UCON Flex Advanced Engine Management System
Discussion in 'Performance and Tuning' started by gray223, Jul 5, 2014.
  1. Jul 14, 2017 at 9:47 AM
    #261
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    That seems insane to me. I really hope it works out for you, so much trouble with your truck and ecus. :annoyed:
    loginfailed[QUOTED] and gersus like this.
  2. Jul 14, 2017 at 11:19 AM
    #262
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Its not as bad as it sounds. Used ECUs are only $150-$200 on eBay depending on the day. I already have a Drewtech Mongoose. Programming an ECU only costs me $55 for a 48-hour Techstream subscription.
  3. Jul 14, 2017 at 11:31 AM
    #263
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    I'm doing the same ..
    Bought an ecu from eBay for stock calibration.
    loginfailed likes this.
  4. Jul 14, 2017 at 11:43 AM
    #264
    gersus
    gersus Well-Known Member
    Missouri
    14 Tacoma DCOR
    Lil lift, bumpers, SC, UCON, headers, etc.
  5. Jul 14, 2017 at 1:29 PM
    #265
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Technically, you don't need a cable. Only a paper clip.
    But you don't know what calibration is in there without some sort of tool to read the calibration ID.
    What if the one you buy on eBay had a TRD flash or some poor sap that had a BullyDog flash? I mean there are tons more non-supercharged than supercharged. So odds are in your favor you'll get an NA version. But I have the sort of luck so I want to see the calibration ID with my own eyes before I call it good.
  6. Jul 14, 2017 at 2:28 PM
    #266
    gersus
    Missouri
    14 Tacoma DCOR
  7. Jul 15, 2017 at 11:57 AM
    #267
    s10nick
    s10nick Well-Known Member
    nick
    Greeley, CO
    base mod. debaged
    3inch hbs lift toytec diff drop grillcraft grill hella 500s conv. to 8k hids xentec hid head light conv. 5% tint more to come
  8. Jul 15, 2017 at 3:58 PM
    #268
    jojotoo
    Brandon
    Socal
    2015 DCLB
    Headers , cam gear and thermostat installed. Verified spare ecu N/A calibration file.
    Time to schedule a session with gadget to reprogram the ucon for N/A ecu.
    Torspd, Roostfactor and loginfailed like this.
  9. Jul 16, 2017 at 9:22 AM
    #269
    s10nick
    nick
    Greeley, CO
    base mod. debaged
    How big of a pita were the headers to install?
  10. Jul 16, 2017 at 9:40 AM
    #270
    jojotoo
    Brandon
    Socal
    2015 DCLB
    my friend at Toyota did all the work for practically free. He said it wasn't that big of a deal. Only issue I had was the passenger side o2 sensor not reaching even the upper bung. Ordered extension harness yesterday and will move them to the collector.
    I'm happy with them .. not much louder more of a deeper tone. Stock y with trd exhaust.
    SonnyBones likes this.
  11. Jul 16, 2017 at 11:43 AM
    #271
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    It's not too bad. The biggest headache is the secondary injection setup on the 2012+ models.
    gersus likes this.
  12. Jul 16, 2017 at 12:42 PM
    #272
    SonnyBones
    SonnyBones I VOID WARRANTIES
    Jeffery
    2015 TACOMA ACCESS CAB
    Any CEL light after the header installation? Heard folks were getting them with the URD Spec headers since they eliminated the cats. O2 sims provided weren't working or something like that.
  13. Jul 16, 2017 at 12:46 PM
    #273
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Going to be a nice bumping power with those components.
  14. Jul 16, 2017 at 12:47 PM
    #274
    Roostfactor
    TX panhandle
    I would still occasionally get a cel with the o2 SIM installed. Not really a big deal, I would just clear the code and press on.
  15. Jul 16, 2017 at 12:49 PM
    #275
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    And your sim is installed in the proper fashion? Per the description page?
  16. Jul 16, 2017 at 12:51 PM
    #276
    Roostfactor
    TX panhandle
    It sure was. Even swapped with Gadget for a second o2 SIM. Still happened just not as frequently. It's now removed since the UCON handles all that.
    oni06 and loginfailed like this.
  17. Jul 16, 2017 at 12:55 PM
    #277
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I bet the UCON will handle it better.
    I remember there being a slight signal change from the 2012 plus models, or something of that nature being brought up as the reason why the O2 Sim was hit-or-miss.
  18. Jul 16, 2017 at 12:58 PM
    #278
    s10nick
    nick
    Greeley, CO
    base mod. debaged
    Yeah I spoke with gadget and he said not to run the sims with the ucon. Not sure as to why? Im waiting to install the headers untill I get the o2 extensions. Did you guys need a new gasket for the block side?
  19. Jul 16, 2017 at 1:37 PM
    #279
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
    And a BIG headache is rusted nuts/studs. Remember to change them to stainless ones and lubricate well (ceramic paste), otherwise removing the Spec-U headers might be impossible job.
    I changed the nuts to ARP ones. The best tool to tighten them is this (size 10):
    s10nick likes this.
  20. Jul 16, 2017 at 2:49 PM
    #280
    jojotoo
    Brandon
    Socal
    2015 DCLB
    well.. my passenger side o2 is not connected, yet... extension harness should be here soon. Its throwing a P0031. Im assuming itll be cleared once i connect it.
