Ubolts under torqued
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 4WD, Jun 1, 2012.
Are your U bolts tight ??
Poll closed Jul 1, 2012.
  1. Tight as they should be
    67.9%
  2. Loose as hell
    32.1%
  1. Mar 10, 2013 at 8:24 AM
    #161
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    No issues here. Won't you have to get longer u-bolts?
  2. Mar 10, 2013 at 8:28 AM
    #162
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Even 73 ft-lb is a bit low, considering 1st gens were spec'd for 90 ft-lb.
  3. Mar 10, 2013 at 10:19 AM
    #163
    NiceTaco
    NiceTaco Canadian Redneck
    Ontario, Canada
    2012 TRD Sport
    Aero Turbine 2525, Front bilstein 5100's @1.75, rear 5100's, 1" Toytec rear block, Devil Horns, BGF AT's, 18" Moto Metal 962's
    Yes, I have the longer bolts.... That's why I searches about this today and found this thread.. Among a bunch if other threads on this site and others.. Some are saying the do 37ft lbs and its fine...
    Is there not a specific spec based on diameter and grade of the bolts?
  4. Mar 10, 2013 at 10:51 AM
    #164
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    I just put in my rear lift with just a little over 3000mi on my truck. It felt pretty loose. Less than 40lbs.
    I wonder if they just feel loose because the U bolts stretched.
  5. Mar 11, 2013 at 3:48 AM
    #165
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    I look at it this way. Spark plugs are barely tight, and they are at 15. 37 is a little over twice that, which is still not very tight, especially for the axle.
    If I were you, I would do at least 80 with spacers.
  6. Mar 11, 2013 at 4:00 AM
    #166
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Damn, I checked the ones on the 05 since an AAL was used but not sure I checked the ones on the 08 since nothing has been done back there except swapping the rr shocks for the TRD ones. Maybe I did check and maybe not but seeing this thread is gonna make me check now...........
  7. Mar 11, 2013 at 9:57 AM
    #167
    NiceTaco
    Ontario, Canada
    2012 TRD Sport
    I just talked I toytec as i bought there block and ubolts and did a shitload of research online... The consensus seems to be on a 9/16 ubolt you should be 80-90 ft lbs...
    Toyota is f$&ked they don't fix anything 37... Ya 37 and there is no drive line issues with these trucks....
  8. Mar 11, 2013 at 10:12 AM
    #168
    4WD
    4WD [OP] cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Whenever I do installs I always show the owner how loose they are & usually they're shocked .. I've had a couple that weren't much tighter that hand tight..
  9. Mar 11, 2013 at 9:56 PM
    #169
    jarvis
    jarvis Well-Known Member
    Pahrump Nevada
    2003 Xtra Cab Prerunner
    Finally checked mine today. Wow-only 1 on each side clicked at 70 lbs. The others were pretty loose. Torqued all to 70. Thanks for the tip.
  10. Mar 27, 2013 at 8:52 PM
    #170
    payrow
    payrow Well-Known Member
    Los Santos
    '18 DCSB Sport
    I also hated the thunk my truck made - and with 36K miles it seemed to get worse so...
    Checked mine today, they were looose - probably 37lbs. I torqued them down to 90lbs crossed pattern.
    One question:
    My leaf springs did not line up perfectly, should they? Is this normal? They were shifted just a bit on both sides - actually the middle leaf was.
    Thanks everyone!
  11. Mar 27, 2013 at 10:40 PM
    #171
    4WD
    Doug
    2004 DC TRD 4x
    You can find a little deformity in all leafs but when obliviously out of alignment, chock the front wheels & get a high lift jack or similiar & raise the rear by way of bumper to take most the weight off springs (but don't raise off ground) Get a 2-4lb single jack (sledge hammer) & give'm a smack or 2 to line up, lower truck....done;)
  12. Mar 28, 2013 at 1:37 AM
    #172
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    ^^^ that is key... I pulled a stupid move and jacked mine up with no chocks and facing down hill.... As soon as the rear came up the truck decided to leave me. Once the rear tires hit the ground it still went ~3 feet.... :eek:
  13. Mar 28, 2013 at 8:00 AM
    #173
    SpacemanSpiff
    SpacemanSpiff Well-Known Member
    James
    08 TRD Off-road
    Has anyone searched the manufacturer's specs on the leaf springs ubolts? As far as I know, Toyota doesn't manufacture the leaf springs, correct?
  14. Mar 28, 2013 at 8:07 AM
    #174
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    is this a spring spec, axle spec, suspension spec ?
    I am wondering myself why 37 foot lbs. It is not a simple printing
    error as it is stated in lbs/ft, and newtons, and they are both equal to 37footlbs
    unless one engineering doc was misprinted, and that was translated
    to the manual.
    I have my handydandy torque wrench soaking outdoors as I speak [to come
    down to air temperature so I can calibrate it], and will wonk them all down
    to 85 and see what I get.
  15. Mar 28, 2013 at 8:17 AM
    #175
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Hey Doug finally crawled under my truck yesterday, installed my replacement leaf keepers and checked torque on my ubolts, still tight from the day we installed the leafs.
  16. Mar 28, 2013 at 9:50 AM
    #176
    nat
    nat Well-Known Member
    South San Francisco Bay Area
    2007 DC SB Tacoma
    Bestop, MP3 Aux Input
    There is a specific spec, I posted it a while back. The spec in the manual is a typo. Torque those fuckers down.
  17. Mar 28, 2013 at 10:00 AM
    #177
    Large
    Large Red
    Anyone with timbrens have a good way to torque these without removing the timbrens?
  18. Mar 28, 2013 at 10:17 AM
    #178
    TRDSport12
    TRDSport12 Member
    The Great North
    2012 DCLB TRD Sport BLK
    just checked mine, all of them on my 2012 were below 40lb. not anymore, thanks!!
  19. Mar 28, 2013 at 10:50 AM
    #179
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    A few possibilities.
    1. Typo, number transposed. 37, 73.
    2. Typo, hit wrong spot on keyboard. 37, 67.
    3. Looked at wrong column in table of design handbook. Suggested assembly torque for M14 or 9/16 is 37 ftlb for aluminum bolts. Suggested torque varies by grade of steel and whether it's coated.
    I did mine to 70 ftlb.
    Keep in mind that cheap torque wrenches might have low accuracy anyway. I've seen some rated at +\- 25% of range.
    Torque is important but "exact" values usually aren't. In the ballpark is good enough because truth is a lot of variables affect the correlation of torque to clamping force.
  20. Mar 28, 2013 at 11:21 AM
    #180
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    I just did mine; sure as shit, they were 'loose'.
    I'm the original owner, 85K, TSB springs installed at 5K
    Passenger side; one spun at 35, the others spun at 45.
    Driver side; all spun at 50.
    I tightened them all to 75.
    I definitely 'feel' a difference with the 'goblins'.
    Thanks for the heads up; one less goblin to hunt.
