Ubolts under torqued
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 4WD, Jun 1, 2012.
Are your U bolts tight ??
Poll closed Jul 1, 2012.
  1. Tight as they should be
    67.9%
  2. Loose as hell
    32.1%
  1. Mar 29, 2013 at 10:51 AM
    #201
    nat
    nat Well-Known Member
    South San Francisco Bay Area
    2007 DC SB Tacoma
    Bestop, MP3 Aux Input
    That isn't how suspension works.
  2. Mar 29, 2013 at 10:58 AM
    #202
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    AFAIK the leafs will crack at the centering pin hole (which isn't immediately catastrophic) well before the U-bolt fails in fatigue. However, we haven't seen many cracked leafs, either.
  3. Mar 29, 2013 at 11:03 AM
    #203
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    Noooooo seriously....
    when i cranked mine to 80 I -think- it feels firmer
    so i was just tossing that out there...do looser ubolts compress
    the leak pack together a little less, and allow more freedom of the
    leafs under certain conditions ? therefore a plusher ride ?
    I swear it feels a bit firmer...that... or I am just feeling what
    normal is without a vibe.
    so i was thinking..hmmm maybe toyota specs 37 because of this ?
    why else would they spec 37 ? it isn't like the ubolts aren't beef enough
    to get them 'gutentite' at the factory
    anyhow, to some extent i think ubolts do compress the leafs and make
    them a bit firmer between themselves....
    anyhow, I am familiar with IRS, but not leafs....
  4. Mar 29, 2013 at 11:36 AM
    #204
    4WD
    4WD [OP] cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    I'm not talking about the Ubolt failing & snapping, I'm talking about them working themselves loose enough to gap right off the bump stop, if this happens (& it has before I'm sure) at highway speed you're just 1 or 2 good bumps from separating the springs from the spring perch on top of axle, rear shocks aren't going to stop it from happening, I've sheared axle pins before on full sized trucks & it gets weird & wacky in a heartbeat.
    If separation occurs, the only thing connecting the axle to the rest of the truck is lower rear shocks/mount & the brakelines , which make lousy limit straps, needless to say with that kind of weight & inertia those things would snap like twigs...
    & also , someone give me the rational behind going from 90 ftlbs (1st gen.) which is reasonable, to the 37 ftlbs. spec'd for 2nd gens. anyway you slice it makes no sense & I'm willing to bet that theres not a suspension shop in my area that would go along with the 37 ftlb thing either...WHY? For safety/liability..
  5. Mar 29, 2013 at 11:40 AM
    #205
    Large
    Large Red
    I'll have to take a pic. You can't get a socket on any of the u-bolts while the timbrens are installed. I think I'll have to remove the timbrens and torque the u-bolts, then reinstall them, I'm running the all pro u-bolt flip if it matters.
  6. Mar 29, 2013 at 11:45 AM
    #206
    Large
    Large Red
    Found one kinda..
    Hard to tell but there's hardly any room, I was installing my kings in this pic
  7. Mar 29, 2013 at 11:53 AM
    #207
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    you would prob be better off to just give me the timbrens that way you wont have to worry about the torque values on your ubolts anymore and will be sure to have plenty of access to double check them at any time.
  8. Mar 29, 2013 at 12:01 PM
    #208
    KJaikaran
    KJaikaran Well-Known Member
    Orlando FL
    2011 Tacoma DCSB TRD Sport
    URD intake/maf calibrator, Icon extended travel coilovers, Icon UCA, OME Dakar leaf packs, Bilstein extended rear shocks, 3 degree axle shims, Carrier bearing drop bracket, DS2 retro, 5k HID bulds top and bottom
    I have a question on possibly over torquing my u-bolts. I installed my OME leaf packs and had a set of custom u-bolts made up. I had them make them in a little beefier size at 9/16. I asked the guy what was the max torque they could handle and he told me 93 ft pound and i read on here one time that it should be torqued down a little tighter for the bigger size, so that what i torqued them too. SO, i'm wondering if i should back them off a little, or if its not a big deal.
    Prior to the OME leaf pack i was running a 1.5aal on my non TSB leaf pack that i honestly only hit with my impact gun when tightening the u-bolts and didn't actually torque them with my torque wrench, and ever since i installed the OME leaf packs with 3 degree axle shims i have had some serious axle wrap. I would assume its because of the higher angle of the drive shaft.
