Ubolts under torqued
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 4WD, Jun 1, 2012.
Are your U bolts tight ??
Poll closed Jul 1, 2012.
  1. Tight as they should be
    67.9%
  2. Loose as hell
    32.1%
  1. Jun 1, 2012 at 9:54 PM
    4WD
    4WD [OP] cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    As some of you know I spend a fair amount of time under Tacomas doing leaf springs, & they're mostly 2nd gens that have never had anything done to their springs till I get ahold of them, from '05 up to a couple 2012's. Now heres the problem, literally every one I've done have had U bolts that I swear could not have been tighter than 25-30 ft.lbs as I demonstrated to the last 2nd gen owner who has had nothing done rear spring wise, I took a standard 3/8" drive ratchet w/19mm socket & with 3 fingers on the ratchet gave a slight pull & it was loose on the U bolt spinning free.
    It has become obvious that they are rolling off the assembly line this way in my region of the country, not saying all Tacomas are like this but wherever they build them around my neck of the woods this has been the case. So what I'm asking you to do (if your bored or just want to prove me wrong) is for those with stock leafsprings & you know they've never been messed with, I implore you to throw a socket on yours & try to loosen (or tighten for that matter) posting up your results.
    I mean these are supposed to be around 90 ft lbs. IIRC , even if it was 50 it'd still take a good yank to break loose
    & again, I find it disturbing that they roll off assembly line this way
  2. Jun 1, 2012 at 9:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The FSM states that they be torqued to 37 ft.-lbs. I have talked at length about this to some Toyota Tecs., as well as shot a coupl emails to Toyota Corp (though they were un answered). The concensous is they should be torqued between 75# and 85#.
  3. Jun 1, 2012 at 10:03 PM
    dad32509
    dad32509 Thinking of something clever
    Dave
    San Diego
    Blacked out 05
    5100's front and back, OME 885x's, LR UCA's, OMD rear springs, Pioneer AVH-P2300DVD, HVAC Green led's MOD, Blacked out bumper, Plastidip emblems, custom front tube bumper, 32" combo led bar, rigid duallys, otrattw switches, my own Satoshi grille, shorty antenna, Spyder LED halo headlights. csjumper2003 map/dome, 3rd brake, DTRL white/amber and parking LED's. Pelfreybilt IFS skid, Cab mount chop, sliders and rear light bar w/blitzpro 5LR dust light. Uniden CB, Magnaflow 18" exhaust, Rear tire carrier, sway bar removed, spidertrax 1.25" spacers, Wheelers 16" Alloys w/265/75r16 Goodyear DuraTracs
    I can honestly say, mine were loose as hell. I went to Dougs to redo my leaf pack and the Ubolts werent even a problem to get off. If they were torqued, it was at 15lbs at the most
  4. Jun 1, 2012 at 10:05 PM
    4WD
    Doug
    2004 DC TRD 4x
    Well then my guess of 25-30 lbs is well, a pretty good guess, but I really have a problem with that , there is NO WAY IN HELL I would let any truck leave my place with U bolts torqued to 37 ft lbs regardless of what the manu. manual says personally
  5. Jun 1, 2012 at 10:06 PM
    4WD
    Doug
    2004 DC TRD 4x
    haha, no shit huh...:D
  6. Jun 1, 2012 at 10:09 PM
    4WD
    Doug
    2004 DC TRD 4x
    As a matter of fact I'd bet that at 37 lbs torque I could pry between the bottom leaf & the perch on axle & see day light, hard to believe Toyota is ok with that...
  7. Jun 1, 2012 at 10:22 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    When I got my '06 used in 2010 I re-torqued them. I went off the 90 ft lb spec in my old hilux haynes manual as both are 14mm u-bolts, and all moved, a lot. I almost crapped when I later read that the FSM for the taco says 37 ft-lbs, I agree, its not near enough. IMHO, either a typo or a first stage, and they forgot the second and possibly third stages of the torque procedure???
  8. Jun 1, 2012 at 10:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You wouldnt be able to pry them apart. Its still clamping force being applied. That being said, I stand firm in the thinking that under torqued U bolts are one reson behind most rear vibes after a lift install.
  9. Jun 1, 2012 at 10:31 PM
    4WD
    Doug
    2004 DC TRD 4x
    Agreed, I just couldn't let anyone roll out with that little of torque holding something together that is so important & def. would cause additional issues with vibes..
  10. Jun 1, 2012 at 10:39 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    The 37 ft lbs in the FSM has to be a typo
  11. Jun 1, 2012 at 10:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Which is the conclusion I came to. A friend of mine (Who at the time was a Toyota Master tec) confirmed the "37#" should have been 73#'s
  12. Jun 1, 2012 at 10:42 PM
    LAoffroadin
    LAoffroadin BURY ME WITH MY TACO!!
    Joshua
    Northwest
    2012 offroad 4x4
    ICON stage 5 coilers w/ ICON ucas, dakar leaf pack with Fox rears, k&n cai, LED cab light, raceline 16 inch wheels , toyo m/t 33",painted front yota emblem gloss white, retrofit headlights with mirrimoto 3 " lenses running the 6k headlights. Bhlm, bestopper, wet okole seat covers (max 4), weather tech mats,winch with piaa fogs. All pro apex front bumper. Sliders etc
    all that plus common sense would say that its probably better to ver tighten than under tighten...
  13. Jun 1, 2012 at 10:42 PM
    OZ-T
    Peter North
    British Columbia
    Yep
    Unfortunately , because this typo is in the FSM , it also surfaces in Haynes , Chilton , etc
  14. Jun 1, 2012 at 10:44 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Being as U bolts are a Torque to Yeild bolt, over tigtening them can have bad consequences.
  15. Jun 1, 2012 at 10:45 PM
    LAoffroadin
    Joshua
    Northwest
    2012 offroad 4x4
    yes but on this forum the question is "tight as they should be or loose as hell"
  16. Jun 1, 2012 at 10:48 PM
    OZ-T
    Peter North
    British Columbia
    that's more of a statement than a question
  17. Jun 1, 2012 at 10:50 PM
    LAoffroadin
    Joshua
    Northwest
    2012 offroad 4x4
    :facepalm::facepalm::facepalm: you get the point...
  18. Jun 1, 2012 at 10:50 PM
    OZ-T
    Peter North
    British Columbia
    actually kinda maybe no
  19. Jun 1, 2012 at 10:51 PM
    4WD
    Doug
    2004 DC TRD 4x
    Yep, they'll thread stretch just fine on their own
    true, now the whole damned thing is subject for debate as to whats "tight as it should be" or "loose as hell"
    For what its worth if I can , with 3 fingers & no effort spin these nuts loose (as the way its been) This falls into the "Loose as hell" area IMO..
  20. Jun 1, 2012 at 10:53 PM
    LAoffroadin
    Joshua
    Northwest
    2012 offroad 4x4
    well i would say that obviously thats TOO loose...
