Ubolts under torqued
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 4WD, Jun 1, 2012.
Are your U bolts tight ??
Poll closed Jul 1, 2012.
  1. Tight as they should be
    67.9%
  2. Loose as hell
    32.1%
  1. Mar 28, 2013 at 11:28 AM
    #181
    ouyin2000
    ouyin2000 Well-Known Member
    Nova Scotia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    *gremlin
  2. Mar 28, 2013 at 11:33 AM
    #182
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    :D
    Oh and your avatar looks like Nicholas Cage playing David Grahl.
  3. Mar 28, 2013 at 12:51 PM
    #183
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    IIRC about Toyota docs...
    it cannot be a typo of 37 or 73, because Toyota engineering calculates torque in newton meters...foot lbs is a translation. There would need to be dual concurrent mistakes for it to be a typo. 50.7 nm vs 98.97nm and 37 vs 73 ftlbs. The FSM shows both 37ftlbs and 50NM, and both are equal to 37ft. so, that is a lot of characters to excuse as a 'typo'. I don't buy it. intentional...
    this 37ftlbs is absolutely intentional, or the supposed typo (item 3 above) is on the engineering docs not the service docs.
    Now where in the HELL is Lagunito when we need his advice on torque ???? :D
  4. Mar 28, 2013 at 1:13 PM
    #184
    SpacemanSpiff
    SpacemanSpiff Well-Known Member
    James
    08 TRD Off-road
    Now 127 makes a great point...so the real question, if it is not an error then is 37 ft/lbs the correct torque? :goingcrazy:
  5. Mar 28, 2013 at 1:53 PM
    #185
    dusman
    dusman Well-Known Member
    Dustin
    Windsor, Maine
    2017 TRD ORDC MGM
    checked my on 2012 and couldn't move them but maybe a hair full force on a 3/8 wrench, don't have a torque wrench to see when it would give, but tighter than I can move has to move more than 37lbs
  6. Mar 28, 2013 at 2:04 PM
    #186
    nat
    nat Well-Known Member
    South San Francisco Bay Area
    2007 DC SB Tacoma
    Bestop, MP3 Aux Input
    Typically, torque is a function of the fastener size and whether there is lube involved or not. Dry torque is higher than lubed torque.
    Torque the U-bolts to 75-80 and forget about them.
  7. Mar 28, 2013 at 3:59 PM
    #187
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    HOLY CRAP !
    Ok, I have a 2013 turd or, and also have the 15-25 tsb vibe
    I was planning on getting the tsb done
    NO MORE !
    torqued 50, they all were far looser
    torqued 80
    NO MORE VIBE ISSUES* !
    *OK...so I still admit there is barely a whisper of a vibe but
    I really have to hammer to feel it. Drive like a dick level. I can now pretty much
    blast around all sporty-driving-like and NO MORE VIBE 15-25 (or any speed).
    learned:
    a) Toyota spec must be an error, I mean damn !
    b) those who get the tsb done and then say 'only made it worse'
    all I can figure is they put torque to 37, which is freaking wrong in my book
  8. Mar 28, 2013 at 5:28 PM
    #188
    4WD
    4WD [OP] cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    good to hear erik, i know its not 37lbs.....:p:)
  9. Mar 28, 2013 at 5:37 PM
    #189
    Agro
    Agro Well-Known Member
    San Diego
    2015 Ford F-150 XLT 3.5L Ecoboost!
    Honestly I figured you all must have bunk tacos :). I was figuring my 2013 was solid, no need to check.
    So I did just now before heading out. Many nuts were less than 40ftlbs. I set em all to 70. Plus or minus a little with variances.
  10. Mar 28, 2013 at 8:27 PM
    #190
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    It certainly doesn't hurt to tighten them to 73 -- I tightened them on my 2012 within 2 weeks of owning it and took some pretty rough Colorado trails without losing the axle.
