UCA's JBA or SPC?
Discussion in 'Suspension' started by Trdpro1, Dec 13, 2017.
  1. Dec 21, 2017 at 9:09 AM
    jerzsubbie
    jerzsubbie Well-Known Member
    Davidson, NC
    ‘13 GX460
    I haven't looked a ton yet but SPC's are $366 from Headatrong when added to the lift kit I'm planning on. JBAs are $450. I'm all for better deals, if you have some leads, please share!
  2. Dec 21, 2017 at 9:11 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Ahhh, I see that now. I was pricing out buying it separately, in which case the JBA is about $20 cheaper.
  3. Dec 21, 2017 at 9:11 AM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    I am on my 4th set of SPC's in 5 years. Atleast their warranty is simple.
    EatSleepTacos likes this.
  4. Dec 21, 2017 at 9:22 AM
    jerzsubbie
    Davidson, NC
    ‘13 GX460
    Do you change them every time you change your cabin air filter? lol. That sounds like a nightmare.
    Island Cruiser and EatSleepTacos like this.
  5. Dec 26, 2017 at 2:07 PM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    This exactly. I've had negative camber issues the entire time I've lifted my truck. I preset my camber with the SPC UCAs and the shop was able to dial it almost down to completely zero while maintaining decent caster.
    Just make sure you tighten that bolt real tight. Mine came lose once because I didn't tighten it all the way and hit a pot hole. :annoyed:
  6. Dec 26, 2017 at 2:07 PM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    There are some group buy deals for these every once in a while or some vendors will hook you up if you're a repeat customer...
  7. Dec 28, 2017 at 1:32 PM
    yeos
    yeos OCD Member
    Moses Lake, WA
    2007 Lexus GX
    I've had my SPCs for 2.5 years now and one of the ball joints just went. Only 20k miles on them. I've read much into the great warranty and customer service that SPC has and emailed them about the issue. A buddy if mine has the JBAs and have no issues with them.
  8. Dec 28, 2017 at 1:40 PM
    Fleabag
    Fleabag Suck it Trebek!
    Uriah
    Vancouver, WA
    2013 Toyota Tacoma TRD Offroad - SSM
    Suspension: SPC Light Racing UCAs Old Man Emu 886 Coils Old Man Emu 90000 Nitrocharger Struts Old Man Emu 60091 Nitrocharger Struts Deaver U402 Stage 3 Leaf Spring Packs Dobinsons Greasable Shackle Bolts Old Man Emu 95PF5 Trim Packer Energy Suspension Bushings Timbren U Bolt Flip Kit And Bumpstops Timbren Front SES Bumpstops Total Chaos Cam Tabs Tires: Pro Comp 87 Series 16's Steel Wheels Goodyear Duratrac 315/75r16 Engine: aFe Cold Air Intake aFe Throttle Body Spacer HyperTech Speedo Calibrator HP Tuner with a JustDSM and nd4spdbh tune file 3° Exhaust Cam Gear from Mightytacoman Peddle Commander Throttle Calibrator Drivetrain: ECGS Front Differential 4.88 gears with Harrop E-locker ECGS Rear Differential 4.88 gears with stock E-locker Tom Wood's One-piece driveshaft Derale Transmission Cooler Derale Thermostatic Switch for fan Mishimoto Fan for transmission cooler Improved Racing Thermostatic Cooler Bypass and filter relocator for transmission cooler Electrical: Eaton RFRM Custom PDM 10 fused relay circuits, 10 fused circuits Feniex 4200 Mini Controller with MeSo Customs mount. LED Bulb Upgrade Front - Rigid D Series Pro - Flood Diffused Rigid D Series Pro - Spot Rough Country Midnight Series 20" single row ARB 9" knockoffs Rear - Rigid D Series Pro - Flood Diffused Communication: Midland MXT275 GMRS Radio Assorted GMRS Handhelds Suburban Assault Armor: MobTown Rock Sliders - Plated MobTown Tail Gate Reinforcement Brute Force Fabrication Plate Front Bumper Brute Force Fabrication HC Dual Swing-out Plate Bumper BAMF Full Skid Set Chaos Fabrication Bed Side Reinforcements Recovery: Superwinch Tigershark 11,500 SR Hi-Lift Extreme 60" Shovel Mattock ActionTrax Recovery Boards Straps & Shackles Exterior: Homertaco Ghost Raptor Grill Alpine Designs Offroad Cab Mount Relocation Brackets Fender Trim Firewall Massage Stubby TRD Antenna Weathertech Window Deflectors Toyota Hood Deflector Soft Tonnaue Cover Color Matched Canopy Custom Aluminium Box on Swingout Modified Bedslide Interior: MeSo Customs Maps Lights and Dome Light ImMrYo Rear View Mirror Relocate Bracket LostSheep's Ram Mount - Mount DynoMat Ram Mount X-Grips and Various Connectors UltraGuage Weathertech Floor Mats Chinesium A/C Knobs Horse Blanket Seat Covers.
    I am hearing alot of people having to replace ball joints on the SPC's, I just recently put a set of them on my rig. has the ball joint failure been resolved with newer versions or was there no changes and one can expect failure even with consistent maintenance?
  9. Dec 28, 2017 at 1:42 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    The new balljoints have grease fittings and if greased correctly they should fail less.
