UBolt spacers
Discussion in 'Suspension' started by SamSter0077, Oct 27, 2009.
  1. Oct 27, 2009 at 6:25 PM
    SamSter0077
    SamSter0077 [OP] Happy Camper
    Katy, TX
    09 Tacoma 4x4 TRD OR
    OME 886 Coils, and Struts, Rear Toytec TSB AAL/ OME shock absorbers, Fog Lamp anytime mod, Voyager Brake Controller.
    OK, just installed by TSB AAL, and the U-bolts are NOT long enough. I was able to seat the bolts without using the spacers that were already installed. I have to Tow 400+ miles this weekend, and will probably not be able to replace the Ubolts with longer ones.. do you think that would be a problem?
    Thanks,
    Sam
  2. Oct 27, 2009 at 6:29 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    By spacers you mean washers? I think you will be fine. Drive around a little first them tighten them up again.
  3. Oct 27, 2009 at 6:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If you dont have the bolts fully seated on the threads, its not a good idea to haul/tow anything. Or drive it.....You really need to get the correct size U bolts.
  4. Oct 27, 2009 at 6:36 PM
    aww1970
    aww1970 Well-Known Member
    2009 Tacoma TRD Long Box
    I have also heard from a few machanics that you should always replace the u bolts when you add a leaf regardless if the stock ones are long enough to re-use.
  5. Oct 27, 2009 at 6:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    True
  6. Oct 27, 2009 at 7:00 PM
    SamSter0077
    Katy, TX
    They are fully seated with slight thread above the top, but without Washers.
  7. Oct 27, 2009 at 7:02 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    I would go for it. But thats just me.
