UCON Flex Advanced Engine Management System
Discussion in 'Performance and Tuning' started by gray223, Jul 5, 2014.
  1. Sep 18, 2017 at 1:00 PM
    #1021
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    Not sure if I wanna pay $157 in shipping. 6 injectors / 6 harness .. how in the hell is that $157 for FedEx ground. I think shipping for y pipe and exhaust were less.
    loginfailed[QUOTED] likes this.
  2. Sep 18, 2017 at 1:03 PM
    #1022
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Yea Gadget said his new website's shipping module is charging separate shipping per item. He's working on debugging it. He said place the order then email him and he'll refund the difference. Or wait till Wednesday and give him a call.
    jojotoo[QUOTED] likes this.
  3. Sep 18, 2017 at 1:05 PM
    #1023
    jojotoo
    Brandon
    Socal
    2015 DCLB
    lol .. makes sense. thanks !..
  4. Sep 18, 2017 at 1:29 PM
    #1024
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Still a lot of bugs in the new website I see. No fuel pump available for the '05-'15 Tacoma either.
    oni06 likes this.
  5. Sep 18, 2017 at 1:40 PM
    #1025
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Gadget said he was trying to debug it. I like the fresh look but there really wasn't anything wrong with the old site, IMO.
    Also the coupon code I used before is inop. :pout:
  6. Sep 18, 2017 at 4:24 PM
    #1026
    Billy182
    Billy182 Well-Known Member
    Bill
    NJ
    X-Runner
    2013 X-Runner build thread: https://www.tacomaworld.com/threads/billy182s-2013-x-runner-build.829354/
    Yeah I found the same prob, I wanted to order the URD y-pipe today. It says on the site 10% off, but then only orders through as list price, plus the old ForumMember coupon code isn't working either. I hate to wait, but after spending a small fortune at URD I'll wait until I get a good price.
    In the mean time, I've ordered a couple of the shorter Dayco belts (my belt was still slipping). They should be here in a day or two so it will give me something to do. Hopefully that will eliminate the belt slipping prob
  7. Sep 18, 2017 at 4:28 PM
    #1027
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Yep, I'd like to upgrade the injectors but I'll wait until a coupon code comes up, or maybe a Black Friday Cyber Monday sale.
    I have the shorter belt too. Haven't put it in yet though. Because I'm lazy, lol.
    Biscuits and jojotoo like this.
  8. Sep 18, 2017 at 4:38 PM
    #1028
    jojotoo
    Brandon
    Socal
    2015 DCLB
    It should .. the shorter belt is pretty tight.
  9. Sep 19, 2017 at 12:34 PM
    #1029
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
    I liked the old site much more, just waste of time and money just update for nothing. Much more difficult to use by phone.
  10. Sep 19, 2017 at 2:16 PM
    #1030
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Well maybe he wants to freshen it up to attract the 3rd genners.
  11. Sep 19, 2017 at 2:51 PM
    #1031
    gersus
    gersus Well-Known Member
    Missouri
    14 Tacoma DCOR
    Lil lift, bumpers, SC, UCON, headers, etc.
    I think it might have been due to issues behind the scenes with ordering.
    Login, thats hilarious and makes total sense!
    loginfailed likes this.
  12. Sep 20, 2017 at 1:53 PM
    #1032
    Billy182
    Bill
    NJ
    X-Runner
    I'm curious and will need to check my data logs to see what the duty cycle is for the wot rpm range I would drive in.
    I honestly don't think I'll ever be winding it up as high as I did for the test, but 4.5 to 5k is definitely possible.
    If your afr's stay in a stable range during use even up to the redline as we did for our data logs, is it worth the extra $ for bigger injectors?
  13. Sep 20, 2017 at 2:51 PM
    #1033
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    If you're not hitting 80% duty cycle, it's not really necessary to upgrade the injectors.
    I'm going one size up because sometimes I may want to do a WOT run and would rather have a little headroom to work with.
    jojotoo and oni06 like this.
  14. Sep 20, 2017 at 5:43 PM
    #1034
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    85% duty cycle is the tuning standard. I wonder how much more fuel from the 7th injector the UCON will add. I would imagine all the way to 100% duty cycle if need be. If you guys are at around 40% duty cycle on the 7th and 80% on the primaries I think you are fine. The only way to know for sure is datalog at the lowest altitude on the coldest day for your area. That will place the largest fuel demand on your fuel system since that will be the densest air your engine will see.
    jojotoo likes this.
  15. Sep 21, 2017 at 9:01 AM
    #1035
    Billy182
    Bill
    NJ
    X-Runner
    @12TRDTacoma @Torspd @jojotoo
    Guys, thanks for helping me find the right belt to fit my 2.55 pulley. I got it on yesterday but haven't driven the truck yet. Hopefully this will cure the slipping problem I had that came with the stock belt
    (accidentally double posted, went into wrong thread first time)
  16. Sep 21, 2017 at 9:55 AM
    #1036
    12TRDTacoma
    Rob
    Concordia
    Boosted
    No problem man! It was a bear for me to find, so I don't want other people going through the same ordeal I did. The more information available out there to us the better so I'm just spreading the love. :)
    jojotoo likes this.
  17. Sep 21, 2017 at 11:07 AM
    #1037
    Billy182
    Bill
    NJ
    X-Runner
    My dyno sheet, overall a little disappointing, it looks like the belt was slipping at around 3800 rpm. Ambient temps were 85 degrees
    loginfailed and FinnJ like this.
  18. Sep 21, 2017 at 11:19 AM
    #1038
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Did you just do this dyno? That amount of power and torque looks about right though. What are your mods? How much boost are you maxing at now and if you get this much power at warmer weather, imagine what it will perform like on 60*F and below days. :)
  19. Sep 21, 2017 at 11:34 AM
    #1039
    Billy182
    Bill
    NJ
    X-Runner
    This dyno was a week ago. Boost gauge goes up to 10psi and it was pinned during this dyno run.
    I guess I was only disappointed in the belt thing, other than that it's pretty much what I expected out of the build. Considering the stock bottom end, I sure don't want to grenade it, but on the other hand wanted a drivable street vehicle that pulled well throughout the rpm range, and as shown by the torque curve it attains that goal.
    I have the TRD (magnuson) blower, DT long tubes, 2.55 pulley, 7th injector, exhaust cam gears, 180 thermostat, UCON, and AFE dry air cleaner with added Volant scoop. As soon as Gadget gets his new website straightened out, I'll be buying the URD y-pipe to use with the stock muffler (lol until I find another cat back with suitable noise levels)
    Biscuits and loginfailed like this.
  20. Sep 21, 2017 at 11:55 AM
    #1040
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Okay okay. That looks like a nice build. Your belt should be under control now that you got the new one on. Did you get a press on 2.55 pulley or a quick change like I have?
    I'm close to hitting 11 psi on a 86*F day if I hold it in boost for longer than a brief moment of time like I usually do. Otherwise I normally sit at about 9.5-9.7 psi. I guess it takes more than a few seconds for the blower to build up max boost it is capable of pushing with it's respective pulley size configuration.
    You may be being slightly choked up with that Y pipe if you are still using the stock one. I couldn't believe how restricted it is when I saw it!