    37 doesn't seem right, but most owners have no clue and there is no recall, so I have to assume that 37 is enough to work.
  11. Mar 28, 2013 at 8:49 PM
    #191
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
  12. Mar 28, 2013 at 9:34 PM
    #192
    4WD
    Doug
    2004 DC TRD 4x
    Well, considering that 1st gens are spec'd for 90ftlbs, theres nothing magical or special about 2nd gen Ubolts (they're the same as 1st gens., swapped out many times)
    You guys need a refresher....
    http://www.youtube.com/watch?feature=player_embedded&v=X8Sg8dCtXnI#t=3s
    NO WAY IN HELL IS THIS TIGHT ENOUGH !!;)
    Especially to hold a moving,flexing, 400lb + axle assembly (not counting tires/wheels)
  13. Mar 29, 2013 at 4:56 AM
    #193
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    all I can imagine is 37 softens the ride a bit ? to satisfy those who want
    a truck to drive more like a car. (most of the market)
    I swear the arse is a bit firmer at 80...
    anyhow, the annoying vibe is fixed
  14. Mar 29, 2013 at 5:55 AM
    #194
    aaronbuell
    aaronbuell Well-Known Member
    aaron
    windsor NY
    09 TRD/OR Access Cab V6 debadged
    Fog-light anytime mod, ,black grill,URD short throw,TRD decals removed ,debadged,black rear bumper, homemade tire carrier,TreadWright tires,Evo mod,removed rear headrests and seats,ABS kill switch mod,black center caps,Clarion CX501 head unit,Relentless hood brackets with floodlights.
    I pulled one u-bolt off yesterday to get longer ones made for my new springs and could not believe how easy it came off.
  15. Mar 29, 2013 at 9:46 AM
    #195
    4WD
    Doug
    2004 DC TRD 4x
    I pray you're kidding....
    & glad you tightened things up...
  16. Mar 29, 2013 at 10:05 AM
    #196
    rtn1911
    rtn1911 Well-Known Member
    Richard
    CA
    2013 MGM 4x4
    This morning my service writer confirmed that the torque spec for the u-bolts is 37 ft-lbf.
    He pulled up an online version of the FSM for my 2013 Tacoma and printed out the 4-page section on rear leaf spring installation, where the torque spec is listed in two different places.
    Intuitively, 37 ft-lbf is too light for the u-bolts, and 90 (+/-) ft-lbf seems reasonable and ties with the spec for earlier models. Then again, I find it hard to believe that a typo of this magnitude could survive for years without being corrected. Strange.
  17. Mar 29, 2013 at 10:11 AM
    #197
    4WD
    Doug
    2004 DC TRD 4x
    I find it harder to believe that someones axle hasn't went bouncing down the road somewhere....
    & this isn't directed at you but I don't give 2 shits about what Toyota has to say on this about there product, anyone who thinks that 37 ftlbs is enough, is a fool in my book & no way would I let them have a wrench in their hands on anything I own or was working on...
  18. Mar 29, 2013 at 10:35 AM
    #198
    rtn1911
    Richard
    CA
    2013 MGM 4x4
    Yeah, I agree with you on both points. Then again, it makes zero sense that this is a mistake that hasn't been corrected. So, the question is "WHY"? It doesn't really matter on a practical level, but it just makes me wonder what's going on.
  19. Mar 29, 2013 at 10:42 AM
    #199
    KingKoda
    KingKoda Never Satisfied
    Palmetto
    '12 TRD.S DCSB 4x4
    Boosted TRD/URD All Terrain Sleeper w/ Sockmonkey Decals Worth +666HP
    I agree with them seeming too low at 37 ft.lbs and that Toyota had this in their fsm for sometime without the need/desire to change it. However, I have mine torqued down around 85-90 ft.lbs, but I've added an AAL and went with that info for install.
    Any info on what other manufactures have for their u bolt torque specs?
  20. Mar 29, 2013 at 10:49 AM
    #200
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    umm....
