uca's for 1500's and eibach coils?
Discussion in 'Suspension' started by Gus 524, Apr 20, 2013.
  1. Apr 20, 2013 at 1:57 PM
    Gus 524
    Gus 524 [OP] Well-Known Member
    Justin
    MN
    09 tacoma SR5 4WD 4-cylinder
    I'm trying to find out what kind and brand of upper control arms i should get to go with my lift that i will be putting on soon. This is the lift that is being shipped to me right now .
    Looking for uca's that will give me factory alignment and give me some decent off road capabilities all while being fairly cheap. (not looking to buy the best because i don't have much money to spend)
    Thanks,
    Justin
  2. Apr 20, 2013 at 2:03 PM
    Asianguywithatruk
    Asianguywithatruk Well-Known Member
    CenCal
    05 taco DCSB
    King RR coilovers Ironman leaf springs 17" scs sr8 jet black 285 75 17 Yokohama geolandar Demello front bumper Brute force rear bumper
  3. Apr 20, 2013 at 2:07 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Just get yourself some Light Racing. Probably be the cheapest. They're functional and will get the job done. Downside is they look stock and don't look awesome like ones from Camburg, etc.
    But if you're not worried about having something that stands out, the Light Racing ones will suit you just fine. I picked mine up from Toytec when I got the rest of my lift from them, but I think you can get them a little cheaper elsewhere.
  4. Apr 20, 2013 at 6:50 PM
    Gus 524
    Justin
    MN
    What about built rights? Can't find any prices on them but I heard they where a cheaper uca that performs verry well.
  5. Apr 20, 2013 at 6:53 PM
    sirwillysc
    sirwillysc Well-Known Member
    Will
    Columbia SC
    13 Tacoma Dbl Cab TRD Off Road
    Debadged destickered
    Do u have to get UCA s with that kit? why couldn't you use stock
  6. Apr 20, 2013 at 6:59 PM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    FWIW
    I know the guys at Toytec are big fans of the Light Racing UCAs because they are fully adjustable for alignment and the upper ball joint is fully sealed, protecting against corrosion from road salt and such. My experience has been very good with them.
  7. Apr 20, 2013 at 7:03 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    5100's set at 0 and Eibach coils don't require new UCA's. You can get a perfect alignment with the factory arms. I have that setup and just got my alignment perfect. 0 toe, a tiny bit of camber (I requested it) and 2.5 caster. Unless you kicked the 5100's up to .85, there's no need to get new UCAs with that lift.
  8. Apr 20, 2013 at 8:12 PM
    Gus 524
    Justin
    MN
    Thanks for that info. With the winters here in Minnesota it sounds like light racings might be the way to go.
    Yea ok but I'm cranking those guys up to .85. Thanks for that info though.
  9. Apr 21, 2013 at 6:39 AM
    Pugga
    Massachusetts
    Sorry, I was answering Sir Willy also. The LR UCA's are a good choice for UCA's for a stock travel lift kit. Protected ball joint and tons of adjustability. They will work for mid travel also but at that point you might benefit more from a uniball UCA instead.
  10. Apr 21, 2013 at 6:47 AM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    ^ what that guy said :cool: i have them and am happy with them, haven't had any problems. Last time i checked headstrong offroad had the best price at $375 shipped
  11. Apr 21, 2013 at 9:26 AM
    Gus 524
    Justin
    MN
    Ok my bad. Looks like light racing is what I should get.
    $375 :eek: thanks for letting me know!
