UCON Flex Advanced Engine Management System
Discussion in 'Performance and Tuning' started by gray223, Jul 5, 2014.
  1. Aug 15, 2017 at 7:42 AM
    #721
    oni06
    oni06 Well-Known Member
    S/C and UCON. Nothing else.
  2. Aug 15, 2017 at 7:47 AM
    #722
    gersus
    gersus Well-Known Member
    Missouri
    14 Tacoma DCOR
    Lil lift, bumpers, SC, UCON, headers, etc.
    Must've got some CA smog in your intake. haha
    Torspd, Roostfactor and oni06 like this.
  3. Aug 15, 2017 at 7:53 AM
    #723
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Mine did the same thing and Scott logged back in and checked a box that said iMode somewhere in the settings and those codes never came back.
    Roostfactor and jojotoo like this.
  4. Aug 15, 2017 at 10:29 AM
    #724
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    Im hoping the URD intake will help balance the "too rich" afr a little (comparted to the stock or in-engine bay intakes)
  5. Aug 15, 2017 at 11:05 AM
    #725
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    UCON will control afr from 0 to 100% throttle. It keeps the system in closed loop all the time. It will adapt to your mods as well but you may need a different "stage" tune (more aggressive) if changing to headers.
    oni06 and Skootter14[QUOTED] like this.
  6. Aug 15, 2017 at 11:13 AM
    #726
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
    It will, but it change to the open loop too.
  7. Aug 15, 2017 at 11:28 AM
    #727
    Skootter14
    Jeremy
    Nows a GREAT time to ask this question:
    What is meant by OPEN and CLOSED loop?
  8. Aug 15, 2017 at 11:57 AM
    #728
    Roostfactor
    TX panhandle
    Closed loop the ECU used the wraf "O2" sensor signals to keep afr at approximately 14.7 to 1. Stoichiometric afr. In open loop the ECU doesnt care what the wrafs are doing, it just uses maf, throttle position, and I dont know what else to dump extra fuel in. Toyota sets this part of the ECU map up extra rich to keep cats from overheating and from possibly going lean at very cold temps at sea level.
    Skootter14 likes this.
  9. Aug 15, 2017 at 12:00 PM
    #729
    Roostfactor
    TX panhandle
    Not to doubt you FinnJ but how do you know this?
    The UCON stays in closed loop to keep command of the afr at all times. If it didn't then you would have to have a means of controlling mixture at high throttle settings e.g. maf calibrator.
  10. Aug 15, 2017 at 1:04 PM
    #730
    FinnJ
    Finland
    My ScanGauge shows when it's closed and when it's open.
    I have thought that too, I don't know, maybe the UCON still reads the WRAFs at background even if it's in open loop.
    Roostfactor[QUOTED] likes this.
  11. Aug 15, 2017 at 1:43 PM
    #731
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Hey buddy does this have a part number? I need to get one asap the p0300 happens every 10-15 miles :bananadead:
  12. Aug 15, 2017 at 1:55 PM
    #732
    oni06
    ScanGuage is only showing you what the UCON is telling the stock ECU. The stock ECU wants to think its in closed or open loop so thats what the UCON is telling it.
    What the UCON is actually doing is the magic fair dust shit.
    jojotoo likes this.
  13. Aug 15, 2017 at 2:15 PM
    #733
    Skootter14
    Jeremy
    Thank you very much
  14. Aug 15, 2017 at 2:16 PM
    #734
    FinnJ
    Finland
    Maybe you are right.
    RA77 and Roostfactor like this.
  15. Aug 15, 2017 at 2:35 PM
    #735
    Skootter14
    Jeremy
    so its an ECU also. . .but lets the stock ECU run things until this "30%" hits. After which, the UCON takes over and feed false data to the stock. . .(I assume)
  16. Aug 15, 2017 at 3:01 PM
    #736
    Roostfactor
    TX panhandle
    Correct...remember the UCON gets the raw engine data first, then sends happy signals back to the ecu so it thinks it's running the show. The scangauge is getting it's data from the ecu but the ECU is getting false data from the UCON.
    Torspd likes this.
  17. Aug 15, 2017 at 3:05 PM
    #737
    Roostfactor
    TX panhandle
    Not really. The UCON controls all aspects of the tune. The 30% you are referring to how much adaptive control it has. If more adaptive tune is required over 30% then the guardian kicks in as a precaution to protect the engine.
    Say for example you put a 2 inch pulley on the sc with stock one injectors and no other fuel mods. At wide open throttle you would have massive fuel demand and the UCON would try to keep your afr at say 11.75. Since your injectors would be wide open and not even close to providing enough fuel the afr would skyrocket! The UCON would sense that it could not control the rising afr so would actuate the guardian.
    Torspd likes this.
  18. Aug 15, 2017 at 3:13 PM
    #738
    Roostfactor
    TX panhandle
    Sorry, after re-reading your post I believe that to be correct as far as the 30% being throttle input.
    Not to be confused with the 30% adaptive.
  19. Aug 15, 2017 at 3:32 PM
    #739
    StOrMyThEtAcO
    StOrMyThEtAcO @stormythetaco
    Cody
    CO
    18 TRD Sport mom bus
    All of them
    I don't have a part number. I would just email Magnuson with my picture an ask what size they are.
    GT7[QUOTED] likes this.
  20. Aug 15, 2017 at 3:45 PM
    #740
    Skootter14
    Jeremy
    yea, I should have specified: the 30% was throttle input
