UCON Flex Advanced Engine Management System
Discussion in 'Performance and Tuning' started by gray223, Jul 5, 2014.
  1. Aug 14, 2017 at 10:25 AM
    #681
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    $40 is a drop in the bucket compared to what I've spend with URD. Definitely should be included with the UCON.
    oni06[QUOTED] and jojotoo like this.
  2. Aug 14, 2017 at 10:25 AM
    #682
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    Yeah .. but it'll be a starting point. Plus, I had drive 15 miles to find an open spot at 5am. Might have not had my foot all way to the floor. I wanted to hurry and get out .. felt like I was doing something illegal. Lol
  3. Aug 14, 2017 at 10:27 AM
    #683
    jojotoo
    Brandon
    Socal
    2015 DCLB
    Yeah .. where's the "dislike button". He charged me $50 !!
  4. Aug 14, 2017 at 10:27 AM
    #684
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Widebands, extra injectors, other sensors that can be logged, not sure what all is possible.
    jojotoo likes this.
  5. Aug 14, 2017 at 10:27 AM
    #685
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    BS
    Roostfactor and jojotoo[QUOTED] like this.
  6. Aug 14, 2017 at 10:29 AM
    #686
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Because you were!
    oni06 and jojotoo[QUOTED] like this.
  7. Aug 14, 2017 at 10:34 AM
    #687
    oni06
    oni06 Well-Known Member
    Yeah 40-50 bucks is a drop in the bucket when looking at the project as a whole.
    jojotoo and loginfailed like this.
  8. Aug 14, 2017 at 10:49 AM
    #688
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    @loginfailed no misfires in 300 miles so far today, but the other codes popped up 2-3 times.
    I think i might know why it was misfiring
    @StOrMyThEtAcO said that the internal o-ring was causing it.
    During gear install, mine was half off, and I crazy glued it
  9. Aug 14, 2017 at 10:49 AM
    #689
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I agree with the way you put it and do see it from that point of view because for anyone doing all of this to their trucks, $40 shouldn't phase them one bit. Scott even told me he was going to ask Gadget to send me the cable when we were talking about logging my Innovate LC2s. But I told him I had already ordered it from Gadget for $40 and we left it at that.
    I have no direct knowledge of the arrangement between them, but I suspect Gadget is sitting on a pile of expansion harnesses that should've wound up in the boxes with everyone's' UCONs. Primarily I would say that he doesn't want people just hooking crap up to the UCON all willy-nilly and shorting stuff out. Secondarily, there's an extra $40-$50 revenue being generated each time someone calls looking for their missing harness.
    jojotoo likes this.
  10. Aug 14, 2017 at 10:49 AM
    #690
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    What o-ring?
    Billy182 likes this.
  11. Aug 14, 2017 at 12:34 PM
    #691
    jojotoo
    Brandon
    Socal
    2015 DCLB
    If you're a novice like myself you'll be scratching your head when plugging in the harness to the ucon. I was literally following the out dated instructions to the "T". It states that the 3rd port on the ucon will not be used when all ports will need to be connected. 6 connectors = 6 Ports on the ucon.
    I'm probably the only one that went through this .. lol
    loginfailed likes this.
  12. Aug 14, 2017 at 12:45 PM
    #692
    GT7
    Grant
    Phoenix
    2013 DCLB
    The orange one that seals the internal cooler. Not an o-ring I guess, just a seal
    loginfailed[QUOTED] likes this.
  13. Aug 14, 2017 at 12:48 PM
    #693
    Billy182
    Billy182 Well-Known Member
    Bill
    NJ
    X-Runner
    2013 X-Runner build thread: https://www.tacomaworld.com/threads/billy182s-2013-x-runner-build.829354/
    There's no way that can cause a miss. Even the replacement ones from TRD said to re-glue it if it falls away
  14. Aug 14, 2017 at 12:49 PM
    #694
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    don't some remove that orange seal all together? I took mine out.
  15. Aug 14, 2017 at 12:51 PM
    #695
    GT7
    Grant
    Phoenix
    2013 DCLB
    Must be a different o-ring! Ill probably take mine out then next time its apart
  16. Aug 14, 2017 at 1:04 PM
    #696
    Billy182
    Bill
    NJ
    X-Runner
    I'm not sure why anyone would take that out, the whole idea is to seal the intercooler so all of your intake charge is forced through it
  17. Aug 14, 2017 at 1:10 PM
    #697
    mightytacoman
    Kel
    4.5L 1grfe
    Some have found that the glue doesn't hold it well and it can get sucked down into the engine, others say it runs better without it. When I flooded my truck (8ft of water) and I took the intercooler out, it was barely hanging on. So I took it out and its one less thing to worry about. At first I tried gluing it, but it still didn't hold like I felt it should.
  18. Aug 14, 2017 at 1:45 PM
    #698
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    wait .. . so you don't plug in one of the 6 ports (bc the instructions say so). . . .and later it says once all 6 are plugged in its good. . . hmmmm somethings not adding up haha
    so did you plug all 6 in?
    loginfailed and jojotoo[QUOTED] like this.
  19. Aug 14, 2017 at 1:45 PM
    #699
    s10nick
    s10nick Well-Known Member
    nick
    Greeley, CO
    base mod. debaged
    3inch hbs lift toytec diff drop grillcraft grill hella 500s conv. to 8k hids xentec hid head light conv. 5% tint more to come
    You will have to let me know what happens with the trany issue mine hasnt done ot since but if there is a fix I want to do it
  20. Aug 14, 2017 at 1:48 PM
    #700
    jojotoo
    Brandon
    Socal
    2015 DCLB
    Plug all 6 .. I called gadget, he said instructions were outdated, plug all 6.