  10. Dec 28, 2017 at 1:51 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    I have the spc i have about 70k on them no issue but recently just order new set of balljoints and bushing to freshen them up
  11. Dec 28, 2017 at 2:01 PM
    Fleabag
    Uriah
    Vancouver, WA
    Sounds good I have the new version and grease them every 3k and check them after a offroad run.
  12. Dec 28, 2017 at 2:32 PM
    yeos
    yeos OCD Member
    Moses Lake, WA
    2007 Lexus GX
    Well that didn't take long. Tom from SPC was very helpful in getting a new pair of upgraded ball joints with the zerks shipped out to me. I just have to return the old ones afterwards to get my core charge refunded.
    Fleabag and Sandman614 like this.
  13. Dec 28, 2017 at 11:23 PM
    swissrallyman
    swissrallyman Well-Known Member
    2017 Tacoma TRD Sport
    I had the SPC and loved them. Went through 2 sets of balljoints over 120,000 km and just replaced again with the 3rd set which were greasable when i totalled the truck. Hit a jeep head on at highway speeds, with our front right wheels colliding. Needless to say every single suspension component on my truck was torn off. LCA torn in half, ome shock shaft and coil broken, swaybar links broken, and the SPC UCA also broke, but the adjustable balljoint did not budge; they only snapped in one location, about 3 inches from the balljoint... i’m still waiting for pictures from my insurance company and will post them. Even my front cab mount was almost torn off the frame...
  14. Dec 29, 2017 at 6:21 AM
    snook 32
    snook 32 Well-Known Member
    Herb
    Davie Florida
    08 pre runner
    JBA's on mine easy to install, well built, time and effort was put into them and testing as well.
  15. Feb 7, 2018 at 6:59 AM
    #35
    bijick
    bijick such mods much want
    E
    Stl
    2013 MGM Singular Cabular Selectable
    OME 884’s ,Dakar hd’s, Jba uca, lce header, 4.88’s, Arb locker , j shift tcase-T4R, arb bumper, leer topper, 3500w inverter, mad wife, scratched paint, skid plates, snorkelerer, led flush mount reverse lights, etc..
    Just got my jba’s yesterday, haven’t installed them but man are they beefy. Extremely simple and I really enjoy the fact that they use gm ball joints and are easily changeable. I’ll probably update this next week after they’re installed and I’ve had an alignment.. hopefully my cams aren’t seized.
    CementTRDOffRoad likes this.
  16. Mar 22, 2018 at 6:00 PM
    #36
    nairb
    nairb Well-Known Member
    Brian
    Oahu, Hawaii
    2017 DCab 4x4 OR
    How is the caster on the JBA with a mild lift? I have fox 2.5s in order for my 2017 and won’t be lifting it beyond the preset height. I read some issues with too much caster on mild lifts? The shop told me that I need UCAs for my extended coils, the body won’t fit stock UCAs without hitting. I need to be within stock specs to be road leagal here.
  17. Feb 3, 2020 at 2:15 PM
    #37
    Skawdee
    Skawdee SKOL Vikings!
    Star Valley, Wyoming
    2009 Tacoma TRD-Offroad, 6-spd Man.
    Old Man Emu 2.5” Full Suspension Lift w/ Wheeler's Off-Road Progressive Leaf Pack JBA Upper Control Arms Moog Lower Control Arms Victory4x4 Strike Front Bumper w/ Grill Tubing Morimoto XB Headlights Baja Designs Squadron Sport Amber Fog LED’s Baja Designs 20” White LED Light Bar Over-sized BFG All-Terrain Tires K&N Stock Replacement Air Filter Pioneer AVIC-W8400 Head Unit Apple TV Wireless Phone Charging Pad Bed rail mounting with ax, shovel, MaxTrax Bed Extender
    I’m reviving this thread because I’m in the same debate - JBA’s vs SPC. I have a 2009 TRD off-road with the OME 2” lift bought from Wheelers.
    By now I know at least the SPCs have been refined and the JBAs have a cerakote ball joint. But the pricing is way high now it seems. SPC are $523 on Amazon ($650 from Headstrong) and JBA is $450 from their website. I don’t think I need the extra adjustment of SOC and that JBA red might look sharp on my Barcelona Red truck.
    Also In looking to replace my LCAs because they’re over 11 years old factory and my bushings are worn, causing cupping on the new tires. Several shops told me this. What would you suggest? I’m thinking Moog for the bushings and greaseable ball? Some say Toyota OEM.
    What say you? Thanks!
  18. Feb 3, 2020 at 2:39 PM
    #38
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Uppers Id go jba. Lowers moog whole replacements
    Skawdee[QUOTED] likes this.
  19. Feb 3, 2020 at 3:12 PM
    #39
    Skawdee
    I have a guy that said he’d ship me his 2015 OEM LCAs that have 1500 miles on them before he installed a long travel kit. If the price is right, think that’d be good?
  20. Feb 3, 2020 at 3:17 PM
    #40
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    1,500 miles? Or 15,000 miles? Both are extremely low for a 2015 so I'd be leery of authenticity. A pic of the odometer would be nice. Parts like that are hit or miss because you don't know the life they lived. Those could have been some real rough miles. Especially if the guy is going long travel. Maybe he rides his truck hard. Something to think about.
