UCON Flex Advanced Engine Management System
Discussion in 'Performance and Tuning' started by gray223, Jul 5, 2014.
  1. Sep 3, 2017 at 9:15 PM
    #961
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    I have had the same issue
    loginfailed likes this.
  2. Sep 3, 2017 at 9:53 PM
    #962
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I would think its a leak between the front WRAFs and rear O2s. Maybe a collector crush gasket? Not sure if a manifold or SAI gasket leak would cause cat inefficiency or not, but I guess check everything exhaust related?
    Too much passing and your MPG won't be that good! :D
    Honey, I ordered that 6 months ago. They said it was on back order. :D
    Just order yourself something. Tell your sweetie that a bunch of your Tacomaworld buddies pitched in for a gift. :stirthepot:
  3. Sep 3, 2017 at 9:58 PM
    #963
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    The only issue I'm having is that the damn exhaust is still not quiet enough for my tastes. I wonder if an additional resonator would help. I may be able to squeeze one more in there before the muffler.
    Anyone think the second resonator would help, or is this big ass Magnaflow going to be loud no matter what?
  4. Sep 3, 2017 at 11:59 PM
    #964
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    You got the 3" mark whatever magnaflow from URD? I think its gonna be loud no matter what unless you go back to stock and add a resonator with what you're pushing through there
    loginfailed[QUOTED] likes this.
  5. Sep 4, 2017 at 1:14 AM
    #965
    GT7
    Grant
    Phoenix
    2013 DCLB
    I e got two resonaters and it quited it only slight but made the overall tone so much better on the spec u system
  6. Sep 4, 2017 at 4:43 AM
    #966
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Back to stock!?! :rofl::crazy::der::lalala::smack::luvya::brianr::jerkoff:
    oni06 and gersus like this.
  7. Sep 4, 2017 at 10:04 AM
    #967
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    How the heck is it running if the exhaust is plugged to where no gasses can get out?!?!??
    You have to have some major leaks.
    Did you install new crush gaskets between the headers to y-pipe? Have you re-torqued on all of the header and y-pipe hardware?
    loginfailed and inwood customs like this.
  8. Sep 4, 2017 at 4:04 PM
    #968
    VolcomTacoma
    Jeff
    NorCal
    I'm just saying, it's probably the quietest on the market without tossing 2 resonators and a muffler on there. You're still flowing more than stock so its gonna be loud. You want a quiet racetruck lol.
  9. Sep 4, 2017 at 11:48 PM
    #969
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    I think I've replaced the crash gaskets twice .. once when I stilled the headers then last week for the y pipe. I recall both components came with 2 each.
    I've checked for exhaust leaks a week after I installed the headers and a 2nd time after installing the y pipe which was a week ago. Then a 3rd time at a muffler shop to weld the resonator. All the hardware was re-torqued twice and they were all tight. I do smell a bit of exhaust when I am driving. The cels appeared after installing the headers so I m gonna start from the header gasket.
    After the 3rd tune .. 420 seems to have fixed it self, still have 430.
    Probably take it to my buddy's shop tomorrow and check the whole setup. Again ...
    Found a dyno shop near by .. will post some numbers after the 2.55 pulley and upgrading my valve body. Middle of next month.
    Roostfactor likes this.
  10. Sep 5, 2017 at 5:25 AM
    #970
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    jojotoo likes this.
  11. Sep 6, 2017 at 11:51 AM
    #971
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
    Tried to look with Techstream what is going on, but I had no luck. It connects to the vehicle, but when trying "Engine and ECT" nothing happens, just scrolling and Please Wait...:
    But if I shut down the engine, then it goes further, but then there is no connection anymore:
    IMG_3656.jpg Normal? Techstream worked without problems before the UCON.
  12. Sep 7, 2017 at 11:50 AM
    #972
    Billy182
    Billy182 Well-Known Member
    Bill
    NJ
    X-Runner
    2013 X-Runner build thread: https://www.tacomaworld.com/threads/billy182s-2013-x-runner-build.829354/
    Got my new ECU in, and the 2.55 on. Overall very happy, now to take a closer look at the data logs from today's test runs
    Roostfactor, Torspd, jojotoo and 4 others like this.
  13. Sep 7, 2017 at 12:36 PM
    #973
    gersus
    gersus Well-Known Member
    Missouri
    14 Tacoma DCOR
    Lil lift, bumpers, SC, UCON, headers, etc.
    Nice!
    I got a pod mount and was going to install it the other day but it looked like the gauges were going to obscure more than I wanted of the factory gauges so I took it off. Yours seems fine, even at a low angle. Maybe I'll look at it again.
  14. Sep 7, 2017 at 12:38 PM
    #974
    Billy182
    Bill
    NJ
    X-Runner
    Ahh relief! Cam angles are looking better with the new ECU
  15. Sep 7, 2017 at 1:15 PM
    #975
    FinnJ
    Finland
    Has anyone tried Techstream with UCON?
  16. Sep 7, 2017 at 5:21 PM
    #976
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I have not tried it. I don't have the cracked version so I pay $55 each time I use it. Needless to say, I don't use Techstream often. I do need to get back in there and program my VIN, though.
  17. Sep 7, 2017 at 5:22 PM
    #977
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Yep, that look good. Mine are about 5 or so as well.
  18. Sep 7, 2017 at 5:24 PM
    #978
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Looks good, mine goes up to around 10 also. Taking pics of your gauges at 90 MPH? LOL
    By the way, on your WOT data log, what is your max MAF number?
    FinnJ, Torspd, jojotoo and 1 other person like this.
  19. Sep 8, 2017 at 7:23 AM
    #979
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    oni06 and jojotoo like this.
  20. Sep 8, 2017 at 7:39 AM
    #980
    Billy182
    Bill
    NJ
    X-Runner
    Here's my peak MAF g/s: 309.9
    and my cam angles at that point:
    loginfailed, jojotoo and Roostfactor like this.
