Ubolts under torqued
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 4WD, Jun 1, 2012.
Are your U bolts tight ??
Poll closed Jul 1, 2012.
  1. Tight as they should be
    67.9%
  2. Loose as hell
    32.1%
  1. Jun 1, 2012 at 11:04 PM
    kjmc
    kjmc Well-Known Member
    Kelly
    Alliston,Ontario,Canada
    2007 TRD-SR5 4x4 DCAB
    Truxedo Lo-pro-Qt Sirius Radio
    Toyota should fix all Tocoma springs, are they waiting for an other Campaign ? (RECALL)
    How much money have owners spent fixing this issue ? Save your receipt is what Toyota
    told me ! Should add Broken to the Poll Lol.
  2. Jun 1, 2012 at 11:17 PM
    6spd
    6spd Well-Known Member
    san diego
    2023 4x4
    I work in manufacturing. I'm no engineer, but I have fastened many a fastener in my time. I would say 37 ft/lbs would be a little under spec, as we tighten 1/2" bolts to roughly 55 ft/lbs. If you guys take into consideration, the total value of those four fasteners(of the u bolts holding down the leaves to the axle, to the plate) that is probably just about the right amount of clamping force to keep those things together, regardless of the conditions.
    remember, TOTAL clamping force. if it was one pair of u bolts, or one fastener, then I would definitely question that spec. otherwise, I think it is just about right.
    another thing to consider, is the yield strength of the fasteners, the nuts, and the u bolts. I'm sure the u bolts and nuts wouldnt be grade 8, as it is not holding down a lot of force(the leaves don't need a lot of clamping force, since the truck's weight is helping weigh down the leaves to the axle, and the centering pin for the leaves keep the leaves intact so no shifting fore or aft). even grade 5 hardware would be sufficient enough for this application.
  3. Jun 1, 2012 at 11:29 PM
    LAoffroadin
    LAoffroadin BURY ME WITH MY TACO!!
    Joshua
    Northwest
    2012 offroad 4x4
    ICON stage 5 coilers w/ ICON ucas, dakar leaf pack with Fox rears, k&n cai, LED cab light, raceline 16 inch wheels , toyo m/t 33",painted front yota emblem gloss white, retrofit headlights with mirrimoto 3 " lenses running the 6k headlights. Bhlm, bestopper, wet okole seat covers (max 4), weather tech mats,winch with piaa fogs. All pro apex front bumper. Sliders etc
    given that this 37lbs is a typo still... this makes me wonder if toyota engineers have it that way for a reason such as the force being pushed down onto the bols from the compression of the leafpack/ shock. allthough i am not engineer but i am quite a savvy mechanic... wiser fellows.. what you think?
  4. Jun 1, 2012 at 11:35 PM
    4WD
    4WD [OP] cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Yeah but you have to take into account that a 3500-4000 lb truck (give or take) with the dynamics of pushing/pulling force, G forces in corners, constant twisting/moving energy forced onto the axle/spring perch where they meet etc:
  5. Jun 1, 2012 at 11:39 PM
    LAoffroadin
    Joshua
    Northwest
    2012 offroad 4x4
    yes true but i duunnoo i dont see a multi billion dollar business making a mistake like that and not catching or changing it with all the discussion about it. there has to be something behind this...
  6. Jun 1, 2012 at 11:44 PM
    4WD
    Doug
    2004 DC TRD 4x
    But you wouldn't expect a major manufacturer to have the same TSB's year after production year either, but to each there own , theres still no fucking way I'd ever let a truck leave with that light of torque spec..
  7. Jun 1, 2012 at 11:47 PM
    LAoffroadin
    Joshua
    Northwest
    2012 offroad 4x4
    HMMM YOTA You isa be haven sum esplaninin ta du!!!! :notsure:
  8. Jun 1, 2012 at 11:49 PM
    6spd
    san diego
    2023 4x4
    I'm sure the dynamic movement is taken into consideration of the torque spec of the u bolts at the factory. I believe the g forces in corners, and twisting of the leaves would have a more shearing effect, rather than a pulling away effect of the fasteners.
    regarding the comment of toyota sending out vehicles with mcsteaks to the field, I see that all the time where I work at, and that is the reason why there are service centers(i.e. dealers) to pick up the slack of the discrepancies with the vehicles leaving the factory. they've made the money once we've taken delivery of a new vehicle.
  9. Jun 2, 2012 at 1:17 AM
    seric007
    seric007 Well-Known Member
    bttz, wrong. not related to rear vibes. when i did my AAL they got the GoodNTight torque spec. vibes like hell
  10. Jun 2, 2012 at 4:58 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Good and tight is not always equal and tight. I'd get a torque wrench and check those if I was you.
