UCON Flex Advanced Engine Management System
Discussion in 'Performance and Tuning' started by gray223, Jul 5, 2014.
  1. Jun 13, 2017 at 5:23 AM
    #101
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Good stuff, I like it! Thanks for the tips!
  2. Jun 13, 2017 at 8:56 PM
    #102
    Roostfactor
    TX panhandle
    Used the breaker bar starter method for crank pulley bolt removal. Worked like a champ! Ended up impacting the install. Special tool bolt holes on s/c pulley were slightly off from stock pulley so wouldnt easily thread.
    jojotoo and oni06 like this.
  3. Jun 13, 2017 at 9:01 PM
    #103
    oni06
    oni06 Well-Known Member
    Progress :thumbsup:
    Roostfactor[QUOTED] likes this.
  4. Jun 13, 2017 at 9:45 PM
    #104
    Roostfactor
    TX panhandle
    Yeah, should be an easy install once the UCON comes in.
    oni06 likes this.
  5. Jun 13, 2017 at 9:47 PM
    #105
    oni06
    I was emailing Gadget back and forth today to get them my info and he said he is trying to get them all out by early next week.
    So hopefully soon.
    zerotimeouts likes this.
  6. Jun 13, 2017 at 9:57 PM
    #106
    Roostfactor
    TX panhandle
    Thx for the update. I thought he might ship the initial batch of orders all at once to avoid people complaining when some but not all ship.
  7. Jun 13, 2017 at 10:01 PM
    #107
    oni06
    If I get it before the 1st I will be golden as thats my install date for the S/C
  8. Jun 14, 2017 at 12:16 AM
    #108
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
  9. Jun 14, 2017 at 10:30 PM
    #109
    Guns 'n Tacos
    Guns 'n Tacos Well-Known Member
    Georgia
    would the UCON offer significant gains over the MAF calibrator if used on a naturally aspirated engine?
  10. Jun 14, 2017 at 10:41 PM
    #110
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Significant enough to justify the additional cost over the Maf Cal? I would personally say no. You could probably get another 15 horse out of it all while having the numbers be perfect (which is the kicker). If that is worth it to you is up to you though...
    gersus likes this.
  11. Jun 14, 2017 at 10:43 PM
    #111
    Guns 'n Tacos
    Georgia
    Thank you, I'm debating if I want to pony up now incase I decide to add a SC later. I already decided on power over suspension and that was a difficult decision to make too!
    gersus likes this.
  12. Jun 14, 2017 at 10:46 PM
    #112
    memario1214
    Colton
    Missoula, MT
    If you honestly think that you will spring for the S/C I say just pony up for it now. The money will already be spent either way and you get to reap the UCON benefits on the front end as well.
  13. Jun 14, 2017 at 10:48 PM
    #113
    Guns 'n Tacos
    Georgia
    I'm sure I will, I just moved to the Tacoma from a Cummins with ~650 rwhp and 1100 ft/lbs...
  14. Jun 14, 2017 at 10:53 PM
    #114
    memario1214
    Colton
    Missoula, MT
    In that case you will likely be disappointed even with the blower, but I can tell you from experience it sure gets waken up with one. With the UCON you can go down to some small pulleys and should be able to produce some real nice power though.
  15. Jun 14, 2017 at 10:55 PM
    #115
    Guns 'n Tacos
    Georgia
    I'm having more fun with this truck being able to fit in a parking garage and not weighing as much as a house, so any little power gain I can squeeze out is like a cherry on top. Having a fast full size was fun but it was lifted 6" and on 37" MTs, not very practical.
    gersus and Torspd like this.
  16. Jun 14, 2017 at 11:01 PM
    #116
    memario1214
    Colton
    Missoula, MT
    Haha it doesn't take long to make a Tacoma impractical as well! Welcome to TW, ask questions, and mod on!
    :wave:
    oni06 and Guns 'n Tacos[QUOTED] like this.
  17. Jun 15, 2017 at 4:22 PM
    #117
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    anyone gonna document the process of the cam gear swapping? I have no idea about this aspect and it is keeping me from leaning on the UCON EMS for the SC???
    EDIT: Im talking with TRD Sparks and they are looking at another GB on Magnuson S/Cs if anyone is looking to get one.
    DanoDavis and nudavinci64 like this.
  18. Jun 15, 2017 at 4:25 PM
    #118
    Guns 'n Tacos
    Georgia
    I second that
  19. Jun 15, 2017 at 6:38 PM
    #119
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    It is documented, and you receive the instructions once you have the UCON.
    Here is a brief run down. Pull the valve covers. Line up timing marks. Pull exhaust cam gears. Install new. Reassemble. Lol. But seriously.
  20. Jun 15, 2017 at 7:07 PM
    #120
    Guns 'n Tacos
    Georgia
    Thanks, I'm not much of a mechanic so I'm terrified of pulling the valve cover without seeing what the process entails first.
    Skootter14 likes this.
