UCA question
Discussion in 'Suspension' started by Masada, Oct 30, 2009.
  1. Oct 30, 2009 at 11:37 AM
    Masada
    Masada [OP] Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    I just put on my 5100's at 1.75" and may have to get new UCA's so I can get everything aligned. With that said, I really don't have the cash for Total Chaos or Cambrug uniball UCA's. So I found the CAMBURG BALL JOINT UPPER A-ARMS on their website and wondered if anyone had these? They run $399 from them or $379 from Wheelersoffroad.com.
    Will these help get my truck back into spec? Will I have a problem if I upgrade to new 265/75 tires?
    I really don't need any racing UCA's or anything, because I don't plan on wheeling my truck that hard. But I don't want to have alignment issues either. Someday I will get the long travel suspension kit, but not yet :D
    Here are the specs from Cambrug:
    ****Disclaimer****
    I did read the thread on lift's and everything and noticed it said the Cambrug does not help with alignment, but their website communicates otherwise so I am a bit confused. It sounds like these have gone through a revision of sorts.
  2. Oct 30, 2009 at 11:50 AM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
  3. Oct 30, 2009 at 12:00 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    With the Camburg UCA's you mention, you need to either re use your existing Ball joints, or buy new ones. With the LR UCA's, they come with ball joints.
  4. Oct 30, 2009 at 12:03 PM
    Masada
    Taylor
    Laveen, AZ
    yes at a substantial cost increase right? ****edit just went back and read that it does help with alignment...
    I'm ok with reusing the factory ball join, i think???
  5. Oct 30, 2009 at 12:05 PM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven, WV
    2021 Cement Grey Off Road
    Stock
    you shouldnt need new uca's if you just lifted it 1.75". are you having that much problems with alignment?
  6. Oct 30, 2009 at 12:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The LR UCA's do fix alignment issues.
    His specs are pretty bad right now. Hes taking his truck back to have them fix it, but I agree. 1.75" lift shouldnt affect them not getting it into specs.
  7. Oct 30, 2009 at 12:20 PM
    Masada
    Taylor
    Laveen, AZ
    That's more comforting to hear Chris thank :)
    And I went back and changed what I said, because I re-read the discription on wheelers. (my read kung fu is not so good today :D)
    just so we all know, here are my before and after specs on alignment.
    Before
    L >>>>>>>>>R
    0.9 camber 0.6
    1.6 Caster 1.7
    0.08 Toe -0.12
    After
    L >>>>>>>> R
    0.9 camber 0.6
    1.6 Caster 1.7
    0.08 Toe 0.07 <<<<<<<they only changed the Toe????
  8. Oct 30, 2009 at 12:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Take it back and have them make it right, or give your money back.
  9. Oct 30, 2009 at 12:22 PM
    gupster88
    Brett
    Almost Heaven, WV
    Stock
    who is doing your alignment?
  10. Oct 30, 2009 at 12:23 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Taylor......Call Shumans Auto clinic and have them do it. Get you money back from Big O.
  11. Oct 30, 2009 at 12:30 PM
    Masada
    Taylor
    Laveen, AZ
    I may have to do that, but I'm going to try a different Big O. I called one and the guy sounded really nice and was cool with me bringing it in to him. If they still can't get it right, I'll ask for my money back and go to Shumans. I probably should have done that in the first place, but I don't think they are open Saturdays...
    The Camburg UCA still intrigue me...at some point I may go taller on my lift and I will need them at that point.
  12. Oct 30, 2009 at 1:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah. But they dont do anything the LR UCA's dont. Plus the LR's have more range of adjustment.
  13. Oct 31, 2009 at 6:50 PM
    Masada
    Taylor
    Laveen, AZ
    So I took my truck off roading today and man was it a harsh ride...I'm starting to think about getting the OME 885 and setting the Billsteins to stock height for now. And in the futre raise them up some...
    Any thoughts on that?
  14. Oct 31, 2009 at 6:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    What are you set at on the shocks?
  15. Oct 31, 2009 at 7:03 PM
    DTacoms
    DTacoms Well-Known Member
    Frisco, Texas
    05 4x4 DC LB BSP
    Your caster is better than mine when I had 1.75" and no aftermarket UCA. I had less than 1.3 degrees. Firestone said it's max out but it's within specs.
    I heard that with a lift, you can't go up to 2 degrees, so I just lived with it. The truck drove fine by the way.
  16. Oct 31, 2009 at 7:10 PM
    Masada
    Taylor
    Laveen, AZ
    1.75"
    I'm thinking about putting them at stock hight and getting the OME 885.
    How high would that be of a lift in the front.
    Keep in mind I have the All pro bumper and skid plate...
  17. Oct 31, 2009 at 7:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah....the 885's may ride better. Whats the issue with the ride? Too stiff? Not dampened correctly/ not controlled?
  18. Oct 31, 2009 at 10:04 PM
    Masada
    Taylor
    Laveen, AZ
    I took it out to 7 springs today and it felt like I was driving over huge bumps every time I got up to speed on the dirt road. Way too stiff and uncomfortable, not like it was before the lift. Almost like I had not spring articulation at all...
    That's why I'm thinking the 885 with stock hight bilsteins...maybe a more smooth ride.
  19. Oct 31, 2009 at 10:12 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    You might be better off going with the 886's because of that AP bumper...
  20. Oct 31, 2009 at 10:17 PM
    Masada
    Taylor
    Laveen, AZ
    That's a good point, but the bumper only weighs about 120Lbs and the truck shed about 50 from the stock bumper. So I really only gained about 70ish Lbs, is that really enough to make the 885 sag?
    I'm just worried about the 886's because I've heard they are very stiff and harsh. That's what I'm trying to avoid by possible getting new springs.
