Ubolts under torqued
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 4WD, Jun 1, 2012.
Are your U bolts tight ??
Poll closed Jul 1, 2012.
  1. Tight as they should be
    67.9%
  2. Loose as hell
    32.1%
  1. May 24, 2013 at 8:05 AM
    #221
    4WD
    4WD [OP] cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Well considering that Toyota is still using crappy springs it'd prolly be a safe bet that the same limp wristed torquers are on the assembly line...:D
  2. May 24, 2013 at 8:07 AM
    #222
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    If you're in doubt I don't know why you wouldn't take the 10 mins to check them and be safe.
  3. May 24, 2013 at 3:44 PM
    #223
    haider320
    haider320 Well-Known Member
    Roswell, NM
    2013 MGM Double Cab SR5 4x4
    I don't have a torque wrench so I used a wrench. Mine were not very tight. I could get a half turn before they were really tight. I gave them a good tight snug. I'm assuming mine were at 37 ft-lb since I was able to get 1/2 turn out of the bolts before it was tight.
  4. May 25, 2013 at 7:48 AM
    #224
    D1EHARD
    D1EHARD Got the Fever
    Bama
    2017 DCSB Silver TRD Offroad
    Just wanted to add my experience. In stock form on my 2012, I had a small vibe in the 40-60 area. Then I threw on a 2.5" leveling kit up front to clear my 285's. The vibe increased. I purchased a tapered 1" block for the rear and at the same time saw this thread. So sure enough, when I went to take my u-bolts off, they were loose. So I throw in the lift block and tightened them sob's down to 85#. Go for a test ride and it is smooth as silk all the way up to 80 mph.
    So from my experience, tightening the u-bolts to 85# removed my driveline vibe. Even on a lifted truck (which is said to increase vibes).
    I voted "Tight as they should be" but I misread the poll. I should have voted "loose". Mine were indeed too loose.
    Thanks for the head's up OP.
  5. May 27, 2013 at 3:28 PM
    #225
    4WD
    Doug
    2004 DC TRD 4x
    I still stand on my position , no way do I buy the 37ftlb. torque thing being right, Toyota still uses crap for springs...
    For reference: 1st gen Tacomas are spec'd for 90 ftlbs. on Ubolts...
    2nd gens are spec'd for 37 ftlbs.
    Why the huge diff. in numbers ? Rationalize this to me & maybe I'll at least listen to Toyota's explanation...
  6. May 27, 2013 at 6:15 PM
    #226
    rtn1911
    rtn1911 Well-Known Member
    Richard
    CA
    2013 MGM 4x4
    It's strange that Toyota specs 37 lb ft for this part. And when I checked mine a couple of months ago, sure enough, they were not very tight. The spec seems unreasonable to me, so I tightened them up.
  7. May 28, 2013 at 6:54 AM
    #227
    Chadillac
    Chadillac Active Member
    Tri-Cities, WA
    12 TRD OR
    It wouldn't be the first time Toyota did this. Look up the head gasket problems on the 3rd gen Supra because of under torqued bolts.
    I found mine were extremely loose as well. I tightened them up to 90 ft-lbs.
    Thanks OP.
  8. May 28, 2013 at 6:41 PM
    #228
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    4WD,
    I put some Dakars on and was rechecking torque tonight after about 60 miles.
    I followed the FSM but used 85 ft/lbs on the u-bolts. FSM says, torque in the air, which I did.
    Checking tonight, with vehicle on the ground, u-bolts were "loose". Took them back up to 85 ft/lbs.
    What gives?
    Imagine this procedure being followed with 37 ft/lbs...
  9. May 28, 2013 at 9:24 PM
    #229
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    All suspension components should be re-checked after 200 miles or so. I also, personally, tighten once on the ground.
  10. May 28, 2013 at 9:30 PM
    #230
    4WD
    Doug
    2004 DC TRD 4x
    Why in hell would they say this is beyond me & wonder what they meant by "in the air".. I tighten Ubolts in "real world" situation, on ground with all vehicle weight on axle...:notsure:
    I think its time to shitcan the FSM if these are the best recommendations they can come up with
  11. May 28, 2013 at 10:01 PM
    #231
    Monster1
    Monster1 Well-Known Member
    San Antonio, Texas
    2012 Texas Edition DC Tacoma 4WD
    Weathertech digitals front and rear, TRD exhaust, Coverking dash mat, Oem Tacoma bedmat, Better Built tool box, bed extender, Toytec 1 1/2" AAL, Bilsteins front and rears, fronts set at .85, K&N filter, aluminum skid plate, EGR vent shades, locking tailgate handle, TRD emblems, Cal Trend seat covers front and back.
    I torqued mine to 75 Ft-lbs with Toytec AAL's installed, is that tight enough, what does everyone think about this setting?
  12. May 28, 2013 at 10:06 PM
    #232
    4WD
    Doug
    2004 DC TRD 4x
    It makes you 38ftlbs smarter than anyone who thinks 37 ftlbs is enough....
    You'll be fine with that...;)
  13. May 29, 2013 at 9:31 AM
    #233
    4WD
    Doug
    2004 DC TRD 4x
    Damn, that works for me !...:thumbsup:
  14. Jun 17, 2013 at 7:21 PM
    #234
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    Finally got around to checkin' my U-Bolts, only to find the poll closed :confused:
    2010 A/C V6 Auto 4x4 23,000mi 3yrs+
    Broke nuts free w/2' Breaker Bar so I wouldn't be torquing a seizure.
    Broke loose 'bout 1/8 of a turn.
    All 8 immediately "clicked" upon tightening w/torque wrench set @ 73 ft/lb
    My vote: "Tight as they should be"
    CC
  15. Jun 17, 2013 at 7:33 PM
    #235
    JpAdct
    JpAdct Well-Known Member
    PB County, FL
    2003 Tacoma ExtCab
    Did this remove your driveline vibrations at all?
  16. Jun 17, 2013 at 7:36 PM
    #236
    KalamaKid
    KalamaKid Well-Known Member
    Oregon
    same shit as everyone else
    Most of my U-bolt nuts were finger tight @10K a year after I bought the truck new...
  17. Jun 17, 2013 at 8:23 PM
    #237
    Cape Codder
    Jack
    Didn't really have much vibration, nor did I change anything.
    Suspension is stock.
    My U-Bolts were tight.
    CC
  18. Jun 17, 2013 at 10:09 PM
    #238
    4WD
    Doug
    2004 DC TRD 4x
    Wow, they were huh? Shit you'd be the first one then..:D
    I wouldn't put any faith in that poll, half the guys that said they were tight as should be , I know for a fact some of them had their suspension done before hand... But all I want is for everyones to be tight, so good job...:thumbsup::thumbsup:
  19. Jun 17, 2013 at 10:14 PM
    #239
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I was there when Dougy proved it to me. Was replacing the leafs on a guy with stock leafs, untouched...they weren't hand tight, but damn close...put a short socket wrench on one and a quick effortless tug had the nut spinning right off.
    Needless to say I went and double checked all my fittings lol
  20. Jun 17, 2013 at 10:23 PM
    #240
    KalamaKid
    Oregon
    I know it sounds anal but I re-torque all my suspension shit every time I change my oil. Including the drive shaft. Its a good practice and only takes 5 minutes. You can generally find a 20-150ft lb click type half inch drive from sears on sale for $40 every couple months.
