitting in a box with the ujoints waiting for my frame replacement to get done.
  2. Feb 22, 2016 at 10:53 AM
    327
    327 Well-Known Member
    Mark
    Covington, LA
    Former 06 TRD Sport Silver Current 06 Sport 4Runner
    I need mine done really bad. I'm afraid to drive it.
  3. Feb 22, 2016 at 9:57 PM
    jsnm23
    jsnm23 [OP] There are no solutions; only tradeoffs.
    2011 mgm TRD OR 4x4
    5100s @1.65 MB 352 wheels Debadged Cb radio Bhlm
    OK, so not too sure its ujoints anymore or the center carrier bearing. After driving my truck a little today I am now able to produce the clunk/rattle it gives me. While driving at ~40-45 mph if I let off the gas and then lightly feather the gas pedal from a coast @ around 1500 rpms the truck makes a audible and physical clunk for a half a second (feels like i hit a speed bump.) Not able to replicate the clunk at any other speed or rpm range.
    Possible tranny issue???:eek:
  4. Feb 22, 2016 at 10:42 PM
    Ahougland89
    Ahougland89 Well-Known Member
    Anthony
    Orting, Washington
    2007 Tacoma 4x4 6spd Manual
    3inch lift 33inch TOYO M/T
    My truck does a clunk as well its normal. Happens when you accelerate, start to coast when you let off the gas, then press on the gas to maintain speed there is always a little clunk with my 6spdMT
  5. Feb 22, 2016 at 10:53 PM
    jsnm23
    2011 mgm TRD OR 4x4
    This is not normal for my truck. It literally feels like I hit a speed bump
  6. Feb 22, 2016 at 10:55 PM
    jsnm23
    2011 mgm TRD OR 4x4
    This is my third Tacoma. None of them have done this. I'm just hoping its nothing serious because I love this truck
  7. Feb 23, 2016 at 1:54 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Well even if it is serious you can still repair it amirite?
  8. Feb 23, 2016 at 8:33 AM
    jsnm23
    2011 mgm TRD OR 4x4
    Everything can be fixed at a cost. Problem is I don't have a money tree on my property.
  9. Feb 23, 2016 at 8:59 AM
    Wolftaco0503
    Wolftaco0503 Well-Known Member
    Adam
    Chicago
    2013 Super White LONG BED TRD SPORT 4x4
    Maglite mod Bottle Opener in bed Weathertech Mats Front & Back
    Great movie
    CroResident likes this.
  10. Feb 23, 2016 at 10:15 AM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    Take out the drive shaft and go through avery joint and bearing feeling for roughness to narrow it down. I think timken makes toyotas carrier bearing
  11. Apr 3, 2016 at 7:42 PM
    beavis87
    beavis87 Well-Known Member
    El Paso
    '10 Silver TRD OR
    I bought an Anchor carrier support bearing. Looked alright. Also found out the hard way why not to get Moog 270 U-joints. They just were too wide and made installing them a PITA and actually got severely damaged. Not to mention the needle zerk fitting is junk. Not only with the needle adapter bend while pumping grease, but I couldn't get any grease into them.
    TacoTuesday!! likes this.
  12. Apr 3, 2016 at 7:46 PM
    3coma
    3coma my kid says my truck is "Boss"
    rob
    19 dcsb sport cement 4x4
    When you're a hammer everything looks like a nail.:D
  13. Apr 3, 2016 at 7:52 PM
    jsnm23
    2011 mgm TRD OR 4x4
    Figured it out. Wasn't a u joint or bearing. It was a cracked spark plug. Runs great again
  14. Apr 3, 2016 at 7:56 PM
    beavis87
    El Paso
    '10 Silver TRD OR
    I did everything as others have said to do them. I used a vice and two sockets. The problem with these was that one side would not seat into the center body all the way, it would just not go in any further. Thought if I put a washer wide as the bearing cup and thick enough to seat a snap ring that I could press in the other side. This was the result.
  15. Apr 3, 2016 at 10:21 PM
    #35
    Jimmyh
    SC
    2012 Prerunner SR5
    It looks like a needle bearing got loose preventing the cap from going all the way in. The end caps are cracked.
  16. Apr 5, 2016 at 6:35 PM
    #36
    beavis87
    El Paso
    '10 Silver TRD OR
    Yeah I thought that too so I pressed it back from the other side to see what was going on. First I used nothing to stop it from pushing out the other bearing cup back out (just the vice), then thought if I left snap ring in, it would allow pressed side to seat fully onto body, but all it did was squish the snap ring so tight you couldn't remove it, then I tried the washer idea and that happened. Inside of the bearing cups came pretty well greased and kept the needle bearings in there while pressing in the u-joint. I ordered 3 Spicer 5-1330-1X ujoints and plan to use a ball joint puller to remove and install u joints.
  17. Apr 5, 2016 at 7:46 PM
    #37
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    We used a press the other weekend with a piece of 1.5" tube and a socket. Made nice work of them
  18. Mar 12, 2018 at 1:18 PM
    #38
    super g
    super g Well-Known Member
    garrett
    north carolina
    09 trd off road with high hopes
    Afe stage 2 cai pro dry s, magna flow exhaust
    Does anyone happen to know the carrier bearing part number from spicer? About to replace all 3 u joints and figured might as well take care of that too.
  19. Mar 12, 2018 at 1:29 PM
    #39
    beavis87
    El Paso
    '10 Silver TRD OR
  20. Mar 12, 2018 at 2:30 PM
    #40
    devkurf
    devkurf Member at Large
    midwest
