UCA Question- TC, SPC, Camburg
Discussion in 'Suspension' started by 2012TacomaGuy, Jun 12, 2019.
  1. Jun 12, 2019 at 10:21 PM
    2012TacomaGuy
    2012TacomaGuy [OP] Well-Known Member
    Hayden
    Goodyear AZ
    2012 Pyrite Mica DCSB TRD Sport
    Empty wallet
    Hey all,
    I was looking at getting some new UCAs for an upcoming 5100/OME 887 lift up front and narrowed down my search to Total Chaos UCA (uniball), SPC LR (balljoint) and Camburg (Moog balljoint). I wanted to stay away from uniball since I am currently in Colorado and deal with a lot of dirt, mud, salt, and wet conditions nearly everyday. First off, recommendations between these three? Camburgs and SPC are the exact same price with TC being around $200 more. Also, I noticed two different versions of the SPC LR UCAs? One was more of full stamped metal and the other was a mix of stamped and tubular. Are there different variations to SPC LR UCAs? If so, which style is newer/better? I also am going to be running 285/75/17 Nitto Ridge Grapplers on SCS Ray 10 17x8.5 -10 offset (if that matters at all for choice of UCA). Thanks!
    Style 1 SPC LR: https://www.headstrongoffroad.com/s...g)_Ball_Joint_Upper_Control_Arms_-_25470.html
    Style 2 SPC LR:
    https://www.summitracing.com/parts/...cqrRmtxTSovvUEV_BPXLHVIVO9d7_DwsaAr57EALw_wcB
    https://www.amazon.com/Specialty-Pr...6385&sr=8-4&keywords=tacoma+upper+control+arm
  2. Jun 13, 2019 at 10:03 AM
    TacoTron
    TacoTron Tacotronn
    Anthony
    Denver, CO
    07 Toyota Tacoma
    I would go with the SPCs since you're running 285/75/17. You're going to rub on the body mount but with the spcs you'll be able to pull the tires forward almost an inch away from the body mount plus its a closed system especially being in colorado its a plus. Stop by toytec lifts if you are local we are in Denver.
  3. Jun 13, 2019 at 10:13 AM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    My reasoning on going with Camburg ball joint UCA was to stick with a relatively common part.
    With the SPC arms you have a single source for ball joints. What happens if they change the design, run into a sourcing problem, go out of business? Probably unlikely but not with my luck.
    With the Camburg I feel more confident that I'll be able to find a spare part even if it takes buying a whole danged arm from Toyota (I kept my original ball joints for spares, too). Or if one breaks on a road trip all I need is a NAPA or O'Reilly's or worst case I might have to overnight one from Amazon.
    FWIW I debated about going with the JBA but at the time they were still dialing them in. They use a standard GM ball joint. At this point if I had it to do over I might go that way, although I can't say I don't like my Camburg. The poly bushings kind of suck when they start creaking but that's not Camburg's fault.
  4. Jun 13, 2019 at 10:15 AM
    DaveInDenver
    David
    Grand Junction
    Unexceptional
