UCON Flex Advanced Engine Management System
Discussion in 'Performance and Tuning' started by gray223, Jul 5, 2014.
  1. Jul 10, 2017 at 10:32 AM
    #221
    gersus
    gersus Well-Known Member
    Missouri
    14 Tacoma DCOR
    Lil lift, bumpers, SC, UCON, headers, etc.
    20 minutes, man you're fast!
  2. Jul 10, 2017 at 11:41 AM
    #222
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I was on a good pace until I was reinstalling the passenger valve cover. I couldn't get the rear secondary air pipe to line up and got in there with a pry bar to bend it over a little. The gasket fell off and it took me 20 minutes of cussing to find it. Then upon reinstalling the passenger side coils I noticed that during my prybar move, I must have snapped off the plastic vacuum nipple on the rear secondary air solenoid. Another 20 minutes of CA gluing, epoxying and cussing and now I'm back on track. Hopefully the CA glue and epoxy hold up. I think that valve is like $500, LOL
    Roostfactor and Torspd like this.
  3. Jul 10, 2017 at 3:05 PM
    #223
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Its alive. It runs pretty good at part throttle and the normal grandpa style driving that I do. But when you put your foot into it, it gets rich pretty quick. I have dual widebands, one in each bank. Anything close to WOT and the needles get buried at 10:1 which is the lowest my gauges will display.
    I understand that one of the advertised features of the UCON is that it self-tunes for the most part. Ann of you guys know over what period of time this takes place? I suppose I should just give @Gadget a call but its too late in the day. Just curious if any of you guys know how the self tuning works.
  4. Jul 10, 2017 at 3:24 PM
    #224
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Sorry Login, no idea on learning timeframe.
  5. Jul 10, 2017 at 3:35 PM
    #225
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    The Ucon must be in limp mode @loginfailed being 10:1 at wot
    loginfailed likes this.
  6. Jul 10, 2017 at 4:57 PM
    #226
    gersus
    Missouri
    14 Tacoma DCOR
    I havent played around with mine much yet but I can hit 10, even high 9's just messin around.
    I thought maybe its because I have the stage 2 tune which is intended for 2.85 pulley, headers, and y pipe. I dont have the y pipe.
  7. Jul 10, 2017 at 5:05 PM
    #227
    gersus
    Missouri
    14 Tacoma DCOR
    Also, from a dead stop my truck wont break traction like it used to. It pauses for a split second then takes off.
    (Trac control is off)
  8. Jul 10, 2017 at 5:14 PM
    #228
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Same!
    gersus[QUOTED] likes this.
  9. Jul 10, 2017 at 5:53 PM
    #229
    TRON
    The Ucon is suppose to lean you out not rich you up... AFRs in the 9s are no good man
  10. Jul 10, 2017 at 6:38 PM
    #230
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I need to call Gadget tomorrow. The truck is slower in boost than it was with just the TRD tune. There are also these little mini spikes that feel like fuel cuts when at WOT or close to WOT. Normal driving it actually feels very smooth. But any throttle at all and the AFR dips down in a hurry.
  11. Jul 10, 2017 at 6:56 PM
    #231
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    You guys did email or discuss which specific aftermarket conponents you have, ao that the proper tune could be uploaded, correct?
  12. Jul 10, 2017 at 7:05 PM
    #232
    gersus
    Missouri
    14 Tacoma DCOR
    Yes
  13. Jul 10, 2017 at 8:28 PM
    #233
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Yes, Gadget emailed me and asked me specifics. Magnuson SC, TRD tune, stock headers, stock y-pipe, stock exhaust, URD Walbro 255/LPH pump, TRD injectors.
  14. Jul 10, 2017 at 9:10 PM
    #234
    GT7
    Grant
    Phoenix
    2013 DCLB
    Extremely specifically
  15. Jul 10, 2017 at 9:50 PM
    #235
    TRON
    There's really only 3 different general maps for the ucon and TRD blower setup. And there all based off what size injectors, what cats are deleted, and the 7th. All other mods for TRD setups don't really apply to these maps. I'm sure Scott tweaks some tunes but only a rare few get that luxury
    Torspd and loginfailed[QUOTED] like this.
  16. Jul 11, 2017 at 3:04 AM
    #236
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    So do you know what the UCON shots for as far as a target for its auto tuning? Does it use the WRAF sensors and shoot for a certain AFR?
  17. Jul 11, 2017 at 4:52 AM
    #237
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Correct. If you are having a tune specific related issue, and Gadget cannot solve it, then a remote tuning session is their next step.
  18. Jul 11, 2017 at 4:59 AM
    #238
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    not about restriction in this case. Its about backpressure. The URD spec U pipe is smaller than the Y pipe and I think its either on par or smaller than stock headers, but DEFINITELY makes more power than either other exhaust setup. Id believe youd get 60 HP over stock with a good tune and the URD spec U pipe. Sure, its 1K but it comes with the Y pipe and the Catback, deletes the front cats, and doesnt sound like you hacked up your exhaust with a saw either! heres a link to my videos: https://drive.google.com/file/d/0B4eLRaYSqYH5WDR0LXVNbG9MWW8/view?usp=sharing
    https://drive.google.com/file/d/0B4eLRaYSqYH5a1RfVFpOdEc0LTA/view?usp=sharing
  19. Jul 11, 2017 at 5:03 AM
    #239
    GT7
    Grant
    Phoenix
    2013 DCLB
    Go away turd gen :lalala:
  20. Jul 11, 2017 at 6:04 AM
    #240
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Are you referring to 2nd Gen components, or 3rd Gen?
    PapaBear and 12TRDTacoma like this.