  11. Jun 2, 2012 at 5:28 AM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    This ^^
  12. Jun 2, 2012 at 7:18 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    This ^^^
  13. Jun 2, 2012 at 8:46 AM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    Doug,
    Thanks for the heads up warning. I just checked my U-bolt torgue setting and they were under 40lbs. I tightened them in sequence to 73 lbs.
    Back when the earth was forming and I was a strapping young lad, I worked at a semi-trailer axle assembly plant. We torqued the the U-bolts to 180 lbs. There was no power applied to these axles as they were simply under trailers. We were using 1 inch U-bolts.
    No, they were not stone wheels and axles, those were still being made on the other side of the plant.
  14. Jun 2, 2012 at 10:02 AM
    4WD
    Doug
    2004 DC TRD 4x
    Ya know rick I don't know if its a heads up or what, but I DO know that when I see nuts that are given the task of holding an axle assembly to the rest of the vehicle & they're not much more than hand tight, spec'd for it by manufacturer or not I get fucking nervous.. I just find it ridiculous that ANY automaker would deem fit a setting that low, now Chris4x4 said upon digging around that it was a typo in the manual & instead of 37 ft lbs. it was 73 ft lbs (which makes a hell of alot more sense) it seems they(Toyota) forgot to tell the guys on the assem. line I guess,, maybe the poll sound have asked "Do you think your Ubolts are tight enough?"..I dunno, I'll just keep them around 80 ft lbs like I have been just to cover my ass if nothing else.. I still have guys who's trucks I work on to come back in a week just so I can re check... so ....:notsure::notsure:
  15. Jun 2, 2012 at 10:28 AM
    #35
    wolftree
    Rick
    Ohio
    While I was under the truck, I should have checked the torque on the exhaust hangers. I expect they were torqued around 37 lbs as well. I agree, 37 lbs is not sufficient for holding a drive axle with multiple forces working on it. The wheel lug nuts get a higher torque setting.
    I found this at TTora, dated 23 Nov 2009.
    www.tacomaterritory.com/wiki/index.php/Torque_Specifications
    according to it, leaf spring U-bolts should be torqued to 90lbs. The rear differential drain plug has a torque of 36 lbs.
  16. Jun 2, 2012 at 11:52 AM
    #36
    6spd
    san diego
    2023 4x4
    good debate/discussion here that has brought some good info. cheers
  17. Jun 2, 2012 at 12:26 PM
    #37
    seric007
    they are ubolts, equal thread distance exposed on both sides. changing the torque 5lbs on 1 bolt isn't going to magically make drive shaft vibration disappear.
  18. Jun 2, 2012 at 1:04 PM
    #38
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    My driver's side was right; the passenger's side was dangerously loose. The rear bolt's nuts could almost be loosened without the ratchet. That one took about 4 1/2 revolutions per side to get to spec. Front u-bolt on the same side wasn't quite as bad, I'd estimate in the 35 ft-lb range.
    That rear axle slapped around so bad when it was loose I thought once it was going to separate from the truck on one particularly mistimed shift.
    Dangerous stuff, Toyota, dangerous... you can do better.
  19. Jun 2, 2012 at 1:45 PM
    #39
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Just becuase the threads may look the same, doesnt make the torque within 5#'s. I tried to see how accurate I was at turning nuts once, and out of 4 bolts, there was a 45# difference. Your elbow, no matter how calibrated you might think it is, cant tell the difference between 25#'s, and 50#'s
  20. Jun 2, 2012 at 1:54 PM
    #40
    4WD
    Doug
    2004 DC TRD 4x
    Exactly this reason why everyone should check & thank you for checking bro' ... you caught an unsafe condition & dealt with it hey it might have stayed that loose for your entire ownership & nothing would've come of it, .. or maybe you'd hit 1 pot hole too many & forced that loosened nut to run the thread on the U bolt stripping it on impact because it WAS loose just glad ya caught it , this thread ain't a who's right /whos wrong thing I just wanted to know how many are out there like the ones I've worked on, unfortunately they've all been 2nd gens, in fairness tho' even the 1st gens weren't quite up to specs, but not slightly above hand tight, they're not even nylocks, nor do they use lock washers either... I just want everyone to check their own just so You know your safe & I'm sure a few like yourself will be surprised with a few WTF's!! like you were.. just check them people please, shit maybe alot of axle wrap would be minimized (im sure it would)....just being safe
