UCA"s questions
Discussion in 'Suspension' started by knotty, May 29, 2013.
  1. May 29, 2013 at 12:22 PM
    knotty
    knotty [OP] Well-Known Member
    milwaukie, oregon
    I know this may sound like a dumb question but i cant find a answer an i have been looking for hrs ... what is the benefits of doing uca apposed to stock ones ? what are the difference in the uca, ie. length, more adjustable??
    thanks for your time !
  2. May 29, 2013 at 12:32 PM
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    There isn't really any great benefit to them if you are running stock suspension. If you swap out your suspension to something that lifts the truck hence altering the geometry of your front end, a more adjustable uca will allow you to obtain better steering/wheel alignment. In addition, some uca's have less articulation than the stock version and are less likely to interfere with the tire size increases that typically come hand in hand with lifting
  3. May 29, 2013 at 12:44 PM
    knotty
    milwaukie, oregon
    ok well i am running 5100's and planning on going with ome 886 springs since i have an arb bumper and going to be throwing in a winch but i want to run 285's should i run uca also ?
  4. May 29, 2013 at 12:46 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Yes
  5. May 29, 2013 at 12:48 PM
    Hairy Taco
    North of Hell
    08 TRD
    I would if I were you, but this is a topic that has been debated endlessly on this site. Some guys are happy with their alignment on stock uca's, some aren't. I wasn't. I prefer my truck to track effortlessly when rolling down the highway.
  6. May 29, 2013 at 1:07 PM
    knotty
    milwaukie, oregon
    ok .. how do new uca make it track better ? are they adjustable ? where the stock ones are not ?
  7. May 29, 2013 at 1:10 PM
    Hairy Taco
    North of Hell
    08 TRD
    yes indeed. With the stock uca's, the tech will be forced to play and balance off the caster and camber as best as he can. With a uca such as SPC's light racing, the tech can set the toe and the camber to how he wants it then set the Camber from the uca. It allows you to get a perfect alignment.
    Your Caster will determine how well your truck tracks. When you lift the truck, the camber increases and caster decreases. It is important to regain the losses. The uca's help this
  8. May 29, 2013 at 1:12 PM
    TacoBurrito07
    TacoBurrito07 Well-Known Member
    Jake
    Arizona
    07 SWB Dbl cab TRD Sport 4x4
    I thought you couldnt run 5100s with the 886s?? only up to 885s??
  9. May 29, 2013 at 1:16 PM
    Hairy Taco
    North of Hell
    08 TRD
  10. May 29, 2013 at 1:21 PM
    knotty
    milwaukie, oregon
    well with the added weight with the arb bumper and winch and i want to get the 3 inch lift also im going to try it and see what happens!!! whats the worst that can happen ?
  11. May 29, 2013 at 1:28 PM
    OZ-T
    Peter North
    British Columbia
    Why not get the shocks that were designed to go with those coils ?
  12. May 29, 2013 at 1:29 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    you kill a family on the road when your suspension blows apart on the highway and you careen into a apposing lane.
    Don't worry no one will know that you could of cared less...after all this is just the web :rolleyes:
  13. May 29, 2013 at 1:33 PM
    knotty
    milwaukie, oregon
    yeah that could happen with a tire blow out too !! i just don't see how the suspension could just blow apart !
  14. May 29, 2013 at 1:33 PM
    knotty
    milwaukie, oregon
    what shocks would those be ?
  15. May 29, 2013 at 1:37 PM
    XXXX
    sKiP
    05 Prius
    maybe you should look into how the shocks blow apart before you state such things :notsure:
    and I'm no lawyer but last I checked a blow out is not even close to the same the same as negligence
  16. May 29, 2013 at 1:38 PM
    OZ-T
    Peter North
    British Columbia
    OME shocks like the 90000's
    ARB makes OME products , the OME 886 coils are designed to work with the ARB bumper , the OME 90000 shocks are designed to work with the 886 coils
  17. May 29, 2013 at 1:55 PM
    Hairy Taco
    North of Hell
    08 TRD
    :rolleyes: you sure have a way of making a point
    I would do this too.
  18. May 29, 2013 at 3:46 PM
    knotty
    milwaukie, oregon
    ome 90000
    • Open length is 543mm
    • Closed length is 413mm
    5100's
    Collapsed Length (MM): 432.5
    *Extended Length (MM): 573
    i dont see how the 5100 will "blow apart" sense they are a longer shock the only thing i see as a poss fail is the c clip ...
  19. May 30, 2013 at 11:27 AM
    cdj1
    cdj1 Well-Known Member
    Clint
    Muuurville, TN
    97 Tacoma
    King Extended travel coilovers, 5100 Shocks, Daystar shackles,OME Leaf Springs,255/85/16, front diff drop, RAT skid plates, 4.56 gears, LSD in rear, Aussie locker in the front, Front Range Offroad twin sticks, trail gear/ Bash Fab rear bumper, elite off road front bumper and sliders, warn m8000 winch, in cab winch control
  20. May 30, 2013 at 11:32 AM
    disc0monkey
    disc0monkey All right. I believe ya. But my Tommy Gun don't!
    if nothing else the valving won't match the spring. I added a turn on my coilovers and the valving felt un-tuned and i put it back to factory in 2 days. why pass up on a tuned package?
