UCON Flex Advanced Engine Management System
Discussion in 'Performance and Tuning' started by gray223, Jul 5, 2014.
  1. Aug 12, 2017 at 4:51 AM
    #581
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    throttle body spacer?
  2. Aug 12, 2017 at 6:23 AM
    #582
    5thGearPinned
    5thGearPinned Light Speed
    Texas
    2013 DCLB 4x4
    TRD Supercharger
    Looks like the 7th.
  3. Aug 12, 2017 at 6:35 AM
    #583
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    :eek: :drool:
  4. Aug 12, 2017 at 8:48 AM
    #584
    s10nick
    s10nick Well-Known Member
    nick
    Greeley, CO
    base mod. debaged
    3inch hbs lift toytec diff drop grillcraft grill hella 500s conv. to 8k hids xentec hid head light conv. 5% tint more to come
    Has anyone had auto trany issues since the ucon install? My acted like it lost 5 gear all the sudden. It wouldn't shift into 5th at all while I was driving down the hwy. Pulled over shut it off and let it sit for a few mins then started back up. No issue worked fine again it was strange. Just curious if anyone else had this same issue?
    loginfailed likes this.
  5. Aug 12, 2017 at 10:04 AM
    #585
    Billy182
    Billy182 Well-Known Member
    NJ
    X-Runner
    2013 X-Runner build thread: https://www.tacomaworld.com/threads/billy182s-2013-x-runner-build.829354/
    Just a little update on mine, I did a steady cruise and a WOT data log for Scott this morning, and he got back to me right away and said the UCON reflash worked well with everything pretty much spot on....
    except that the cam angles are off, so evidently the pos bullydog flash is still in there and costing me horsepower.
    I've decided I'm going to buy a normally aspirated ECU for my x-runner and go from there. Unfortunately the x-runner used parts market is almost non existent, so I think I'm going to have to buy a brand new ECU. Has anyone else done this? I'm guessing the new ECU's are blank and need to be flashed with an OEM factory tune.
  6. Aug 12, 2017 at 10:11 AM
    #586
    Skootter14
    Jeremy
    I think @loginfailed knows a thing or two (or four) about ECUs and Ebay haha
    Roostfactor, loginfailed and oni06 like this.
  7. Aug 12, 2017 at 12:19 PM
    #587
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
    It's not blank, it's ready to go. VIN is missing, but you can add it later.
  8. Aug 12, 2017 at 12:35 PM
    #588
    Billy182
    NJ
    X-Runner
    Ok, whew that's good news. At this point I spent so much money on this truck what's another 600. At least then I'll know it's good to go. Do you know how I'd add a VIN to it? Jumping pins 13 & 4 on the OBD2?
  9. Aug 12, 2017 at 12:57 PM
    #589
    FinnJ
    Finland
    ^ You'll need the Mongoose cable or similar. And Toyota Techstream with VIN Update Wizard (VUW).
  10. Aug 12, 2017 at 3:17 PM
    #590
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Mine has done this since my original ECU using the Bully Dog flash. It also did it on the second ECU with the TRD flash and it still does it on my current ECU with the UCON.
    Mine will eventually shift into 5th. But I can manually make it shift to 5th buy just clicking the shifter over to 4th then back to 5th. It's weird behavior but not a huge issue. It doesn't do it all the time and it seems like it happens more in the morning when the trans hasn't fully warmed up yet.
    I had the same issue with the TRD flash. Swapped to a stock ECU and cam angles are where they're supposed to be.
    You got THAT right!
  11. Aug 12, 2017 at 3:20 PM
    #591
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    This^
    My original clif notes from the group buy thread:
  12. Aug 12, 2017 at 4:08 PM
    #592
    oni06
    oni06 Well-Known Member
    This happens to me as well. However it started happening before the S/C + UCON where installed. It started happening when I went from 265/70/R16 to 285/75/R16 tire size and I haven't regeared.
  13. Aug 12, 2017 at 4:10 PM
    #593
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Mine did it with stock tires.
  14. Aug 12, 2017 at 4:10 PM
    #594
    oni06
    UCON was updated this morning and I just finished data logging while the family took a nap.
    Its fucking hard to grab this data where I live in Los Angeles/Harbor City.
    30-60 sec of constant 75 on the freeway is much harder than it sounds.
    Finding a place to WOMP on it from a stop is also very hard to find where I live.
    With that said the WOMP was :D:D:D:D :burnrubber::burnrubber::burnrubber::burnrubber::burnrubber:
  15. Aug 12, 2017 at 4:12 PM
    #595
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    NICE!
    I usually wait until night time to do the logs. As soon as I get my cruise set at 75, some slow mofo decides to get in my lane, lol.
    jojotoo likes this.
  16. Aug 12, 2017 at 4:16 PM
    #596
    oni06
    This is LA ... night time traffic isn't much different than day time traffic
    jojotoo likes this.
  17. Aug 12, 2017 at 4:19 PM
    #597
    oni06
    No expert at reading the logs but looks like AFRs dropped into the mid 10s
    jojotoo and loginfailed like this.
  18. Aug 12, 2017 at 4:19 PM
    #598
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    One of my buddies used to live there he said the same thing, lol. I couldn't make it there I like my space. And my guns, lol.
    Roostfactor and jojotoo like this.
  19. Aug 12, 2017 at 4:20 PM
    #599
    oni06
    Born and raised and haven't lived anywhere else.
    I really want space and I like my guns to.
    jojotoo and loginfailed[QUOTED] like this.
  20. Aug 12, 2017 at 4:21 PM
    #600
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Sounds right. UCON likes it rich. You can see the cmdAfr and that tells you what the UCON is shooting for. And Sensorswraf1 sensorswraf2 is what is actually happening.
