UCON Flex Advanced Engine Management System
Discussion in 'Performance and Tuning' started by gray223, Jul 5, 2014.
  1. Aug 1, 2017 at 10:06 AM
    #441
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Correct, they aren't even shipped yet due to the URD y-pipe not in stock. Supposed to be getting shipped sometime this week.
    Cats or not, I don't think 10:1 at WOT is ideal.
    jojotoo likes this.
  2. Aug 1, 2017 at 11:07 AM
    #442
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    pulled the trigger on the S/C today. Got the UCON EMS and the URD 05+ fuel pump upgrade (walbro 255 lph) to go with it.
    now to select the gauges and wait for the return home to install. . . .
    I have 4.56, URD TCAI, 35's (5 including the spare on the rear tire carrier), with armor and get about 14mpg. if that puts your mind at ease?????
  3. Aug 1, 2017 at 11:09 AM
    #443
    s10nick
    s10nick Well-Known Member
    nick
    Greeley, CO
    base mod. debaged
    3inch hbs lift toytec diff drop grillcraft grill hella 500s conv. to 8k hids xentec hid head light conv. 5% tint more to come
    Agreed that's a bit rich!
  4. Aug 1, 2017 at 11:44 AM
    #444
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
    I have understood that cats don't like unburned fuel = rich mixture = black smoke. Somebody said that the rich AFR is for protecting cats... Please, could someone explain? :confused:
    A bit? A lot! I'd like to see 12.0:1.
  5. Aug 1, 2017 at 11:45 AM
    #445
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    Lean fuel mixture makes for a hot exhaust gas temp
  6. Aug 1, 2017 at 11:46 AM
    #446
    Skootter14
    Jeremy
    is the real concern with too rich of a mixture: detonation???
  7. Aug 1, 2017 at 11:48 AM
    #447
    glorifiedwelder
    jason
    Santa Clarita, ca
    Too rich can cause cylinder wash. Too lean will cause detonation
    Torspd likes this.
  8. Aug 1, 2017 at 11:50 AM
    #448
    FinnJ
    Finland
    I don't know, maybe. I have never experienced one with my FJ, despite of lean mixture with the previous not-so-optimal tunes. But the UCON should give more/better timing advance.
  9. Aug 1, 2017 at 11:53 AM
    #449
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    What he said.
    The cats have a happy medium of fuel mixtures they can work well in. Too lean or rich can cause them to melt, damage, or fail.
    Skootter14 likes this.
  10. Aug 1, 2017 at 11:54 AM
    #450
    Skootter14
    Jeremy
    Gotcha, makes sense.
    you guys have any pics of where you mount the UCON on the Tacoma?
  11. Aug 1, 2017 at 11:55 AM
    #451
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Running below 9's for to lengthy a period of time, will not only cause cylinder wash, but can also allow fuel past the rings and into the oil pan. Worst case scenario. Then it will dilute and break down the oil.
    Again, worst case scenario.
    Tacomalx4x4 likes this.
  12. Aug 1, 2017 at 11:59 AM
    #452
    glorifiedwelder
    jason
    Santa Clarita, ca
    It mounts to your ecu with Velcro and a zip tie. The instructions have good directions and some pictures
  13. Aug 1, 2017 at 12:00 PM
    #453
    Skootter14
    Jeremy
    sweet, thanks. I wasn't sure if I would have to self tap screw it in the kickpanel area or something
  14. Aug 1, 2017 at 12:05 PM
    #454
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    it'll piggy back right on top of the ecu .. just enough room.
    Skootter14[QUOTED] likes this.
  15. Aug 1, 2017 at 12:18 PM
    #455
    oni06
    oni06 Well-Known Member
    Anyone with the UCON + an OBDII guage (ScanGuage, UltraGuage, BullyDog, etc..) having any issues with the data stream. Right now I just have the BullyDog that came with the S/C and it starts to display guage info then pauses and sometimes will continue and sometimes will say initializing connection. Not sure if its the BullyDog or something to do with the data stream from the UCON to the ECU.
    I am inclined to lean toward the BullyDog since the ECU isn't throwing any CEL.
  16. Aug 1, 2017 at 12:32 PM
    #456
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I just ordered this:
    http://www.innovatemotorsports.com/products/dlg1.php
    Replacing my Speedhut AFR gauges since they only go down to 10:1. Another benefit is two AFR gauges in one housing to save room. I wish they made another digital one that was fuel pressure and boost in the same housing. Then I could have only two gauges.
  17. Aug 1, 2017 at 12:39 PM
    #457
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Reset the battery as tor said, runs a little weird but we will see as more miles go on it
  18. Aug 1, 2017 at 12:39 PM
    #458
    jojotoo
    Brandon
    Socal
    2015 DCLB
    its probably the Bullydog.. no issues with my scangauge.
    oni06[QUOTED] and loginfailed like this.
  19. Aug 1, 2017 at 12:40 PM
    #459
    Skootter14
    Jeremy
    I have the UG and asked Gadget about the readings on that with the UCON installed. as far as intake temps, MPGs, distance, etc, those should not be affected. Stuff like AFR will most likely since the point of the UCON is to keep the stock ECU happy (or at least that's my understanding). Which is why I plan on getting the AFR gauge, but still use the UG for other parameter outside of AFR and boost.
  20. Aug 1, 2017 at 12:46 PM
    #460
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    That will "sometimes" happen when you have more than one OBD2 device at the same time. UCON counts as one. So UCON + Scan Gauge = 2.
    In my case, I've had all at the same time... The UCON, the Maestro interface for my Pioneer radio, an UltraGauge, and my Autel Maxisys. The CAN BUS traffic gets a little crowded.
    Roostfactor and jojotoo[QUOTED] like this.
