ucas
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tarpon24, Oct 30, 2012.
  1. Oct 30, 2012 at 2:12 PM
    Tarpon24
    Tarpon24 [OP] Well-Known Member
    Frankie
    Fl
    Trd
    Leveling kit, 20 in rims, flowmaster true duals, bullying watch dog,
    what is the difference between stock ucas and after market ones the size of the ball or the design ? because when i was taking off my stock ones i ripped the boot and i never knew the stock uca internals looked so similar
  2. Oct 30, 2012 at 2:43 PM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    I'm assuming you're talking about stock length UCA's and not long travel length UCA's.
    Most aftermarket UCA's have uniballs instead of the ball joint. The advantage here is better performance at extreme angles, and theres no boot to rip or grease. They are usually coated with some teflon from the factory.
    And the reason I went with aftermarket UCA's is the stronger tubular design. The stock ones are just some sheet metal that is folded into a half-circle shape. Tubular arms can withstand more force and are less likely to bend and break if you hit something hard enough. Aftermarket UCA's also have higher quality greasable bushings.
    Stock design:
    Total Chaos tubular UCA with uniball
  3. Oct 30, 2012 at 2:54 PM
    Tarpon24
    Frankie
    Fl
    Trd
    yea i was just wondering i put the all pros on my truck today and i ripped the boot with the forks to get the bolt out and saw the ball joint and and was just wondering the difference except for the strength factor
  4. Oct 30, 2012 at 2:56 PM
    alegav
    alegav TeamBlue
    Alex
    San Diego, CA
    2012 Tacoma TRD T|X Baja
    Pelfreybilt IFS Skid, Mid Skid and Plate Bumper, Rigid Industries Dually's, ARB CKMA12 On Board Air, Kenwood TM-281A Radio, Rear view mirror relocation bracket, Wheelers SuperBumps, Toytec Baja Spacer
    Hows the "squeak" with going uni-ball UCA's?
  5. Oct 30, 2012 at 2:58 PM
    Tarpon24
    Frankie
    Fl
    Trd
    what squeak ?
  6. Oct 30, 2012 at 3:00 PM
    The Traveler
    SoCal
    Apparently, the All Pros are notorious for being the loudest UCA's.
  7. Oct 30, 2012 at 3:07 PM
    alegav
    alegav TeamBlue
    Alex
    San Diego, CA
    Ya one reason why I haven't made the switch yet. Probably cant hear it while in the cab but I'm not sure.
  8. Oct 30, 2012 at 3:07 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    My LR UCA's don't make any noise
  9. Oct 30, 2012 at 3:08 PM
    plee33
    plee33 Well-Known Member
    Peter
    Sacramento, CA.
    SWB TRD Sport Long Bed 4x4
    SnugTop SuperSport Shell, BedRug, OME Heavy Duty Lift Kit, Weathertech Liners, more to come....
    Hey OZ, did you have to replace your bushings?
  10. Oct 30, 2012 at 3:10 PM
    OZ-T
    Peter North
    British Columbia
    Haven't yet , no
  11. Oct 30, 2012 at 3:12 PM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Mine only squeak after I pressure wash my truck and directly spray water on the balls and its a pretty horrendous squeak. Then I just put a little triflow on them and squeak is instantly gone
  12. Oct 30, 2012 at 3:13 PM
    Tarpon24
    Frankie
    Fl
    Trd
    i drove around for about an hour and no squeak even off road. and if they do ill the grease the mothers
  13. Oct 30, 2012 at 3:15 PM
    plee33
    Peter
    Sacramento, CA.
    I noticed my bushings are cracked. I need to get it replaced with the new bushings. SPC should give free replacement bushings for customers who have the earlier model arms. My arms only have 15k on them when I noticed the cracks. Should've spent the extra money for the Total Chaos and not have to deal with this.
  14. Oct 30, 2012 at 3:18 PM
    Tarpon24
    Frankie
    Fl
    Trd
    well i ride with the windows down and nothing some yamaha grease cant fix
  15. Oct 30, 2012 at 3:20 PM
    Tarpon24
    Frankie
    Fl
    Trd
    yea idk if they start fing up ill just use that as an excuse for lt setup
  16. Oct 30, 2012 at 3:23 PM
    alegav
    alegav TeamBlue
    Alex
    San Diego, CA
    Thanks for the info guys, looks like you just need the proper lubrication :)
  17. Oct 30, 2012 at 3:30 PM
    Tarpon24
    Frankie
    Fl
    Trd
    yea i use yamaha lube for everything because its the best i could find + its made to stand up to salt water everyday on boats so freshwaters like nothing
  18. Oct 30, 2012 at 3:33 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Any lube that has Teflon in it will work. Otherwise u will dry out the bushings very fast
  19. Oct 30, 2012 at 3:51 PM
    alegav
    alegav TeamBlue
    Alex
    San Diego, CA
    Noted!
