UCON Flex Advanced Engine Management System
Discussion in 'Performance and Tuning' started by gray223, Jul 5, 2014.
  1. Jul 6, 2014 at 9:48 PM
    gray223
    gray223 [OP] Well-Known Member
    SE Missouri
    2014 Tundra Limited
    The cat back I agree but its not that the headers are restrictive its the design of the length of tubes and if the tubes are equal in length there is a lot more to the headers than just how easily they let exhaust gases out, there scavenging and a bunch of other variables.
  2. Jul 7, 2014 at 5:19 AM
    wildcats
    wildcats Well-Known Member
    13 DCSB Sport
    The Ucon is only available for up to a 2008 correct, or is their website just not up to date.
  3. Jul 7, 2014 at 5:40 AM
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    Yeah, not avalaible yet for 2009 +
  4. Jul 7, 2014 at 9:00 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Correct 09+ changed the ECU bus and then, I believe, required it to be licensed to get access to create any plug/pinout. Short story for 09+, no love.....
  5. Jul 8, 2014 at 10:40 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    There is a way, but it would have to be wire in.......
  6. Jul 8, 2014 at 10:45 AM
    Vassily28
    :popcorn:
  7. Jul 8, 2014 at 3:57 PM
    wildcats
    13 DCSB Sport
    Hmm, go on. Has this actually been accomplished? Also what tuning options are there? I know about the URD maf sensor, but anything else?
  8. Jul 8, 2014 at 5:00 PM
    gray223
    SE Missouri
    2014 Tundra Limited
    Look at post 12. Its exactly what Gadget said after I emailed him the op. Not really sure what your asking though.
  9. Jul 8, 2014 at 5:03 PM
    gray223
    SE Missouri
    2014 Tundra Limited
    Also I emailed Gadget again to see what the gains are for the stage 1 and stage 2 tunes. Its taking forever, I would call him but I just got my wisdom teeth out and can't talk very well. Haha
  10. Jul 8, 2014 at 5:05 PM
    wildcats
    13 DCSB Sport
    I was asking Torspd about getting the UCON to work for 2009+ trucks.
  11. Jul 9, 2014 at 5:46 AM
    Vassily28
    :popcorn:
  12. Jul 9, 2014 at 5:49 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Theoretically it can be done. However, I have yet to hear of anyone doing it. If it was straightforward I can almost assure you that there would have been a decent amount of these installed on 09+ trucks by now.
  13. Jul 9, 2014 at 6:31 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Yeah, can you imagine tapping/splicing the UCON in one wire at a time. I'd rather be a tester for the at-home self vasectomy kit... :D
  14. Jul 9, 2014 at 8:02 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    How many people have you heard of who have installed a wire-in standalone EMS on an '09? I only know of one. Toon714. With his ProEFI Pro48.
    The same thing would be done with the UCON. get the extension harness from AEM or URD. Plug one end into the UCON, cut the other end off, and with the pin-out sheets from both year models, splice it in. Sooooooo simple. :cool:
  15. Jul 9, 2014 at 8:18 AM
    #35
    Bellis
    Bellis friggin rad
    Ben
    mass southshore
    pyrite 6-speed 2012 offroad
    driver mod
    this is an awesome idea, but what about the traction control systems and the engine intervention it does. I wonder if that would still work, I suppose if the drive by wire system is a separate system from the EMS then that could intervene pre ucon control. I'm just talking in theory of course and don't actually know how those systems work.
  16. Jul 9, 2014 at 8:23 AM
    #36
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Just leave alone the systems which aren't compatible, or that the OEM ecu can still control just fine.
  17. Jul 9, 2014 at 8:35 AM
    #37
    Bellis
    Bellis friggin rad
    Ben
    mass southshore
    driver mod
    ok I see what your saying so in theory traction control would still function normally
  18. Jul 9, 2014 at 8:37 AM
    #38
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    OP has 4cyl.....didn't see any info back about whether this would also work on 4cyl trucks.
    I have an extra URD MAF with the harness already spliced into so that should be plugnplay whenever I get around to trying to tune mine. It'll be trial and error since Gadget says no maps for LCE header/Tooter IM spacer/Gibson catback/KVA intake combo. Will need 3rd bung welded into midpipe somewhere so I can rig up my Innovate LC-1 wb02 sensor/gauge to see what changes to mapping are doing. I like the self tuning concept of the UCON...........
  19. Jul 9, 2014 at 8:54 AM
    #39
    gray223
    SE Missouri
    2014 Tundra Limited
    I do have a 1st gen 4cyl but I wasn't talking about using it on my truck. I was talking about the 2nd gen v6 because I hope to get one in the not so distant future.
  20. Jul 9, 2014 at 8:57 AM
    #40
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Didn't figure it would so I will continue to consider doing v6 swap into my 2nd gen reg cab......
