UCA’s required ?
Discussion in 'AccuTune Offroad' started by 5465, Oct 4, 2020.
  1. Oct 4, 2020 at 8:46 AM
    5465 [OP] Well-Known Member
    South
    2023 TRD Ex Cab
    I’ve picked up another Tacoma and will lift this one like all the others and have installed most of the lift parts, etc..myself.
    I’m looking at the Fox setup from your website and it says, UCA’s required ? I know what aftermarket UCA’s are for (alignment camber) so why does it say Required ?
    Fox Shock Kit: 03-ON Toyota Tacoma 4wd & 2wd Prerunner W/ UCA, Front Coilover, 2.5 Series, IFP, 4.9″, 0-3″ Lift
    SKU: FOX-883-02-025
    Free Shipping On Orders Over $150
    Fox 2.5 shocks will take your off-road performance to the next level with better heat capacity and more controlled damping. *These coilover require an aftermarket upper control arm.
    PS, do members get discounts?
    Thanks
  2. Oct 5, 2020 at 8:04 AM
    AccuTune Offroad
    AccuTune Offroad Well-Known Member Vendor
    El Cajon, CA
    Upper control arms are required on those coilovers due to the shocks having more travel than stock. The 0-2" travel coilovers don't require an aftermarket upper control arm since they don't have as much shock travel.
    We do not offer discounts since we are providing an exceptional value at no additional cost. Accutune Savings
  3. Oct 5, 2020 at 8:26 AM
    South
    2023 TRD Ex Cab
    Yeah, I’ve read all that. But if the coilover is the same length with the ability to cycle more, how could it harm the coilover, if it only restricts that cycling to a shorter distance ?
    Not trying to be a pain, just want to understand the logic.
  4. Oct 5, 2020 at 8:33 AM
    kbp810
    kbp810 Well-Known Member
    Au Gres, MI
    2016 Tacoma TRD OR
    Because unless you are limit strapped accordingly, the limiting factor will be your ball joint. The ball joint will hit/bind when the extended travel coilover reaches full extension.
    AccuTune Offroad likes this.
  5. Oct 5, 2020 at 8:39 AM
    AccuTune Offroad
    El Cajon, CA
    This is a common thing for using longer travel shocks on the front of an IFS truck, not something unique to us. Plenty of threads on here that discuss this
    0-2" Coilovers have 4.540" shock travel.
    0-3" Coilovers have 4.890" shock travel.
    The coilovers are not the same length. At full droop the steering, ball joints etc. are being maxed out which effect alignment. Aftermarket upper control arm fix these issues and allow for better alignment.
  6. Oct 5, 2020 at 8:55 AM
    South
    2023 TRD Ex Cab
    So, if someone uses a 1/4” top spacer, it effectively has the same affect ?
  7. Oct 5, 2020 at 9:07 AM
    kbp810
    Au Gres, MI
    2016 Tacoma TRD OR
    Yes, with a 1/4" spacer it is possible that you could start pushing the limits of articulation of the stock ball joint.
  8. Oct 5, 2020 at 9:13 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    You could get the coilovers, then decide if you want ucas later. Good chances you will though.
  9. Oct 5, 2020 at 9:39 AM
    South
    2023 TRD Ex Cab
    I will get the UCA’s, because I want the caster set properly, no big deal. I’ve read so many of these topics about extended C/O’s, they all seem to give other information and warn about ball joints being stressed.
    But a 1/4” top spacer gives 1/2” more lift vs that 3/8’s of extra down travel from extended C/O’s.
    I would prefer to purchase from a company that actually works on the products they sell, that’s why I asked here.
    My past Toyota’s vehicles:
    1994 Toyota regular cab 2WD
    1997 Tacoma reg cab 4x4
    2000 Tacoma ext cab 4x4
    2004 Tacoma 4-door TRD 2WD
    2011 Tacoma Reg cab 4x4
    2012 Tacoma 4-door 4x4
    2015 Tacoma Reg cab 4x4
    2016 Tacoma ext cab 4x4
    2016 4runner 4x4
    2008 V8 4runner 4x4
    2019 Tacoma 4x4
    2021 Tacoma 4x4, my newest TOY.
    Every one of those were lifted, from torsion bar lift, spacers, drop bracket to coilovers.
    I’m done, thanks !
  10. Oct 5, 2020 at 9:43 AM
    AccuTune Offroad
    El Cajon, CA
