UCON available for 09-15!!!
Discussion in 'Performance and Tuning' started by gersus, Jun 7, 2017.
  1. Aug 24, 2017 at 3:53 PM
    #61
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    So I don't need the BD version if I have the ucon right?
  2. Aug 24, 2017 at 3:54 PM
    #62
    Oreo Cat
    Yea I just checked and 3.00 and 2.85 don't need it, anything lower has to have the 7th injectior
  3. Aug 24, 2017 at 4:04 PM
    #63
    gersus
    gersus [OP] Well-Known Member
    Missouri
    14 Tacoma DCOR
    Lil lift, bumpers, SC, UCON, headers, etc.
    The only reason you would need the bd version is for the carb sticker.
  4. Aug 24, 2017 at 4:08 PM
    #64
    Oreo Cat
    Do I need that to pass smog?
  5. Aug 24, 2017 at 4:19 PM
    #65
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    Not true considering it says it's "recommended" not required. Here's a fuel injector work sheet I checked if the 2.55 pulley needs more fuel then the 455 cc that is already on the Magnuson/TRD kit.
    https://www.rceng.com/technical.aspx#Fuel_Injector_Worksheet_
    It will require 395 bhp to maximize the 455 cc injectors at 80% duty cycle. The 2.55 pulley only gives you 30-40 more then the stock blower of 305 hp so 345 hp... I disagree here. More then likely you'll need the 255 or 320 lph fuel pump then that extra injector.
    Not to argue here but I like to make sure we're not buying stuff we don't need.
    Torspd and Oreo Cat[QUOTED] like this.
  6. Aug 24, 2017 at 4:37 PM
    #66
    gersus
    Missouri
    14 Tacoma DCOR
    @loginfailed is running the 2.55 with 7th injector. His 6 injectors are at 80% and 7th is at 38%.
    And yeah, fuel pump too.
    @Oreo Cat regardless of which kit you buy, get a wideband AFR gauge.
    And it sounds like you should spend some time familiarizing yourself with the rabbit hole of forced induction. There are some great threads here.
    If you want to read about the infamous bully dog, read the supercharger group buy thread.
    loginfailed and Oreo Cat like this.
  7. Aug 24, 2017 at 4:39 PM
    #67
    Lord Helmet
    Nick
    '24 X3 M40i
  8. Aug 24, 2017 at 4:57 PM
    #68
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That will work for some, but still have flexibility limitations.
    loginfailed likes this.
  9. Aug 24, 2017 at 4:58 PM
    #69
    Lord Helmet
    Nick
    '24 X3 M40i
    I'm just glad we have more options now compared to a few years ago :thumbsup:
  10. Aug 24, 2017 at 7:34 PM
    #70
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    If we put all our faith in the injector calculators I would be making 441 bhp!
    oni06 and gersus[QUOTED][OP] like this.
  11. Aug 24, 2017 at 7:52 PM
    #71
    Oreo Cat
    What do you make now?
    loginfailed[QUOTED] likes this.
  12. Aug 24, 2017 at 9:53 PM
    #72
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
    But the UCON with it's cam gears add maybe 30 hp more.
  13. Aug 24, 2017 at 10:05 PM
    #73
    oni06
    oni06 Well-Known Member
    Summary:
    The more expensive S/C comes with the Bully Dog Tuner
    The BG tune is crap DON'T use it.
    Put the BD into a desk drawer and forget about it.
    If your in Cali it may be worth it to you to get the CARB sticker so you can possibly pass smog even when using the UCON assuming they do the SMOG check only using the OBDII port.
    If your in Cali and you don't have the CARB sticker for the S/C you WON'T pass smog
    2.85 pulley should be coupled with a fuel pump upgrade.
    Smaller then 2.85 pulley REQUIRES fuel pump upgrade AND 7th injector.
    If you do long tube headers + Y pipe in Cali you won't pass smog.
    If you do cold air intake in Cali you won't pass smog.
    If you can do all of the above and still pass smog then :thumbsup:
    If you can do all of the above and still pass smog then you probably also don't need to order it with the BD tuner or need the CARB sticker.
    Torspd likes this.
  14. Aug 24, 2017 at 10:12 PM
    #74
    FinnJ
    Finland
    Should pass easily the sniff test too with stock headers and Y-pipe.
    oni06[QUOTED] likes this.
  15. Aug 24, 2017 at 10:25 PM
    #75
    Oreo Cat
    How does a cia make a truck not pass smog??
  16. Aug 24, 2017 at 10:25 PM
    #76
    Oreo Cat
    I hate this state..
    oni06 likes this.
  17. Aug 24, 2017 at 10:26 PM
    #77
    oni06
    Pretty much all CAI don't include the carbon filter that is required to pass smog in cali.
    Oreo Cat[QUOTED] and TacoJova like this.
  18. Aug 24, 2017 at 10:34 PM
    #78
    Oreo Cat
    Is there a difference between the supercharges too? Or am I just paying an extra $500 for a sticker?
  19. Aug 24, 2017 at 10:35 PM
    #79
    oni06
    Paying for the sticker.
  20. Aug 24, 2017 at 10:43 PM
    #80
    Oreo Cat
    ...fuck this place