  9. Mar 29, 2013 at 12:10 PM
    #209
    4WD
    Doug
    2004 DC TRD 4x
    You're probably good on torque, & I don't know what it is with guys going right to axle shimming before they try dropping the carrier (not picking on you.:)) Is there something about the OME application that says you need to do this ?? I really don't know
  10. Mar 29, 2013 at 12:36 PM
    #210
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    depends on the material... http://www.autoandtrucksprings.com/pages/U-Bolt_Torque.html
  11. Mar 29, 2013 at 12:42 PM
    #211
    KJaikaran
    Orlando FL
    No problem, I actually did the carrier drop with the 1.5aal install. Added the axle shims for preventative measures when i was installing the OME pack, but guess it didn't help lol. Either way, i ordered a traction bar from bud built a few weeks ago so i can permanently get rid of it.
  12. Mar 29, 2013 at 12:43 PM
    #212
    KJaikaran
    Orlando FL
  13. Mar 29, 2013 at 12:56 PM
    #213
    nat
    2007 DC SB Tacoma
    There is a way u-joints are supposed to work together. The output shaft of the transfer case needs to be at the same angle as teh pinion shaft on the rear axle. That is not necessarily 3 degrees. Then the 2 piece drive shaft needs to be co-axial.
    Driveline mechanics 101
  14. Mar 29, 2013 at 1:01 PM
    #214
    rtn1911
    rtn1911 Well-Known Member
    Richard
    CA
    2013 MGM 4x4
    Steve Johnson at Southbay Driveline down the street from me did a good writeup on the topic. Probably s/b a sticky if it's not already:
    http://www.4x4wire.com/toyota/tech/driveline/
  15. Mar 29, 2013 at 1:18 PM
    #215
    4WD
    Doug
    2004 DC TRD 4x
    Thats not the same Steve Johnson that was part owner of Johnson's bug machine in Santee,Ca. is it ??
  16. Mar 29, 2013 at 1:55 PM
    #216
    rtn1911
    Richard
    CA
    2013 MGM 4x4
    Don't know. SBD's website says they've been in operation since 1998.
    http://www.sb-driveline.us/about.php
  17. Apr 23, 2013 at 11:58 AM
    #217
    Rufus
    Rufus Well-Known Member
    SoCal
    2010 TRD PreRunner Sport
    OEM Truck Bed Extender, Window Tint, Tailgate Security Mod, OEM Spare Tire Lock, Cam Locks (storage compartments), OEM Bed Mat, OEM Skid Plate, Stant 11504 Locking Gas Cap, TW Edrin55 OEM Running Boards, Pop & Lock w/Back-Up Cam, Black WeatherTechs, Red Line Quick Lift Plus Hood Struts, Wet Okole Front Seat Covers-black/charcoal with red & white TRD graphic & back seat pockets, DIY Satoshi Grillcraft & Old School Toyota Badge, TW ZonKs Black UWS Low Pro Truck Box, Rear Suspension TSB, 3M Scotch Guard Paint & Headlight Protection Film 8mm Urethane, Flyzeye V2 Wired Amber/White/Amber Interior LED Lights w/Silver Case, Sleek Looking Black LED Tail Lights from K2 Motors (Identical to OEM, but black).
    I had the TSB leafspring done a couple years ago. I recently noticed a slight shudder/vibe during acceleration from a standstill. So I decided to check the u-bolts. Driver side were torqued @ 37ft lbs., but he passenger side u-bolts were VERY loose. Maybe 15-20ft lbs max. Either the Toyota tech forgot to tighten them or they have worked themselves loose. I torqued them to 37ft lbs for the time being until I did further research on TW. The shudder/vibe is still there, but not really as noticeable like before. Gonna torque them to 75ft lbs. See if that eliminates shudder/vibe completely.
    Thanks cRaZy oLdmAn Doug for making us aware of this :cheers: :thumbsup:
  18. Apr 23, 2013 at 1:21 PM
    #218
    4WD
    Doug
    2004 DC TRD 4x
    No problem Rufus , love your sig...:)
  19. May 20, 2013 at 6:10 PM
    #219
    Toytrd12
    Toytrd12 Member
    Frostburg Md
    2012 trd Offraod
    Stock
    I normally don't post on here but I felt the need for this .I crawled under my truck tonight to see what the Ubolts were torqued to, and if they were at 15ft lbs I would be lucky.My truck is a 2012 so apparently the 37ft lbs still applies to them, so I torqued it 75ft lbs. My truck had a really bad surge from reverse to drive a lot more than a normal automatic should have , but it's almost completely gone....YAY!!! .I don't know if it helped the shudder out any but I'm happy with just the little bit it did do.
  20. May 24, 2013 at 7:35 AM
    #220
    haider320
    haider320 Well-Known Member
    Roswell, NM
    2013 MGM Double Cab SR5 4x4
    I'm not going to read through 13 pages; but are the 13's experiancing loose U-bolts? Should I check mine this afternoon?
    EDIT: I lied. I just read the last few pages and some 13's do have this problem.
