UCON Flex Advanced Engine Management System
Discussion in 'Performance and Tuning' started by gray223, Jul 5, 2014.
  1. Aug 27, 2017 at 4:13 PM
    #941
    gersus
    gersus Well-Known Member
    Missouri
    14 Tacoma DCOR
    Lil lift, bumpers, SC, UCON, headers, etc.
    Is that because its new? I put a used one in mine with the paper clip method and its been good to go.
  2. Aug 27, 2017 at 4:16 PM
    #942
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Oh I forgot you bought a new one. Used one already has a VIN.
  3. Aug 28, 2017 at 7:59 PM
    #943
    oni06
    oni06 Well-Known Member
    Hope those of you in Houston are doing okay.
    Roostfactor, jojotoo and loginfailed like this.
  4. Aug 28, 2017 at 8:19 PM
    #944
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I'm blessed to have made out pretty good. Never lost electricity even once. I was pretty worried last night as the water inched its way up my driveway, but thankfully it only got to a little past the expansion joint in my driveway which is around 10ft from house.
    Many areas had it pretty bad and lost everything. Prayers for those that have been displaced. Its going to take a long time to get things back to normal.
  5. Aug 29, 2017 at 9:34 AM
    #945
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Months if not a year. :rain:
    Roostfactor and loginfailed like this.
  6. Aug 29, 2017 at 10:16 AM
    #946
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Everything ok w/ you Torspd?
    5thGearPinned and Roostfactor like this.
  7. Aug 29, 2017 at 11:11 AM
    #947
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Street is flooded just past the sidewalk. Our street is currently doing well. Pending the Addicks reservoir funneling off water quickly enough.
  8. Sep 3, 2017 at 8:47 AM
    #948
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    after swapping to a stock ECU.. all is fixed.
    BD was restricting my throttle %.
    looks like the cels have cleared as well.
  9. Sep 3, 2017 at 9:22 AM
    #949
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That is awesome!
    loginfailed likes this.
  10. Sep 3, 2017 at 11:33 AM
    #950
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Good to hear! Been down the same road myself. Seems stock ECU with N/A flash is the best for use w/ UCON.
    oni06 and Roostfactor like this.
  11. Sep 3, 2017 at 1:14 PM
    #951
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    great news man! glad to hear it.. . again this just makes me THAT much more excited for the install.. . .a couple more months
    oni06 and loginfailed like this.
  12. Sep 3, 2017 at 2:57 PM
    #952
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    So did you do a WOT run yet? What was your max MAF? How does it run?
    jojotoo[QUOTED] likes this.
  13. Sep 3, 2017 at 3:57 PM
    #953
    jojotoo
    Brandon
    Socal
    2015 DCLB
    max MAF is 286
    cam angles are 0 at WOT
    cels came back.. 420/430, going to stuff my tailpipe and look for a leak.
    loginfailed[QUOTED] likes this.
  14. Sep 3, 2017 at 6:48 PM
    #954
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I forget, do you have any cats? Shouldn't be getting p0420/430 catalyst efficiency below threshold with the S3 tune. Are you on S3?
  15. Sep 3, 2017 at 6:52 PM
    #955
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Hurry up and get home, brother!
    Skootter14[QUOTED] and jojotoo like this.
  16. Sep 3, 2017 at 7:24 PM
    #956
    jojotoo
    Brandon
    Socal
    2015 DCLB
    no cats.. S3 tune. Ive had the codes since removing the cats / installing the headers. If I plug the tailpipe, is it suppose to stall if i dont have a leak ? Cause its not stalling and i cant visibly see a leak.
    Scott adjusted the tune twice . He says im the only one with this issue :frusty:.. so we're thinking its an exhaust leak.
  17. Sep 3, 2017 at 7:26 PM
    #957
    oni06
    Just got back from vacation yesterday.
    Los Angeles, CA -> San Francisco,CA (x2 days) -> Klamath Falls, OR -> Crater Lake National Park (x2 days) ->Klamath Falls, OR -> Mammoth Lakes, CA -> Los Angeles
    Somewhere around 2k driven. No CEL, 15.5-16.7 MPG (on highway, not in boost), power when needed to pass.
    Loving the S/C and UCON and surprisingly clocked the best MPG since I started tracking it.
    Looking forward to future S/C upgrades sometime next year. Wife has put a hold on all Tacoma purchases for the rest of the year.
    jojotoo, Skootter14 and loginfailed like this.
  18. Sep 3, 2017 at 7:32 PM
    #958
    gersus
    Missouri
    14 Tacoma DCOR
    Sometimes the UPS dude just drops crap off. Idk :notsure:
  19. Sep 3, 2017 at 7:38 PM
    #959
    oni06
    Next Friday is my birthday ... just saying ;)
  20. Sep 3, 2017 at 8:19 PM
    #960
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Not true, I have had recurring 0420 an 0430's myself. He did tweak the tune about 10 days ago and I got a cel shortly after. He was going out of town so I reset the cel an haven't had one since in about 150 miles of driving. I have headers and stock y.
    Scott seems like a great dude though and super knowledgeable so I have faith in him and his abilities.
