UCON Flex Advanced Engine Management System
Discussion in 'Performance and Tuning' started by gray223, Jul 5, 2014.
  1. Jul 17, 2017 at 2:41 PM
    #281
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    eBay ECU had corrosion on the outside and on some of the terminals. I popped off the cover and the board was corroded in some spots. Sent it back today and ordered another from a different seller.
    All works out anyway, since I'm out of town and won't be able to mess with it again until the weekend.
  2. Jul 17, 2017 at 4:04 PM
    #282
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Good catch.
    loginfailed likes this.
  3. Jul 18, 2017 at 8:10 AM
    #283
    gersus
    gersus Well-Known Member
    Missouri
    14 Tacoma DCOR
    Lil lift, bumpers, SC, UCON, headers, etc.
    I bought a ECU this morning from a local salvage yard. $125. Hope to get it paired and UCON updated Thursday. Fingers crossed...
    jojotoo and Roostfactor like this.
  4. Jul 18, 2017 at 8:35 AM
    #284
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Check it thoroughly.
  5. Jul 18, 2017 at 8:44 AM
    #285
    gersus
    Missouri
    14 Tacoma DCOR
    I looked it over for corrosion, bent pins, damage. what else?
  6. Jul 18, 2017 at 10:46 AM
    #286
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Take out the 4 Phillips head screws and pop off the cover. Look at the board to make sure nothing corroded.
    The second ECU I got for $99 should be here Friday.
  7. Jul 18, 2017 at 11:28 AM
    #287
    Tn Jeff
    Tn Jeff Well-Known Member
    Jeff
    Cookeville
    2015 white trd off road
    Ome 886, 90021, hd Dakar’s/elo96r. Spc lca. Trd supercharger (not installed)& pro exhaust. Oem Bed mat. Mobtown tailgate skin & cap & lockable cubbies. Demello al front bumper & warn synthetic xd 9000. Body armor rear bumper. Gentex Compass & temp rear view mirror. Amp research Bed extender. Uws side tool boxes. Cooper 265 75 16 st maxx. Rci al skids; pelftry al gas tank skid. All pro Rear locker skid. Cover king neoprene seat covers. Top line vent visors from amazon. Weather tech floor mats. Piaa lp 530 fog lights. Redline Black hood struts. Bamf DOM bolt on sliders with fill plates. White prinsu cabrac. Wheelers superbump stops front & back. Relentless fab u bolt flip.
    If ecu has been trd flashed, ucon won't work?
    Or, is that just the case with bully dawg?
  8. Jul 18, 2017 at 12:06 PM
    #288
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    It's my understanding that the stock ecu is preferred over trd/bd calibration.
    Roostfactor and loginfailed like this.
  9. Jul 18, 2017 at 12:21 PM
    #289
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Stock is preferred from what gadget has told me. My believe for this is because they're so many different versions of the trd reflash plus the bullydog version. I think a stock ecu is easier to get right with a ucon because they have less variability
    loginfailed, gersus and Tn Jeff like this.
  10. Jul 18, 2017 at 5:48 PM
    #290
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    The TRD flash being an issue would have been a nice factoid to know about in advance. It wouldn't have prevented me from buying a UCON.
    I could have had a stock ECU ready to go ahead of time. The UCON would've had the correct calibration from the beginning. I could've done the whole thing all at once and may not have even have needed a remote session.
    Torspd, Tn Jeff and jojotoo[QUOTED] like this.
  11. Jul 18, 2017 at 6:58 PM
    #291
    gersus
    Missouri
    14 Tacoma DCOR
    I second that.
    Tn Jeff and loginfailed[QUOTED] like this.
  12. Jul 19, 2017 at 4:30 AM
    #292
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Less flashes = less variables = less problems.
    oni06 and loginfailed like this.
  13. Jul 19, 2017 at 6:06 AM
    #293
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I wish my crystal ball would've been operational. Maybe they never tested the UCON with my setup (2014/TRD).
    Scott said the cam angles should be close to 0 degrees and my truck they're around 23 degrees, IIRC. The marks on the crank pulley and cam gears all line up. I thought maybe my chain was off somehow, but he said it's definitely TRD doing it to reduce power level.
    FinnJ and gersus like this.
  14. Jul 19, 2017 at 8:30 AM
    #294
    gersus
    Missouri
    14 Tacoma DCOR
    What I'm continually learning is nothing is easy or simple with these trucks.
    Skootter14 and loginfailed like this.
  15. Jul 19, 2017 at 8:42 AM
    #295
    mightytacoman
    Kel
    4.5L 1grfe
    On paper it always sounds so easy though.
  16. Jul 19, 2017 at 8:42 AM
    #296
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    The TRD reflash being an issue for the Ucon or APR x1 has not been an issue in the past. Curious if getting a stock ecu solves the problem :rolleyes:
  17. Jul 19, 2017 at 9:03 AM
    #297
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
  18. Jul 19, 2017 at 10:11 AM
    #298
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Yep, Installing stock ECU to may NOT really necessarily improve anything. Willing to be a guinea pig try to work with Gadget/Scott to come up with solution but there will be a point in time to just say to heck with it and live with TRD flash only.
    I plan to install URD headers, y-pipe etc but not investing in any more parts unless the UCON is going to work right.
    This is where I'm hoping the issue lies. But it may be not only the various TRD calibrations. The various non-supercharged calibrations may also be problematic.
  19. Jul 21, 2017 at 9:26 AM
    #299
    gersus
    Missouri
    14 Tacoma DCOR
    Got my "new" ecu installed and paired a couple days ago. Just waiting on URD now...
  20. Jul 21, 2017 at 9:42 AM
    #300
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
