UCON Flex Advanced Engine Management System
Discussion in 'Performance and Tuning' started by gray223, Jul 5, 2014.
  1. Jun 12, 2017 at 7:47 AM
    #81
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    May the cam gear modding begin!
  2. Jun 12, 2017 at 8:16 AM
    #82
    gersus
    gersus Well-Known Member
    Missouri
    14 Tacoma DCOR
    Lil lift, bumpers, SC, UCON, headers, etc.
    I'm not exactly looking forward to that. Can I just do the passenger side? hahahahaha
  3. Jun 12, 2017 at 8:26 AM
    #83
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    I hear ya. At least I haven't installed my s/c yet so less dissassembly.
  4. Jun 12, 2017 at 8:39 AM
    #84
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Loosen off on the spark plugs. Will make that hand cranking of the engine MUCH easier, to line up timing.
    Lord Helmet and WOODEX M.E. like this.
  5. Jun 12, 2017 at 11:00 AM
    #85
    oni06
    oni06 Well-Known Member
    Same. Ordered the UCON and haven't installed S/C yet.
  6. Jun 12, 2017 at 11:49 AM
    #86
    Roostfactor
    TX panhandle
    Dang oni, you have had yours since the group buy right? What's the holdup?
  7. Jun 12, 2017 at 11:55 AM
    #87
    oni06
    No time and place to do a self install.
  8. Jun 12, 2017 at 5:23 PM
    #88
    Roostfactor
    TX panhandle
    Anyone received theirs yet or have shipping info? Mine hasn't shipped yet and I ordered on the 8th. I know URD website says by the 16th.
  9. Jun 12, 2017 at 5:26 PM
    #89
    oni06
    URD website says instock on the 16th. I assume they will ship after that.
    Also they need a default tune loaded based on what your current mods are so URD needs to contact those that ordered to get that info and load that default tune.
  10. Jun 12, 2017 at 5:33 PM
    #90
    Roostfactor
    TX panhandle
    URD has my mod info. I'm just anxious to get it.
  11. Jun 12, 2017 at 5:34 PM
    #91
    oni06
    Did they reach out to you or did you reach out to them.
    I want to get my mod info over to them.
  12. Jun 12, 2017 at 5:41 PM
    #92
    Roostfactor
    TX panhandle
    I called because I had some other questions. I would say get your order info from their website and email them your mod list. Title the email something like "UCON order #........... vehicle info/ mod list.
    That way they know right away in the title of email that you already paid for it and that they have the info they need to process your order.
    I should have just put my info in the (comments) section on the order page.
    oni06 likes this.
  13. Jun 12, 2017 at 6:33 PM
    #93
    oni06
    Done. In hindsight I should have also put it in the comments.
    Roostfactor[QUOTED] likes this.
  14. Jun 12, 2017 at 7:57 PM
    #94
    Roostfactor
    TX panhandle
    As for the s/c install, I installed the intercooler and plumbing, reservoir, wiring (Don't install fuse), bracket/pump, etc. Pretty much getting everything else ready in my spare time to minimize downtime. Still have to tackle the crank pulley though.
  15. Jun 12, 2017 at 8:04 PM
    #95
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Is yours auto or manual?
  16. Jun 12, 2017 at 8:49 PM
    #96
    Roostfactor
    TX panhandle
  17. Jun 12, 2017 at 8:53 PM
    #97
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Pull the fuel pump relay, and crank bump the pulley's bolt free. Unless you have a strong impact gun.
    Then impact it back on..
    Lord Helmet likes this.
  18. Jun 12, 2017 at 8:55 PM
    #98
    Roostfactor
    TX panhandle
    Think im going to try a makeshift pulley holder with a 30 inch long 2x4. Drill 2 small holes that line up with pulley holes, then drill larger hole in center for socket to go through. Bolt the 2x4 to the pulley then rotate until the other end touches the ground to lock it in place. Then remove pulley bolt.
    Install is just reverse procedure.
  19. Jun 12, 2017 at 8:57 PM
    #99
    Roostfactor
    TX panhandle
    Not sure if my impact is strong enough but i also would like to torque it to spec. Do most people just impact the snot out of it back on or torque torspd? Haha, couldn't resist!
  20. Jun 13, 2017 at 5:18 AM
    #100
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I prefer the method which you describe. Making the tool, or buying the tool from Amazon.
    There is one potential issue that you are bound to encounter, is bolt breaking torque force overcoming the strength of the bolts which hold the tool to the crank pulley. M8x1.25.
    Just did an NST crank pulley install on a friend's truck. Bump method to release, and then impact to tighten it back.
    Regular crank pulley torque spec is around ~185 ft-lbs. With the s/c crank pulley, it is around ~205 ft-lbs. Don't quote that.
    I prefer torquing properly, but.....unless you can hold the flexplate from rotating, if the bolts won't....then you're left with how strong your impact gun is.
