UCON Flex Advanced Engine Management System
Discussion in 'Performance and Tuning' started by gray223, Jul 5, 2014.
  1. Jul 25, 2017 at 4:31 PM
    #321
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    I wonder if they want to sort that out before they release the ucon again
    Tn Jeff likes this.
  2. Jul 26, 2017 at 2:28 PM
    #322
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  3. Jul 26, 2017 at 2:31 PM
    #323
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    I hope not jesus
    gersus and loginfailed like this.
  4. Jul 26, 2017 at 2:34 PM
    #324
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I had p219a/b on the URD AFR calibrator. Took it off and never got it again until UCON installed. Toyota ECU doesn't like it when we're fiddling with the WRAF signals.
    Roostfactor likes this.
  5. Jul 26, 2017 at 2:39 PM
    #325
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Leave the UCON on and get new heads. ;)
    Roostfactor and gersus like this.
  6. Jul 26, 2017 at 2:45 PM
    #326
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
  7. Jul 26, 2017 at 3:04 PM
    #327
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    But you're not talking about stock heads though, are you!
    gersus likes this.
  8. Jul 27, 2017 at 2:28 PM
    #328
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    so...has anyone installed a magnuson S/C and UCON with the gears and had no problems?
    Im getting down to crunch time to purchase all the above but continuously read about these stories. Im debating just a S/C and TRD Flash since most seem to be alright with that combo but I really like the idea of the UCON and gear swap.
    Should I be concerned? I have an '11 that has never been flashed so the ECU is stock. As for the engine, I have the URD TCAI which I will make work with the S/C...
    loginfailed likes this.
  9. Jul 27, 2017 at 3:02 PM
    #329
    oni06
    oni06 Well-Known Member
    Installing this weekend. Will let you know.
  10. Jul 27, 2017 at 3:04 PM
    #330
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    If you plan on doing a UCON, don't do the TRD flash. At least on my truck, the TRD flash didn't work well with the UCON. Thankfully a $99 eBay ECU and a paperclip got me back to stock.
    The TRD flash by itself is fine, though if you're not too picky. Also, it's about $1500 cheaper than the UCON. ;)
    Tn Jeff likes this.
  11. Jul 27, 2017 at 3:04 PM
    #331
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Nice! Finally!
  12. Jul 27, 2017 at 3:26 PM
    #332
    oni06
    I know right. Its not quite a year since i got it but its damn close.
  13. Jul 27, 2017 at 3:29 PM
    #333
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Hopefully you find it to be worth the wait! Keep us updated on the install. Doing it yourself or no?
  14. Jul 27, 2017 at 3:33 PM
    #334
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Anyone that installed the Supercharger themselves, how much more in depth is the cam install?
  15. Jul 27, 2017 at 3:34 PM
    #335
    oni06
    I hope I find it worth the wait as well.
    No not installing myself as much as I wanted to attempt it just don't have time or space. glorifiedwelder is gonna do the install for me.
    loginfailed[QUOTED] likes this.
  16. Jul 27, 2017 at 3:55 PM
    #336
    GT7
    Grant
    Phoenix
    2013 DCLB
    Honestly easy
  17. Jul 27, 2017 at 6:11 PM
    #337
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    Are you running the ucon on the stock ecu ?
  18. Jul 27, 2017 at 6:12 PM
    #338
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Cam gear install isn't bad at all.
  19. Jul 27, 2017 at 6:13 PM
    #339
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Yes stock non-supercharged ECU. Started out with the TRD flash and it didn't work so well.
  20. Jul 27, 2017 at 6:15 PM
    #340
    jojotoo
    Brandon
    Socal
    2015 DCLB
    So .. other than the 2 cels your truck is running as expected ?
