UCON Flex Advanced Engine Management System
Discussion in 'Performance and Tuning' started by gray223, Jul 5, 2014.
  1. Aug 14, 2017 at 7:37 AM
    #661
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    so. . .how do these "logs" work. Is there extra equipment required to purchase???
  2. Aug 14, 2017 at 7:41 AM
    #662
    gersus
    gersus Well-Known Member
    Missouri
    14 Tacoma DCOR
    Lil lift, bumpers, SC, UCON, headers, etc.
    Scott has software to record logs with the UCON.
  3. Aug 14, 2017 at 7:48 AM
    #663
    gersus
    Missouri
    14 Tacoma DCOR
    @Skootter14 you haven't installed the sc yet right? Mine is lower because of the 170 thermostat included with the ucon. When I had the stock thermostat I was running 185-195ish.
  4. Aug 14, 2017 at 7:49 AM
    #664
    Skootter14
    Jeremy
    so "we" don't have to do anything special or connect anything fancy (or buy some cable to plug into the ucon)?
    Excuse my ignorance...I'm not caught up on all the--using a computer to tap into a car to change paramaters blah blah blah (stuff I don't understand haha)
    Tacomalx4x4 and loginfailed like this.
  5. Aug 14, 2017 at 7:49 AM
    #665
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    Once Scott installs the tuning software you can look at all the values and kind of figure out what he's looking at.
  6. Aug 14, 2017 at 7:50 AM
    #666
    Skootter14
    Jeremy
    you are correct, I have not. I did get the ucon also, so ill be swapping out the thermostat as well.
    loginfailed and gersus[QUOTED] like this.
  7. Aug 14, 2017 at 7:51 AM
    #667
    jojotoo
    Brandon
    Socal
    2015 DCLB
    All the necessary cables will be included.
  8. Aug 14, 2017 at 8:46 AM
    #668
    oni06
    oni06 Well-Known Member
    USB cable that goes from the UCON to a laptop.
    Scott installs software on said laptop.
  9. Aug 14, 2017 at 8:47 AM
    #669
    Skootter14
    Jeremy
    just as long as its not a MAC haha (I think)
  10. Aug 14, 2017 at 8:53 AM
    #670
    oni06
    Correct. Mac not supported. Must be Windows.
  11. Aug 14, 2017 at 9:28 AM
    #671
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    When I installed my WeatherTech floor mats I did have to cut a notch for the accelerator pedal to be able to completely travel to the floor.
    Tacomalx4x4 and jojotoo[QUOTED] like this.
  12. Aug 14, 2017 at 9:29 AM
    #672
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Apple users can use Apple Bootcamp as a solution to that issue.
    oni06[QUOTED] likes this.
  13. Aug 14, 2017 at 9:32 AM
    #673
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Unless you want the UCON expansion harness for wiring in the 7th injector or other sensors. That cable is not included. I had to order it from Gadget and he charged $40 for it. Should have been an included item in my opinion.
    Roostfactor and jojotoo[QUOTED] like this.
  14. Aug 14, 2017 at 9:42 AM
    #674
    jojotoo
    Brandon
    Socal
    2015 DCLB
    I do have weather techs
    loginfailed[QUOTED] likes this.
  15. Aug 14, 2017 at 9:54 AM
    #675
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I'm not sure if that would be enough to make you lose 30% of your throttle but it's worth looking into.
    jojotoo[QUOTED] likes this.
  16. Aug 14, 2017 at 10:08 AM
    #676
    oni06
    Agreed. That should be included either with the UCON or with the 7th Injector.
    I take it its not included with the 7th kit?
    loginfailed[QUOTED] and jojotoo like this.
  17. Aug 14, 2017 at 10:22 AM
    #677
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Nope. $40 either way, unfortunately.
  18. Aug 14, 2017 at 10:22 AM
    #678
    jojotoo
    Brandon
    Socal
    2015 DCLB
    Nope .. gadget called me after I purchased the 7th, said I would need it.
    loginfailed likes this.
  19. Aug 14, 2017 at 10:24 AM
    #679
    oni06
    No "Dislike" button.
  20. Aug 14, 2017 at 10:24 AM
    #680
    oni06
    so what else can be wired into the UCON besides the 7th?
