UCON Flex Advanced Engine Management System
Discussion in 'Performance and Tuning' started by gray223, Jul 5, 2014.
  1. Sep 27, 2017 at 6:36 PM
    #1081
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Then you should have a 2 and 1/2 in Cat-Back exhaust from the factory. OD. The earliest models had two and a quarter.
  2. Sep 27, 2017 at 10:07 PM
    #1082
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Go with the 2.5". 2.25" will restrict flow as it would be the smallest diameter in the post y of the exhaust.
    gersus likes this.
  3. Sep 28, 2017 at 9:05 AM
    #1083
    Billy182
    Billy182 Well-Known Member
    Bill
    NJ
    X-Runner
    2013 X-Runner build thread: https://www.tacomaworld.com/threads/billy182s-2013-x-runner-build.829354/
    Thanks guys. I'll be honest I'm really surprised at how much louder it is, especially since I already had DTLT's and kept the original muffler. Before the y-pipe it sounded almost no different than stock. I guess that just goes to show how restrictive the original y-pipe with secondary cats is.
    I'll be looking forward to getting the vibrant resonator welded in and toning things down a bit
    jojotoo and Roostfactor like this.
  4. Sep 28, 2017 at 9:45 AM
    #1084
    5thGearPinned
    5thGearPinned Light Speed
    Texas
    2013 DCLB 4x4
    TRD Supercharger
    What about the performance aspect of the new y pipe with all your other mods? Did opening up the exhaust free up a lot more power? Is that part worth the extra loudness?
  5. Sep 28, 2017 at 9:56 AM
    #1085
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Did a before and after dyno run, with the URD Y-pipe, as the changed component. It is in the N/A dyno thread. Huge gain at the end of the RPM range, even for N/A. It was on a 1GR 4Runner, with the stock catback, DTLT headers, and APR X-1. Again, the only change was the Y-pipe.
    5thGearPinned likes this.
  6. Sep 28, 2017 at 9:58 AM
    #1086
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It is Lucario Runner's graph. In the first post.
  7. Sep 28, 2017 at 4:17 PM
    #1087
    5thGearPinned
    Texas
    2013 DCLB 4x4
    TRD Supercharger
    Nice. That is definitely good gain.
  8. Sep 28, 2017 at 5:35 PM
    #1088
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  9. Sep 28, 2017 at 8:30 PM
    #1089
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    What's all of the excitement about?
  10. Sep 28, 2017 at 9:18 PM
    #1090
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Howdy. Back from the dead.
    At least someone gets excited about me.:(
    loginfailed[QUOTED] and jojotoo like this.
  11. Sep 29, 2017 at 3:15 AM
    #1091
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Who doesn’t get exited about biscuits? :D
    Biscuits[QUOTED] likes this.
  12. Sep 29, 2017 at 6:35 AM
    #1092
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I like mine with honey and butter. :hungry:
    loginfailed and oni06 like this.
  13. Sep 29, 2017 at 10:32 AM
    #1093
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    So since your last dyno( which was with the 2.55" correct?), you have installed the shorter belt, and the Y-pipe, yes?
  14. Sep 29, 2017 at 2:09 PM
    #1094
    Roostfactor
    TX panhandle
    I like where you're going with this Torspd.
  15. Sep 29, 2017 at 3:09 PM
    #1095
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  16. Sep 29, 2017 at 7:15 PM
    #1096
    Billy182
    Bill
    NJ
    X-Runner
    Yes, noisier now, but still hitting 10 psi with the blower wound up.
  17. Sep 29, 2017 at 8:11 PM
    #1097
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Time to dyno again! Or at least after you upgrade the catback to 3". If you really want to increase the Y pipes lemon or flow then at the exiting merge collector you need to cut it right where produces down from 3 inches and then world on a flange to mate to the 3 inch cat back. So that it is a true 3 inch out of the Y pipe into the cat back.
  18. Sep 29, 2017 at 10:23 PM
    #1098
    Biscuits
    Why 2.5" to 3.0"? Y-pipe diameter is 3.0"?
  19. Sep 29, 2017 at 10:36 PM
    #1099
    Roostfactor
    TX panhandle
    It does begin as a 3" but necks down at the flange to accomodate stock 2.5" exhaust. Bottom pic at the flange is made to fit to the stock 2.5" exhaust.
  20. Sep 30, 2017 at 5:45 AM
    #1100
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    This is it^^^
    Roostfactor[QUOTED] likes this.
